Old 02-04-2010, 12:40 AM   #1
alesserfate
alesserfate is an unknown quantity at this point
what material is the top (shiny part) of a tial wastegate made of ? fittings ?
The top part - it's aluminum isn't it ?
Is that round disk underneath it supposed to be a heatshield ?
There are two 10mm x 1.0 metric female's on top and on the side of the top aluminum part.
Considering this part will get relatively heated under extreme conditions, would aluminum fittings that will thread into the 10mm x 1.0 openings be good for use ?
I used the wastegate with steel banjo bolts and aluminum banjo's previously, but would like to get rid of the banjo in place for -AN.
I am asking this as I know you are not supposed to thread steel fittings into aluminum housings from previous experiences - where the steel expands more then aluminum when heated up and cracks the aluminum.
Input ? Aluminum fittings yes/no ?
alesserfate is offline   Reply With Quote
Old 02-04-2010, 12:43 AM   #2
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
it could be billet
jdm213 is offline   Reply With Quote
Old 02-04-2010, 01:50 AM   #3
juggernaut1
juggernaut1 is an unknown quantity at this point
I use AN fittings on mine.
juggernaut1 is offline   Reply With Quote
