Old 02-15-2010, 12:51 PM   #1
pacificcoastautobody
pacificcoastautobody is an unknown quantity at this point
s14 BC stage 2 cam mod? and jwt sprockets
im doing a rebuild and setting up for turbo. i bought brian crower stage 2 cam shafts and they have slight modification i know you have to grind down the end of the intake shaft but is there any thing else i have to do and how do you recomend grinding the shaft.
next i have the jimwolf ajustable sprockets what do you guys think i should set them at? (ret. 2 deg?) im looking to only have about 300-350rwhp
pacificcoastautobody is offline   Reply With Quote
Old 02-15-2010, 01:47 PM   #2
iwannaslyde
iwannaslyde's Avatar
iwannaslyde is an unknown quantity at this point
im pretty noobish, but i didnt know you had to grind the ends of the cams??? thought they would just drop in...
iwannaslyde is offline   Reply With Quote
Old 02-15-2010, 01:59 PM   #3
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
They are made to be able to use on fwd ka's that require that extra piece to turn the distributor. Its easier to cut that off than to add it on.
My shoe is undesired
undesiredshoe is offline   Reply With Quote
Old 02-15-2010, 10:56 PM   #4
haha no you dont have to grind the ends , the intake side sticks out and i think i shave the valve cover
