Old 02-08-2010, 09:22 AM   #1
burninskulls0911
burninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enough
Need some quick help with MAF's
So i just put an rb25 in my s13. I had the harness professionally converted by Carisma.
well the car seems to break up pretty bad once i hit full boost and i putting tons of black smoke out the exhaust when it starts to break up, which leads me to believe that it is running rich.
well i ran the part number on the MAF (22620 05U00 A36-000 J70)
and it ended up being a stock MAF from an rb26dett
now my question is, will the fact that its an rb26 MAF cause it to be running like this?
the motor is all stock besides a FMIC and freddy intake manifold..
thanks for the help
Adam
burninskulls0911 is offline   Reply With Quote
Old 02-08-2010, 10:09 AM   #2
R33E8
R33E8 is an unknown quantity at this point
Have you performed a boost leak?
R33E8 is offline   Reply With Quote
Old 02-08-2010, 10:40 AM   #3
burninskulls0911
yep
not leaks at all
Old 02-08-2010, 03:03 PM   #4
Mosaic
Mosaic is an unknown quantity at this point
Full boost
U running rich only on fullboost? If the MAF hit its limit then you would run lean, not so?
More likely at full boost your plugs arn't igniting the compressed mix properly.
I'd say go for iridium plugs to increase your voltage per discharge area. You could also sharpen you platinmus and gap em down a bit to see.....but that wo't last very long b4 they get blunt again.
Mosaic is offline   Reply With Quote
Old 02-08-2010, 03:12 PM   #5
burninskulls0911
ive been messing with it all day
and you are correct.
the plugs were gaped to .045 which is wayy too big
so i regaped them back down to about .028..
im about to take it for a test drive..
Old 02-14-2010, 08:49 AM   #6
gigity
gigity is an unknown quantity at this point
The rb26dett maf is real weak I think they are only good for about 250 whp when single used fuck sr20 maf get ya better than that. Any way you look at it you should change maf.
gigity is offline   Reply With Quote
