Old 07-06-2006, 09:11 PM   #1
TEAMMiSCHiEFS14
TEAMMiSCHiEFS14 will become famous soon enoughTEAMMiSCHiEFS14 will become famous soon enoughTEAMMiSCHiEFS14 will become famous soon enough
s14 S14 JDM Kouki Turn Signal Mod
http://www.youtube.com/watch?v=kKJ8NApDTaQ
headlights - off
signal - on
turn signal bulb - on
sidemarker - on
http://www.youtube.com/watch?v=-Npv07_8nnc
headlights - on
signal - off
turn signal bulb - off
sidemarker - on
http://www.youtube.com/watch?v=ksQBrSVqAaM
headlights - on
signal - on
turn signal bulb - on/off alternating
sidemarker - on/off alternating
the write up..
1) OEM wire harness that comes with the JDM kouki turnal signal lenses
2) Cut off the female connector off the harness.. we will reuse the female connector to connect to the vehicle's sidemarker male connector
3) Connect the RED/BLACK wire from the female connector to the RED wire from the sidemarker bulb.. DO NOT connect the BLACK wire from the female connector, just tape it off as pictured
4) Connect the BLACK wire from the sidemarker bulb to the RED wire from the turn signal bulb
5) You can either splice the vehicle's turn signal connector as pictured or just cut off the connector completely
6) Connect the RED and BLACK wire union from the turn signal bulb from step 4 to the GREEN wire from the vehicle's turn signal connector.. Connect the BLACK wire from the turn signal bulb to the BLACK wire from the vehicle's turn signal connector
7) Tape off all your connections with electrical tape.. then plug the female connector from the lenses to the vehicle's sidemarker male connector.. now if you connect everything properly, your turn signals will work as the videos above
**TEAM MiSCHiEF Sacramento**
'98 Aspen White 240SX SE
'00 Super White Celica GT-S 6-Speed RIP 4/12/04
Best 1/4: 14.693 @ 93.476mph (Injen CAI)
TEAMMiSCHiEFS14 is offline   Reply With Quote
Old 07-06-2006, 10:50 PM   #2
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
I did something similar but used the top corner lamp to be a turn signal also instead of a constant on. Both the top corner lamp and the turn signal will turn on when signaling, but only the top corner lamp would remain off when the headlamps are on. I have a diagram of the relays if you're intrested.
mmdb is offline   Reply With Quote
Old 07-06-2006, 10:55 PM   #3
240mph
240mph's Avatar
240mph is making a name for him/her self240mph is making a name for him/her self
Send a message via AIM to 240mph Send a message via MSN to 240mph
Nice work.. I would like to try this mod out as well. Please do a write up thanks.
240mph is offline   Reply With Quote
Old 07-06-2006, 11:00 PM   #4
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
the oem way is for the signal to stay on and flash.
use the Green power from usdm sidemarker, then Red power from usdm signal.
driftingisgay.com
nrg is offline   Reply With Quote
Old 07-06-2006, 11:01 PM   #5
blk90s13
blk90s13 is an unknown quantity at this point
Send a message via AIM to blk90s13
write up .. please
Signature goes here
blk90s13 is offline   Reply With Quote
Old 07-07-2006, 05:35 AM   #6
g6civcx
g6civcx's Avatar
Those are very high-quality videos. Thank you for sharing them.
As for modifying the wiring, it's actually really easy if you don't stray too far away from the OEM setup. I put a lot of info in this thread. Check it out:
http://www.zilvia.net/f/showthread.p...=magic+flasher
Old 07-08-2006, 02:59 PM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
thats pretty cool...i like how you got the 2 bulbs to intermittently blink. i just wired the corner to the old stock sidemarkers and called it quits.
CLICK HERE!!!
Old 08-24-2006, 12:11 AM   #8
TEAMMiSCHiEFS14
sorry for the delay... the write up is up with pics!
Old 03-04-2007, 04:06 PM   #9
trust187
trust187 is making a name for him/her selftrust187 is making a name for him/her self
Send a message via AIM to trust187
the pics dont work anymore...anyone have the pics ? thanks
trust187 is offline   Reply With Quote
Old 03-04-2007, 11:30 PM   #10
grnappletree14
grnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfection
do u have a full write up lmk thanks
grnappletree14 is offline   Reply With Quote
Old 03-26-2007, 02:50 PM   #11
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
OLD thread from the dead, id be interested as well...
pbcstylez is offline   Reply With Quote
Old 03-26-2007, 05:39 PM   #12
projectRDM
projectRDM's Avatar
Did you guys even bother to read the first post? Seems like a good writeup to me, unless you were looking for it in Latin or something.
Old 09-06-2007, 09:22 PM   #13
TEAMMiSCHiEFS14
ok guys, I fixed the links to the pics, hope it helps!
Old 09-07-2007, 07:03 AM   #14
kouki24d
kouki24d is an unknown quantity at this point
nice write up, made it look easy.
kouki24d is offline   Reply With Quote
Old 11-25-2007, 07:57 PM   #15
SOCAL240
SOCAL240 has a spectacular aura aboutSOCAL240 has a spectacular aura aboutSOCAL240 has a spectacular aura aboutSOCAL240 has a spectacular aura aboutSOCAL240 has a spectacular aura aboutSOCAL240 has a spectacular aura about
does this work on the s13 with the jdm turn signals!!?? pleaes anyone???
SOCAL240 is offline   Reply With Quote
Old 11-25-2007, 08:10 PM   #16
SOCAL240
hello!!!
ghfhgfhgf
Old 11-25-2007, 09:43 PM   #17
g6civcx
g6civcx's Avatar
Now that I read the writeup again, I do not recommend this mod. You are backwashing current all the way back to the combination light switch.
When both the corner lamp and the turn signal are on, you have current collision, which is what causes the corner lamp to turn off when the signal turns on.
The best way is to connect both bulbs to turn signal. S14s already have a front side marker.
If you insist on doing this mod, please use a Magic Blinker. Never connect two wires with 12V(+) together like that.
Old 01-22-2008, 11:49 AM   #18
g6civcx
g6civcx's Avatar
Someone asked me the correct way to perform this mod. You will need this part: http://www.customled.com/PRODUCTS/MA...ic_blinker.htm
One blinker for each bulb you want to use for both parking and signal.
Tap the parking and signal wires and route them to the blinker. Hook up the bulb you want to the blinker and ground as indicated in the instructions.
Now the bulb may be used for both parking and signal. The bulb will stay lit with parking, and will flash any time the signal is activated.
This is a much safer way than the way outlined in the first post.
Old 01-22-2008, 02:11 PM   #19
idriveattz32
idriveattz32's Avatar
idriveattz32 will become famous soon enoughidriveattz32 will become famous soon enoughidriveattz32 will become famous soon enoughidriveattz32 will become famous soon enough
for those who dont want to use the JDM turn signal and would rather have the fixed and always on corner light be a blinker what would you guys recommend?
I was told its easy as cutting the corner light near the plug and tapping it into the harness for the turn signal and then running the turn signal bulb and plug into corner light housing...is this right?
Sold the Z, sold the S14, now I drive a G35 6MT coupe.
idriveattz32 is offline   Reply With Quote
Old 01-22-2008, 02:33 PM   #20
projectRDM
projectRDM's Avatar
There's two plugs on the light, and two on the car. One is a marker, one is a signal on the car. Wire them however you want, it's not that complicated.
FORMERLY R240NA
Old 01-22-2008, 04:37 PM   #21
g6civcx
g6civcx's Avatar
I assume you don't want the corner lamp to be used for parking any more, just signal.
The corner lamp harness has 2 wires: ground and parking light power. Follow the parking light power wire as far up the harness as you possibly can. It will tee off to the bumper lamp. Snip it at the tee and tape up the exposed connection of what's left of the tee.
Connect the loose wire to the turn signal wire. Hint: the bumper lamp has 3 wires: parking, turn, and ground. Track down the turn signal wire and connect the loose wire to this.
Repeat on the other side.
Old 10-26-2009, 10:01 AM   #22
Mistah Shotta
Mistah Shotta is an unknown quantity at this point
Can this work on a s13?
My turn signal harness color is red black and green..... I connected the red and green togetherand black 2 black and when i tried my turn signal the dash and the right turn signal blink..... so all i want to know if i connect the black and red together will it have an alternate turnsignal.?
Mistah Shotta is offline   Reply With Quote
Old 10-26-2009, 10:06 AM   #23
Mistah Shotta
could you fix the link for the pictures?
Old 02-09-2010, 11:32 PM   #24
DisFrikkenWill
DisFrikkenWill is a well-known jackass
need to fix picture links
DisFrikkenWill is offline   Reply With Quote
Old 02-10-2010, 12:04 AM   #25
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
if you read you will see that in March of '07 the pictures stopped working. one could assume that they have never been put back up since then, so you did a good job reviving a dead thread for no reason. if you actually read the steps you should be able to do it without the pics anyway.
Old 03-31-2015, 12:29 AM   #26
xorenadosuke
xorenadosuke is an unknown quantity at this point
So I noticed this thread through searching and saw that it was lacking in images. I did a few searches on google and found all the missing pieces.
Originally Posted by TEAMMiSCHiEFS14 View Post
https://www.youtube.com/watch?v=kKJ8NApDTaQ
headlights - off
signal - on
sidemarker - on
headlights - on
signal - off
sidemarker - on
headlights - on
signal - on
the write up..
xorenadosuke is offline   Reply With Quote
Old 06-05-2017, 04:49 PM   #27
sebkouki240
sebkouki240's Avatar
sebkouki240 is an unknown quantity at this point
Hi there!
Sorry to refresh that old thread but this is my situation now.. my turn signal and top corner lamp on my jdm front S14 got strange mods from the past owner and I want to put back to standard sequence... any help is appreciated!
mmdb do you have video ?
Nissan 240SX 1995 LHD - Kouki JDM front end conversion - SR20DET ϟ
sebkouki240 is offline   Reply With Quote
Old 06-05-2017, 06:19 PM   #28
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Updated OP with links and vids
Old 06-15-2017, 05:39 PM   #29
Bnr32gtr
Bnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enough
Just read all of this. Some one chimes in saying that this going to back feed issue in the long term affects would cause the combination switch to burn out and would need some kind of diode. Any one have proper way to wire up Jdm turns to usdm car? Thanks
Bnr32gtr is offline   Reply With Quote
