![]() Join Date: Apr 2004
Lower harness mystery plug
I have a question about the reverse light wiring used in this writeup: http://www.ka24development.com/cwilf...lectrical.html
In this picture, he used a gray male 8-pin gray connector. ![]() Looking at the pins as seen from the pic: Yellow-Red-Orange-Black Not used-White-Green-Blue Anybody know what this is originally from? The pigtail was cut. I'm just curious what it was originally for. It's seen plugged into the "E13" connector on the auto car in the picture, but the "E13" has different colours on the body harness side. I'm wonder where he got that plug from. Last edited by g6civcx; 11-25-2009 at 08:47 AM.. |
![]() Join Date: Dec 2002
The colors from the chassis side to the transmission side do not match. So, don't bother with trying to figure it by color.
The automatic transmission has a total of four plugs, one is a 3pin for the revolution sensor, one large 2pin for the starter inhibit, and then the two 6 or 8pin plugs, one gray, one red, that provide signal and comm.
#3 | ||
That's not what I'm asking. E15. Gray plug. White, black, and shielded wire. E12. Black/white and black/red on this car for the theft warning relay. Quote:
top row orange - line pressure solenoid valve pink - overrun clutch solenoid blue/red - shift solenoid valve a blue/yellow - shift solenoid valve b bottomw row not used black, white/red - atf fluid temp sensor gray/red - torque converter clutch solenoid valve The gray E13 has 7 wires: top row light green/red - D sensor light green - 2 sensor blue - 1 sensor green - switched power bottom row not used gray/blue - N sensor red - R sensor brown - P sensor I am asking because they removed the auto gearbox wiring before I got there. They stuck that same connector into the E13 body harness as seen in the pix. I just want to know where that connector came from for future reference. It works but the colours do not line up with the body harness. I'm in the process of getting the lower harness from the auto so I will go through it myself. But in the meantime this colour change has caused confusion with the previous wiring "experts" and resulted in an engine fire. |
None of the wires match color to color through any of the four plugs that I recall.
For example, the auto wiring has a lot of blue wires, blue/white, blue/yellow, blue/red, blue/black, but none of the correspond to the automatic's harness. I don't have an automatic transmission or a car laying around to compare and match them up though.
connector
I think he has some extra harness's from a salvage yard. I work on electrical systems and when I go to salvage yards I will cut used harness's from cars just for the connectors. I think he connects all of the wires together to work the switch.
