Old 11-24-2009, 04:47 PM   #1
KeithDigital
KeithDigital is an unknown quantity at this point
Why is my turbo leaking from here? (pics)
Stock turbo. Very slow leak. Not really sure where it's coming from but it looks like where the turbine housing meets the center part?
KeithDigital is offline   Reply With Quote
Old 11-24-2009, 05:36 PM   #2
Sileighty_85
Sileighty_85's Avatar
well its either leaking from the oil return or the oil feed line up top
im pretty sure that oil would be cooked if it was leaking inside
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-24-2009, 09:32 PM   #3
Def
99% of the time when you see that you've got excessive blowby, and your compressor housing is basically filled with oil. Take off the intake pipe to the turbo and I bet it's absolutely coated in oil.
Your rings might be going, causing excessive blowby.
DEFSPORT
Old 11-25-2009, 12:26 AM   #4
cotbu
cotbu's Avatar
First you need to determine exactly were the leak is coming from. You still have hard lines, maybe it's cracked, Or maybe it's a drainage problem. Or check the compressor inlet and outlets for oil, wouldn't bother with the exhaust housing, since you didn't mention any smoke. I'm sure the engine bay smokes a little.
Old 11-25-2009, 12:51 AM   #5
J90lude
J90lude's Avatar
J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude
That definitely looks like a crack to me!
"Drive it like you running from the cops"
J90lude is offline   Reply With Quote
Old 11-25-2009, 03:07 AM   #6
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
lol just take apart the turbo and find out
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 11-25-2009, 06:40 AM   #7
KeithDigital
I'll take a look at the intake, but I know the turbo has that huge elbow on it, may not be able to see anything? Also if there was oil in it, wouldn't you think it would be a bad turbo seal - rather then the piston rings?
I will try to do a compression test - that should let me know about the rings.
I know the oil return line is good, the oil feed line - I will have to take off the heat shield to look at.
Take the turbo appart...lol, that is my last resort.
I'll work on this during the weekend, and let you guys know what happens, thanks for the great ideas.
Old 11-25-2009, 07:34 AM   #8
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
damn, i would help u if i was back home.
S13 curtis is offline   Reply With Quote
Old 11-25-2009, 01:02 PM   #9
KeithDigital
Thanks Curtis - if I don't' take too many things apart, I'll be at the Arbys meet on Sunday.
Old 01-13-2010, 04:17 PM   #10
KeithDigital
Well I decided to take the turbo off since I had an exhaust manifold leak anyway. I was hoping this oil leak was from the Oil Feed Line - maybe loose or broken, but the Oil Feed Line looks good. Why is my turbo leaking from here?!! The compressor and turbine wheels look normal - no sign of oil leaking/burning.
Old 01-13-2010, 04:20 PM   #11
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
Is there oil residue in the downpipe?
Most likely, the seals inside the turbo are bad.
Chernobyl is offline   Reply With Quote
Old 01-13-2010, 04:41 PM   #12
Rabboni
Rabboni is an unknown quantity at this point
Im just gonna say that you probably need to rebuild the turbo. There are a lot things that could cause the seals to go bad, but to make sure it doesnt happen again make sure the oil return line is unobstructed, there isnt any excessive blowby (leakdown test is ideal), and that there isnt any shaft end play.
Baling Wire-The Duct Tape Of Champions
Rabboni is offline   Reply With Quote
Old 02-06-2010, 06:19 PM   #13
KeithDigital
I found out the previous owner had some rigged up oil line and ran full oil pressure to this turbo.... You are suppose to have a restrictor of 0.06" or use the factory banjo bolt. So pissed this turbo is mint looking and now I have to rebuild or replace it. I was told there is a slight chance the turbo could be ok if put the factory banjo bolt back on, but not sure I am going to chance it.
Old 02-06-2010, 07:45 PM   #14
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Is it a stock turbo? You dont need a restrictor for stock journal bearing turbos.
CLICK HERE!!!
Old 02-06-2010, 08:54 PM   #15
S13 curtis
S13 curtis's Avatar
get a T28 you will like it alot better if you got the money.
Old 02-06-2010, 09:06 PM   #16
Def
Yes, you do. You need a restrictor for *ALL* turbos.
The stock oil feed banjo bolt has a ~0.06" hole in it to reduce pressure to the turbo CHRA.
A BB CHRA turbo needs a ~0.030" restrictor.
DEFSPORT
Old 02-06-2010, 09:55 PM   #17
KeithDigital
Exactly! 100% correct.
Old 03-16-2010, 12:38 PM   #18
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enough
Feedback Score: 105 reviews
I have the same oil leak, mine is comming from the oil feed banjo bolt because the copper crush washers need to be replaced. Im just getting steel braided lines, hardlines are a pain in the ass.
PM me for s13 or s14 parts!
s13 drifta is offline   Reply With Quote
Old 03-16-2010, 04:09 PM   #19
KeithDigital
It's leaking where the oil line comes out of the block? If so, just unbolt the banjo bolt slap 2 new crush washers on - Nissan Part# 15193-P9000 (order two of them) and be done with it. If you install the steel braided lines you'll need to take your manifold and turbo off! Way too much work
Old 03-17-2010, 10:57 AM   #20
s13 drifta
s13 drifta's Avatar
Nope, its leaking from the turbo. I have to pull the turbo and mani off anyways to install new washers. I already bought goodridge lines, I hate hardlines.
Old 03-17-2010, 03:09 PM   #21
KeithDigital
There are no washers on the turbo side of the oil line, check it out:
I doubt it's leaking from there.
I hate hardlines too!
Old 03-20-2010, 11:39 PM   #22
MavericStephenc
MavericStephenc's Avatar
MavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfection
Send a message via AIM to MavericStephenc
any updates on this?
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd
Boycott Berkeley and code pink
MavericStephenc is offline   Reply With Quote
Old 03-21-2010, 12:06 AM   #23
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
i had a turbo that leaked from there but it had no shaft play and it spooled fine, just made a mess =/
I just replaced the whole unit cuz I ended up snapping the shaft turning the shaft nut counterclockwise to loosen it (it's reverse thread) but when i took the turbo apart it looked like it was leaking from a seal at the end of the CHRA, so it's probably not too hard to replace you would just need the turbo VSR re-balanced.
spooled240 is offline   Reply With Quote
Old 03-21-2010, 07:26 AM   #24
KeithDigital
The previous owner had some rigged up oil line and ran full oil pressure to this turbo and I assume this blew a seal. spooled240 sounds exactly my turbo. Spools great and no shaft play, just leaky and messy. I ended up replacing my turbo with another one.
Old 03-22-2010, 01:58 PM   #25
MavericStephenc
Werd O_o sounds good
