Old 01-19-2010, 04:31 PM   #1
Slevin86
Slevin86 is an unknown quantity at this point
Idle problem?
OK i have a S-13 with a KADE24 engine that i just finished replacing the timing chain on it and everything is hooked right and i started it today for the first time in four or five months and she starts up just fine and will just fine when reving the engine. But when you let it idle she just dies. Like not enough fuel is getting to it or something. But i am not to sure that is the case. I am going through everything and checking everything that has to do with the idle system but i am not to sure what it might be. Any thoughts or suggestions?
Slevin86 is offline   Reply With Quote
Old 01-19-2010, 04:32 PM   #2
tooslick
tooslick is an unknown quantity at this point
sounds like a vacuum leak, check all of your hoses.
tooslick is offline   Reply With Quote
Old 01-19-2010, 08:29 PM   #3
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
try to turn up the idle a little bit, on the passenger side in the very back of the intake manifold on the side is the idle air control valve. you'll see a little phillips head screw, loosen that screw a little to raise the idle.
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 01-19-2010, 08:44 PM   #4
Rabboni
Rabboni is an unknown quantity at this point
A vacuum leak would cause a high idle. I would check the idle air control, or adjust the idle up a little.
Baling Wire-The Duct Tape Of Champions
Rabboni is offline   Reply With Quote
Old 01-20-2010, 01:56 PM   #5
Slevin86
ok well i checked all the hoses and none are leaking. and i was told that there is an idler control box that sits under the intake that sometimes gets stuck when the car sits for a long time with out starting. so i am going to mess with that and see what happens. thanks for help everyone
Old 01-20-2010, 04:51 PM   #6
SinGarage
SinGarage's Avatar
SinGarage is an unknown quantity at this point
Double check your base timing too. I just recently did the same thing off my friends S14 and same situation also. Then I figured out I was off a tooth on the distributor.
SinGarage is offline   Reply With Quote
Old 01-20-2010, 04:53 PM   #7
Slevin86
ok i'll check that as well. but does any one know where you can get that idler box from? or the actual name of the part.
Old 01-20-2010, 05:16 PM   #8
drftmark
drftmark's Avatar
drftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura about
You should just be able to clean it out.
drftmark is offline   Reply With Quote
Old 01-20-2010, 11:00 PM   #9
Slevin86
ok so i can clean it up? i dont really have to replace it if it is no responding at this time?
and is it ok do drive around with this particular problem or would it be adviced not till there is time to fix it?
Old 01-22-2010, 01:29 AM   #10
tooslick
worst that could happen is you stall, that's it. you can drive it arround. just get some throttle body/carb cleaner and clean it out. Also, clean your throttle body. Sometimes oil/gunk clogs it and gives you similar issues.
Old 01-22-2010, 09:38 PM   #11
Slevin86
ok that is good to know. but now it doesn't matter since i accidently punched a hole into it. so i have to take it off and replace it. however here is a question. can that be bipassed or is there a way around not having one?
Old 01-22-2010, 09:40 PM   #12
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
you should just "mess" with everything until it works.... that usually works
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 01-23-2010, 12:39 AM   #13
Slevin86
well the intake manifold is coming off since i dropped an extension down there and i cant get it out. plus i need to see if i really did screw up the IAC Valve. any suggestion on a quick and easy way of doing this? I have the factory manual and it doesn't give me a walk through procedure of how to. It just shows a brake down picture of that side of the engine.
Old 01-23-2010, 02:32 PM   #14
Slevin86
cause right my main concern is am i going to have to disconnect the fuel lines in order to take off the manifold?
