Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Group Buys
Group Buys Dedicated Forum for Group Buys.
Old 01-14-2010, 07:22 PM   #1
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Skullworks - Evo/STi Brembo Caliper Brackets
WHAT:
Adapter brackets to install Evo 8/9 or STi Brembo calipers on your s-chassis.
It's bee a while coming but they're finally here
a fully R&D bracket that allows you to bolt the popular Brembo calipers to your 240.
We obtained a set of Evo and a set of STi Brembo calipers
took them completly appart and measured every conceivable feature on them
to ensure proper upright location, pad placement and rotor offset.
They're made here in the USA by us and test fitted on our cars.
FEATURES:
- CNCd from 1018 Carbon Steel for strength
- Zinc plated to withstand corrosion
- 10.9 (Grade 8 equivalent) bolts and washers included for ease of installation
We choose these features to ensure that the brackets will
withstand the rigors of track use without compromise to safety.
PRICE AND PAYMENT:
The price for these is $110 wich includes paypal and shipping fees.
They will ship via US Priority Mail so it will take roughly 3-5 business days to get to you.
paypal: stmaradona at yahoo dot com
please include your username with your payment message.
NOTES:
As some of you may know, we started on these a few months back
then stalled... and stalled... and stalled some more
here's why: in order to clear the calipers back fins
there needs to be a relief on the bracket around the upright threaded holes.
Most of the existing brackets floating around do it this way.
We weren't comfortable with this since we feel that by doing that the strength of the inner hole threads is compromised.
This could be catastrophic to someone that heavily tracks his car.
After much deliberating, we asked ourselves the question:
What would we do if these were just for ourselves?
We'd shave the back of the caliper and keep the threads on the bracket intact.
So in a nutshell that's what we did.
So you will need to shave your calipers down a bit (see pictures) to run our brackets.
We are aware that some people will be turned off by this and will choose to go a different route.
We're ok with that.
The way we see it, at the end of the day it's about doing something right.
Questions, concerns and comments are always welcomed.
PICTURES:
Amount of material shaved from calipers:
Fitment:
ManoNegra is offline
Old 01-14-2010, 09:13 PM   #2
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
wow those look amazing! i wish you had some for Evo X MR calipers cause i got a set for cheap!
i need tires is offline
Old 01-14-2010, 11:00 PM   #3
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Unfortunately we don't have a set of those calipers to compare.
Old 01-15-2010, 02:23 PM   #4
RAMM
RAMM is an unknown quantity at this point
Do you guys make the Z33 Track rotor brackets to be used with Z32 Calipers? If so, please PM me.
RAMM is offline
Old 01-15-2010, 08:00 PM   #5
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
sorry, we don't
Old 01-16-2010, 12:15 PM   #6
xpinoyxmk
xpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura about
Damn, i wish you guys would of made these before i bought these other brackets. These look so much better.
Glws.
xpinoyxmk is offline
Old 01-18-2010, 08:27 PM   #7
Darude
Darude's Avatar
Darude is an unknown quantity at this point
will these work on a Z32?
Darude is offline
Old 01-19-2010, 08:14 AM   #8
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Z32 calipers are interchangeable with the s-chassis
so I would assume that they would
however we haven't actually bolted and test fitted them on a z32 to confirm
material for the STi brackets arrived
we should be knocking those out this week
Old 01-19-2010, 12:12 PM   #9
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
i'm very interested in a product like this, but i would like it to fit z33 track rotors.
iirc, the evo rotor is 12.65" and the z33 is 12.8"
seems like it wouldn't take much to get .15" difference out of a similar design.
heck, you could probably just take your brackets and flip em 180 so that the bent part faces up instead of down and have enough clearance.
aaaaaanyways. i'm interested in that, thank you for making a cool product that many people have wanted for a long time.
brndck is offline
Old 01-19-2010, 01:12 PM   #10
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
wish you were 5 lug huh?
anyhow, per racingbrake.com:
Z33 Brembo 324x30mm - 12.8x1.2"
Evo 8/9 320x32mm - 12.6x1.3"
Evo X 350X32mm - 13.8x1.2" (for shits and giggles)
so yes, the z33 rotors are marginally larger but also a different thickness
that would require a redesign of the brackets
not worth it but thanks for the interest
Old 01-22-2010, 01:02 AM   #11
jspecusa
jspecusa's Avatar
jspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfection
Send a message via AIM to jspecusa
how about a bracket to fit Z34 4 piston rotors up front and a bracket to fit
the Z34 2 piston rotors up in the back for the Z32 front/rear brakes?
people are cheap they are not going to buy brembo calipers that's why I asked.
Nissan Japan: "road to happiness has many curves"
Jdmlivin: "Jdm is dead, the yen is crazy"
jspecusa is offline
Old 01-22-2010, 08:07 AM   #12
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
unfortunately that's usually the case
we don't have any plans to make z34 brackets but if someone wanted them made
and brought all the hardware - calipers, rotors, pads - it could happen
Old 01-22-2010, 07:33 PM   #13
ghostchild316
ghostchild316's Avatar
ghostchild316 is an unknown quantity at this point
Something like this?
Akebono Nissan 300ZX F&R 14 Inch Big Brake Kit w/ Stoptech Rotors, SS Lines, and Motul Fluid - Nissan performance parts
Or brackets to run z32 calipers with z34 rotors?
ghostchild316 is offline
Old 01-23-2010, 07:36 PM   #14
hey808
hey808 is a well-known jackass
Anyone running these yet? Just waiting for some feedback.
Bob
'92 Coupe
hey808 is offline
Old 01-23-2010, 08:00 PM   #15
awesomenick
awesomenick's Avatar
Trader Rating: (33)
awesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfection
Feedback Score: 33 reviews
Skullworks is legit. So any reviews that come will probably be good.
So tempting. I want these kinda. I don't even have any of these Brembo's yet though.
awesomenick is offline
Old 01-25-2010, 11:06 AM   #16
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Originally Posted by ghostchild316 View Post
But for $2700 you're in Brembo BBK territory
granted only for the fronts but still
you could do an Evo front (and back if you do some work) for ~$1500 if you shop carefully
and that's with 2 piece rotors.
we haven't shipped any so I would be very surprised if someone was
Thanks for the kind words Nick, let me know when you're ready
we tried running the STi brackets this past weekend in a batch plate set up
but the material proved too hard for the tooling
so we have to take a different - longer - approach
we're going to run them again in a few days after the oil blocks are done the same way we did the Evo ones
then they all will go out to plating
Old 01-25-2010, 04:44 PM   #17
hey808
When will they be ready for shipment to customers?
Bob
'92 Coupe
hey808 is offline
Old 01-25-2010, 08:29 PM   #18
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
couple of weeks I recon
they don't really take that long to make
it's just that 1018 destroys endmills so a careful approach is needed
honestly we're more preoccupied with the oil blocks at the moment since
people aren't knocking down our door for Brembo brackets
Old 01-26-2010, 05:56 AM   #19
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
I am planning on making my payment for an sti bracket by the end of this week.
garagelu is offline
Old 01-26-2010, 08:18 AM   #20
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
cool, appreciate it
Old 01-26-2010, 11:19 PM   #21
AWDJosh
AWDJosh is an unknown quantity at this point
i may have to get a set of these i already have the evo brembo brakes....hmmm ill take lots of pictures and be a sponsor(stick a sticker on my rear window) for a better price hahaha. =]
ill let you know im waiting on getting word from the machine shop on my build.
AWDJosh is offline
Old 01-28-2010, 12:43 PM   #22
koukie180
koukie180 is an unknown quantity at this point
Send a message via AIM to koukie180
What rotors do you use with the EVO calipers and what rotors with STI calipers?
koukie180 is offline
Old 01-28-2010, 01:11 PM   #23
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Evo 8/9 rotors for either.
Old 02-01-2010, 01:05 AM   #24
irax
irax's Avatar
are you guys ever going to make a secondary mount for the rear brakes? because that is pretty much what is holding me back from doing hydro ebrake because I would rather have a second caliper than T into the rear brake line. Also I am not cool enough to do hydro side brake anyways... But I will be pretending I'm awesome enough pretty soon soo... yeah
irax is offline
Old 02-01-2010, 11:55 AM   #25
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Sorry, no plans for a secondary rear brake caliper for now.
Old 02-06-2010, 12:20 PM   #26
NISR20MO
NISR20MO's Avatar
Trader Rating: (29)
NISR20MO is an unknown quantity at this point
Feedback Score: 29 reviews
These brackets just mount the front calipers only, correct?
Any plans to fab brackets for the rear calipers as well?
What brake lines would you use? - Custom/Stock Style/Z Conversion Lines
NISR20MO is offline
Old 02-07-2010, 12:44 AM   #27
arabrockermang
arabrockermang is an unknown quantity at this point
How about the rears?????
I bought a set of SRT-8 rear calipers for front but no one is willing to measure them from center to center hole I'm 90% sure they are the same as the EVO/STI except they use a thinner rotor which a SVT Cobra has a similar offset.
With that being said I was under the impression that the STI fronts had the same bolt pattern as the Evo is that true?
Also make some for the rear!!!! I bought a set for the rear but I didn't like the idea of drilling new holes where holes weren't before and tapping it. It doesn't appear safe to me. I'm thinking about trying to make them myself but heck if you guys are using carbon steel I'd rather buy it from you. I was just going to use mild.
Also I'm new to this forum just joined today I'm actually have been part of Nico a few months though so I'm not a total (also usto do everything the hard way that is figuring it out myself so glad forums are around now)
arabrockermang is offline
Old 02-07-2010, 11:52 PM   #28
cIutchkick
cIutchkick's Avatar
cIutchkick has a spectacular aura aboutcIutchkick has a spectacular aura aboutcIutchkick has a spectacular aura aboutcIutchkick has a spectacular aura aboutcIutchkick has a spectacular aura aboutcIutchkick has a spectacular aura about
Send a message via AIM to cIutchkick Send a message via MSN to cIutchkick
i might just need a set... i'll let you know
'95 zenki se - work in progress
'90 s13 coupe widebody
www.myspace.com/krahsh
cIutchkick is offline
Old 02-08-2010, 08:24 AM   #29
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
correct
none at the moment
z32 conversion lines work, or have stainless ones custom made.
Well the STi/EVO patterns are very similar but not enough
to make one bracket work for both like we originally wanted to
so my guess would the SRT calipers would need their own bracket made aswell
no, they don't
see my response above
only way I can see us making brackets for the rears is if someone would
be willing to bring us calipers and rotors to measure and test fit with
we already spent a good chunk of money developing
these brackets -3 sets or calipers, rotors, etc
and frankly the interest isn't high enough for us to develop a rear solution
since z32 rears work well as it is.
welcome aboard, spend some going through the FAQs and archives sections
and you'll be fine
ok
Old 02-09-2010, 08:27 PM   #30
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Update:
we're done making the oil blocks for the other group buy
and now our attention we'll be placed on getting these finished
so expect them done and ready to ship in about a week's time
we also decided to drop the price on these to $110 paypaled/shipped
since it's been brought to our attention most of the 240 community isn't 5 lug.
bbk, brakes, brembo, calipers, skullworks
