Old 01-29-2010, 01:54 PM   #31
koukie180
koukie180 is an unknown quantity at this point
Send a message via AIM to koukie180
I've been to the bay area and those roads are like the bumpy roads in Santa Ana. I will say that coilovers will not be your friend on the streets. The Tein FLEX would be an exception. Their front spring rates are either 7K or 6K depending on S13 or S14.
Koni/RSR combo is indeed a great combo. Never have to worry about passengers being uncomfortable or head bouncing. The ride is smooth and responsive.
koukie180 is offline   Reply With Quote
Old 01-29-2010, 01:56 PM   #32
koukie180
Keep in mind that the RSR springs are the stiffest and among the lowest drop you can get for performance springs.
Estimated Front Drop - 35mm(1.4in)
Estimated Rear Drop - 25mm(1.0in)
Front Spring Rate - 5.00kg(279lbs)
Rear Spring Rate - 4.20kg(235lbs)
Old 01-29-2010, 02:14 PM   #33
k3fallout
k3fallout is an unknown quantity at this point
Thanks for the advice koukie. I figured if I wanted to go as stiff as Ground Control, then I'd might as well just go for coils(though the same could be said for any spring/shock combo for that matter). The only potential road "friendly" coilovers I've read about so far are the Stance LX/GR+ Pro, Tein Flex, Dmax, and Cusco. The people who bought them for the most part said that they road nicely or like stock on the softest settings, but it may be untrue with the roads around here.
k3fallout is offline   Reply With Quote
Old 01-29-2010, 05:37 PM   #34
wiggafly808
wiggafly808's Avatar
wiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to all
I would say save for coilovers..
I had tein drop springs with kyb gr-2s because i found them fairly cheap ($200), but upgraded to coilovers soon after.
Wait for a good deal on coils.
I found tein ha's for $350ish, so i bought those, and the ride quality was about the same.
Somebody offered me more than i paid for them, so i sold them, got some tein hr's for around $350 as well.
If you want cheap stiff coils, id go for megans. I know everyone here bashes them, but ive had them on my car and a bunch of my friends have them with no complaints, so based on my experience id go for it.
If you want a better ride quality, spend more and get some higher up brands
wiggafly808 is offline   Reply With Quote
Old 02-01-2010, 09:48 PM   #35
Gordo714
Gordo714's Avatar
Gordo714 is an unknown quantity at this point
i got a good one..
started out stock supension
went to eibach springs
blew out the stock shocks
got some kyb shocks and fresh eibachs from a trade...
ride was smooth but the ride height sucked
so i cut my springs like an idiot that lasted a couple of months
now im on blown shocks and cut springs = no supension = fail
moral of the story i should have saved up from the begging to get some coil overs ...
advise..save up its worth it..dont cut springs for a lower ride
Gordo714 is offline   Reply With Quote
Old 02-01-2010, 10:25 PM   #36
whiterps13
whiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to behold
I dont know if its been mentioned, because I didnt bother reading more than 10 posts down.
But, coilovers are also much easier to install than springs and shocks. Since they come preassembled, theres no need to use a spring compressor during installation.
A small detail, but yet another reason to choose coilovers.
whiterps13 is offline   Reply With Quote
Old 02-02-2010, 12:09 AM   #37
JAYTRON
JAYTRON's Avatar
JAYTRON is making a name for him/her selfJAYTRON is making a name for him/her self
Send a message via AIM to JAYTRON
OP: I see that you reside basically where I do. I use to live in Sac and still go to visit but now live in San Jose and I daily with coilovers ~50 miles a day.
Once you memorize streets and how to drive a lowered car you'll eventually get the hang of it.
The ONLY regret I have is that I have lower back problems...lol
No bueno
JAYTRON is offline   Reply With Quote
Old 02-02-2010, 12:27 AM   #38
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
I had Tein S.Tech springs and KYB-GR2 shocks on my S14. Came with the car, so no complaints there. It was better than stock for sure, but I wanted and needed coils so much more.
I have Tein Super Drift's now, its just so much better. They have great dampening adjustability and range for height. I had to pick up adjustable arms with it however. If you don't want to go cheap then I say get the tein coils. You wont regret it but make sure you do some research and see which ones are best for you.
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
Old 02-09-2010, 09:32 AM   #39
jay pee
jay pee's Avatar
jay pee is an unknown quantity at this point
If your on a budget n r just daily driving go ahead n put springs but if u got bigger plans the go coilivers... Can't go wrong there are plenty coilovers for good prices.
jay pee is offline   Reply With Quote
Old 02-09-2010, 11:06 AM   #40
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
Is it even a comparison, coilsover are going to do way better then strut spring combo, but it depends on your budget, coilovers will make your ride a little more harsh but you get used to it after a while...
Ceepo is offline   Reply With Quote
Old 02-09-2010, 11:47 AM   #41
jay pee
jay pee's Avatar
just get sum megan streets coilovers like 800 bucks new n u can find so used like 4-5 hundred bucks n they get the job done for a good price
Old 02-09-2010, 12:43 PM   #42
brunswick240
brunswick240 is making a name for him/her selfbrunswick240 is making a name for him/her self
Send a message via AIM to brunswick240
even if you dont want your ride "slammed" (which i dont know why you wouldnt...) you can still have a nice drop on coilovers with out modifications to the body (pull/roll/wire tuck). coilovers are going to be the next best thing to an engine swap, plus youre automatically cooler if you say you have coilovers than springs. let the honduh and mustang boys get springs we rock coilovers
brunswick240 is offline   Reply With Quote
Old 02-09-2010, 05:26 PM   #43
Caveit
Caveit's Avatar
Caveit is an unknown quantity at this point
My car came with lowering springs when I bought it and it still rides pretty nice and handles well. I'd still like to get coilovers so I can go lower, maximum performance, and so I can adjust them. It's a pretty obvious choice. I'd say stick it out for another few weeks and get coilovers instead, you'll be a lot more satisfied.
Caveit is offline   Reply With Quote
Old 03-15-2010, 10:16 PM   #44
JDMS13Louie
JDMS13Louie's Avatar
JDMS13Louie is an unknown quantity at this point
I'm gonna pick up a set of Tein S. Tech springs next week anyone have experience with these? My car is all stock except for the kakimoto exhaust and Exedy stage 1 clutch. oh btw it's a S13. I was a Honda guy and my friend convinced me to make the switch and I'm already loving my car. Any other info on where I could start would be great as well.
JDMS13Louie is offline   Reply With Quote
Old 03-15-2010, 10:19 PM   #45
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
A quality spring/strut combo will handle better, and ride nicer than a cheap coilover -- but it won't go 'very' low.
If you're looking for a nice cheap coilover, I suggest the Megan Racing Street series. Just remember to back off the preload, and you'll be good to go. I used the MR Streets for a year, and had 4 track days on them, without any major complaints. Great bargain coilover.
Old 03-15-2010, 10:24 PM   #46
codyace
codyace's Avatar
Trader Rating: (58)
Old 03-15-2010, 11:14 PM   #47
CNDC
CNDC is an unknown quantity at this point
^Agreed. Ive found that the valving in the damper or the shock is everything.
CNDC is offline   Reply With Quote
coilovers, lowering springs, s13 coilovers, s13 springs
