Old 09-13-2003, 12:15 AM   #1
dmaestro
dmaestro's Avatar
dmaestro is an unknown quantity at this point
Send a message via ICQ to dmaestro
s13 strangest s13 problem
Okay so I took my valve cover off to paint it today. Everything went fine. I put the valvecover back on after like 6 hours and turned on my car. Switched my lights on, they work but my intrument panel and rear lights don't work. The clock, hud, engine lights, cd player, headlights, turn signals, and brake light all work. The instrument panel and the rear driving lights don't work!!! WTF, all I did was paint my valve cover, I didn't unplug anything! Except when my fender light fell out and came unplugged. Could that have tripped everything? I don't think so, this problem happened immediatley after I painted my valve cover. I checked all the fuses and wiring to see if everything was plugged in correctly, everything is!! WTF s wrong? This S13 is has wierder problems then my AE86!!
dmaestro is offline   Reply With Quote
Old 09-13-2003, 03:22 AM   #2
tougebear
tougebear is an unknown quantity at this point
It's the switch. It has nothing to do with you taking out the valve cover. Pure coincidence.
tougebear is offline   Reply With Quote
Old 09-13-2003, 11:25 AM   #3
dmaestro
dmaestro's Avatar
the dimmer switch? light control switch? timer switch?
which one? there's a lot of switches down there.
Old 09-13-2003, 07:30 PM   #4
blue240
blue240 is an unknown quantity at this point
check fuses with a test light not by eye.Learned that the hard way
ever wish you were born in Japan?
blue240 is offline   Reply With Quote
Old 09-13-2003, 08:43 PM   #5
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
idk y this crosses my mind...u check that ground wire commin off the fire wall to the head????( on the right side of motor..its braided)
idk if thats it...but it could help...idk
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 09-14-2003, 11:12 AM   #6
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
yeah I have had a couple "good" fuses that were bad. I'd use caution using a test light though, it actually places a load (the light) on the circuit being tested. Which is bad.
Use a digital multimeter. For 20 bucks at walmart or whereever, there is really no excuse not to have one.
andrave is offline   Reply With Quote
