Old 11-18-2009, 12:35 PM   #1
Dezi
Dezi is an unknown quantity at this point
96 S14 - Pulley noise
Today I went and looked at this old ladies 96 240sx and it's in great condition except for this squealing noise coming from a pulley that I have pointed to in that picture below(not the same car as I looked at today, just using pic to show) My thoughts are that it's just a loose pulley, I checked the belt and it seemed firm but I couldn't move the pulley with my finger. I might still buy this car if anyone hear can tell me a little more about this problem.
Dezi is offline   Reply With Quote
Old 11-18-2009, 12:40 PM   #2
M11's
M11's's Avatar
M11's is an unknown quantity at this point
your power steering pump may need replaced
M11's is offline   Reply With Quote
Old 11-18-2009, 12:42 PM   #3
Ben G
Ben G's Avatar
Ben G is an unknown quantity at this point
did you check the underside of the belt for wear? The belt should turn about a quarter turn any more or less the tension is off, Go up to the pulleys and pull on them a bit back and forth if they are moving excessively they just need to be tightened, check them also for wear chips abnormal wear all you might need to do is tighten or loosen the belt... good luck
Ben G is offline   Reply With Quote
Old 11-18-2009, 12:46 PM   #4
Dezi
is that what the pulley operates? if it is then is it difficult to replace them? to me it looked pretty easy to access that area but I came here because you guys know a lot more about these cars than I do.
and yes I did check the belt and the condition of the pulley itself and they seemed good to me. I've been reading some other threads and I started to see some that talk about spun bearings so it might be bad bearings in the pulley or a bad steering pump like M11 said.
Old 11-18-2009, 12:52 PM   #5
Ben G
Ben G's Avatar
download the fsm and take a look at it you will learn alot and you can decide yourself
240sx FSM, Full Service Manuals, S13, S14, KA24E, KA24DE: 240SX Forum / 180SX Forum / Silvia Forum: Nissan Forums / Infiniti Forums - NICOclub
Old 11-18-2009, 12:54 PM   #6
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
pulley may have been taken off and not put back on properly
pump may be going out
owner may have put power steering fluid in the system instead of auto tranny fluid.
Old 11-18-2009, 12:58 PM   #7
Dezi
Thanks a lot this will also help me find the exact part names of things i need to replace.
Old 11-18-2009, 01:50 PM   #8
iROYAL
iROYAL's Avatar
iROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfection
an old lady drives that!!??
does she look like this?
iROYAL is offline   Reply With Quote
Old 11-18-2009, 01:56 PM   #9
S14DB
AFC #1
S14DB's Avatar
L2R...
Old 11-18-2009, 01:58 PM   #10
Dezi
haha she is short like that lady, old people are the best to buy from. she is the 2nd owner and has had the car for 13 years of it's life. a few scratches on the front and rear bumper covers and around 125k miles it runs great except for this noise. so i think i will ask her to lower the price a little bit and then i will buy a new p.s. pump for it if it really needs it. first i'm going to take the old one apart and see if it's just a simple fix.
Old 11-18-2009, 02:34 PM   #11
S14DB
AFC #1
S14DB's Avatar
Change the Belt and fluid first.
Old 11-18-2009, 02:41 PM   #12
Dezi
yea i don't plan to spend the money on a new pump if i don't have to i'm going to check all the simple things first
