Old 02-16-2010, 10:44 PM   #1
Mute
Mute is a well-known jackass
Rb25det powered 240sx drifting.com project car
If you're local to Southern California I'm in process of getting ready to sell the Drifting.com RB25DET Project drift car with standard RB25DET swap.
Car is an engine bay cleanup and big brake kit away from a photo spread in Import Tuner or Super Street.
CONTACT: ALI
[email protected] ONLY...I barely check in on forums.
Car located in Southern California.
Car available to be seen on Thursday/Friday nights only.
PRICE DROPPED Wanted : 12k OBO
Check it out:
Parts Included:
Suspension:
-Megan Racing Track Series Coilovers
-MR Rear Upper Control Arms
-MR Rear Lower Toe Arms
-MR Rear Lower Traction Rods
-MR Rack Ends
-MR Tie Rod Ends
-MR Front Pillow Tension Rods
-MR Aluminum Subframe Bushing Kit
Cage:
-L-CON Racecar Fabrications:
Custom 8pt SCCA spec Roll Cage
(tightest tolerances you will ever see)
Interior:
-SPARCO Pro-2000 seat (driver)
-SPARCO EVO seat (passenger)
-SPARCO 6 pt. Harness
-SPARCO 4 pt. Harness
-SPARCO 325 Deep Dish Steering Wheel
-Yashio Factory Pink Shift Knob
-Yashio Factory Pink Ebrake Release knob
-Yashio Factory Carbon Fiber Style Shift Boot with Pink Stitching
Exterior:
- URAS Front Bumper
- GP-Sports Side skirts
- GP sports Rear Bumper
- Front and Rear Wide Fenders (20 in front, 40 in rear)
- Seibon Carbon Fiber Hood
- JDM Corner Lights
- 180sx Tail Lights
- 180sx Rear quarter panel windows
- 4 - 17” Falken Hanabi Rims
- 4 - Falken Azenis 615 rubber (Brand New)
Transmission:
-RB25 Mission (needs new shift fork)
-SPEC Stage 3 Clutch
-Steel Braided Slave Cylinder Line - Sr20store.com
-The Driveshaft Shop 1 Piece Driveshaft
-Kaaz 2way LSD (installed by Kaaz for Drifting.com LSD install DVD)
Motor:
- R33 RB25DET Motor from R33 Front Clip (installed by Marco from SR20 Store and Gary from Project Car magazine and owner of Syko Performance for Drifting.com motor swap DVD)
- Syko Performance RB25 Converted Upper/Lower Harness
- Syko Performance Motor Conversion Mounts
- Syko Performance Transmission Brackets
- Syko Performance Sway Bar Brackets
- Syko Performance Intercooler Piping
- Large Intercooler Core - Meganracing.com
-Couplers And Clamps - Hosetechniques.com
-Power Steering Cooler - Sr20store.com
-Greddy RB25 Intake Manifold
-Gizzmo Thermal Intake Gasket Included
-Infiniti Q45 Throttle Body
-Apex-i Power Intake
-Flex-A-Lite Dual Radiator Fans
-Braille Auto Carbon Fiber Battery
-STOCK S14 Radiator
-Z32 Fuel Filter
-Twin Turbo Supra Fuel Pump
-S14 Throttle Cable
-5Zigen Exhaust System
-Rev On - powder coated Valve Cover
Electronics:
-A’pexi RB25 Power FC and (limited ed. gold D1 Apexi FC Commander)
-A’pexi AVC-R Boost Controller
-A’pexi DECS EL II Carbon Fiber (limited) Tachometer
-A’pexi EL II Series Guages (Boost, Oil temp/psi, Water temp, Fuel psi)
-A’pexi Auto-Timer
Bad (reason for lowered price):
-Transmission has an issue.
-Cracked driver side rear view mirror
-Cluster set up could be redone
-Power Steering leak from somewhere at the rack to hose connection.
If you have any questions as to how the car was put together you can buy the swap video from Drifting.com that documents each step. Also you can find my videos under "Drift Garage 1" on Youtube to see the installation of all the Apexi electronic components.
~ Ali
teamgoodink at yahoo.com
Mute is offline
Old 02-17-2010, 09:30 AM   #2
Mute
Additional info.
Sorry, missing a little info.
I think the car is a 91, gotta check the pink.
REGISTERED AS NON-OP . You take care of whatever you want to do in terms of the DMV. Car has been sitting for 2 years since the DVD was made and has seen a couple track days as it was supposed to be shot for Import Tuner so I never wanted to break her.
Car was tuned conservatively by Frank at Racetune
278WHP with around 258 torque (stock turbo, Q45 TB, stock MAF)
But she's quick, hard to explain but I can break traction just by turning in and stepping on the gas in 2nd-3rd gear with Falken FK452s, a little different story with the 615s.
~ Ali
Mute is offline
Old 02-17-2010, 09:54 AM   #3
lost240soul
lost240soul's Avatar
lost240soul is on the path to ruinlost240soul is on the path to ruinlost240soul is on the path to ruin
Bump for legit car.. the owner is a good friend of mine and ive seen this car in person and have rode shot gun in this car.. good car someone come up on this..
lost240soul is offline
Old 02-17-2010, 12:12 PM   #4
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
bump for this car.. i have driven it and its Retarded quick for being so little modified motorwise!
frank tuned it great and Ali has taken VERY good care of it..
Grenade180sx is offline
Old 02-17-2010, 06:19 PM   #5
limited240
limited240's Avatar
limited240 is an unknown quantity at this point
this car is sick. i like the paint job. glws.
limited240 is offline
Old 02-17-2010, 10:38 PM   #6
Smurf_240SX
Smurf_240SX's Avatar
Smurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choices
Send a message via AIM to Smurf_240SX
Seen and heard this car in person, clean car, Engine sounds really healthy and bad ass might I add...sad to see it go glws
FS OEM RB25 PARTS
Smurf_240SX is offline
Old 02-18-2010, 01:29 AM   #7
Gorilla Unit 33
Gorilla Unit 33 is an unknown quantity at this point
does 18k come with the long block?
Gorilla Unit 33 is offline
Old 02-18-2010, 06:33 AM   #8
GraphiteBrawler
GraphiteBrawler is an unknown quantity at this point
"(Possibly selling the built longblock later - 12k OBO for that (comes with some obligatory strings though, email me if interested))"
GraphiteBrawler is offline
Old 02-18-2010, 12:41 PM   #9
Mute
The car comes with the stock longblock that's in her. I have a second FULLY built longblock that was made for another DVD that I am willing to sell but has to go to someone that is going to get her going and willing to do a little video.
~ Ali
Mute is offline
Old 02-18-2010, 02:27 PM   #10
erik05v
erik05v is an unknown quantity at this point
ive seen and sat in the this car before its such a sick ass car...glws
erik05v is offline
Old 02-18-2010, 04:05 PM   #11
matt11145
matt11145 is an unknown quantity at this point
that car looks badass, GLWS
matt11145 is offline
Old 02-18-2010, 11:57 PM   #12
foreverdark
foreverdark's Avatar
foreverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfection
damn makes me want to keep my car satin black. GLWS really nice car and setup!
foreverdark is offline
Old 02-20-2010, 11:43 PM   #13
Mute
Thanks for the props...haven't really gotten much in terms of offers yet, if I don't get a decent offer i'll probably keep her. Surprised no one needs a car that's practically competition ready.
~ Ali
Mute is offline
Old 02-26-2010, 10:22 PM   #14
Mute
PRICE DROPPED TO 15k.
~ Ali
Mute is offline
Old 01-05-2011, 02:53 PM   #15
Mute
Price dropped...12k...get it the f out of my garage! Got offers? Throw em over...
~ Ali
Mute is offline
Old 01-05-2011, 08:15 PM   #16
ketchumcasey
ketchumcasey is an unknown quantity at this point
damn dude i would trade you my rb25det s14 but i know you wouldnt. glws man super clean ride.
GOD CREATED TURBO LAG TO GIVE V-8's A FIGHTING CHANCE...
ketchumcasey is offline
Old 01-05-2011, 08:29 PM   #17
WhipsGoneWild.net
WhipsGoneWild.net's Avatar
Trader Rating: (18)
WhipsGoneWild.net is an unknown quantity at this point
Feedback Score: 18 reviews
bump for rb
WhipsGoneWild.net is offline
Old 01-06-2011, 01:19 PM   #18
Mute
Seriously...if someone brings to the table a good offer I will be open to it...or maybe trade with $? Throw me ideas...
~ Ali
Mute is offline
Old 01-06-2011, 08:10 PM   #19
IwantAs13
IwantAs13's Avatar
IwantAs13 is an unknown quantity at this point
Looks really good
IwantAs13 is offline
Old 01-06-2011, 08:26 PM   #20
sucide_s13
sucide_s13 is an unknown quantity at this point
nice hatch......gwls
sucide_s13 is offline
Old 01-07-2011, 03:16 AM   #21
s13Yoon
s13Yoon is an unknown quantity at this point
sexxxxxxy. glws
s13Yoon is offline
Old 01-07-2011, 06:38 AM   #22
phatyonjoe
phatyonjoe is an unknown quantity at this point
wish you wernt so far away
phatyonjoe is offline
Old 01-07-2011, 06:46 AM   #23
speedracer5
speedracer5's Avatar
Trader Rating: (24)
speedracer5 is on the path to ruinspeedracer5 is on the path to ruin
Feedback Score: 24 reviews
wtf bump bump bump this car is six am i dreaming right now
speedracer5 is offline
Old 01-07-2011, 09:18 AM   #24
Mute
Thanks for the props guys. Would trade for a clean FD. Willing to move a bit on price...if you need a track ready car (auto-cross, drift, whatever) throw me an offer. Also willing to ship to anywhere in the United States.
~ Ali
Mute is offline
Old 01-07-2011, 11:15 AM   #25
turbojohnj
turbojohnj is an unknown quantity at this point
hey man i have a gorgeous kouki 98 100k on the chassis with 5k on a rb25det ne gt35r microtech methanol injection etc a really fast sexy car i get more attention in the s14 than my 800 hp mk4,,hahahaha i would like to trade but you would have to give the built longblock as well
turbojohnj is offline
Old 01-07-2011, 11:40 AM   #26
S14-SLIDER
S14-SLIDER's Avatar
S14-SLIDER is an unknown quantity at this point
dammm clean/sikk coupee
-N/A MIATA DAILY DRIVER
-93 Z32TT GT2530'S WEEKEND TRACK BEAST
S14-SLIDER is offline
Old 01-07-2011, 11:41 AM   #27
Mute
On trade offers...please attach photos and specs. Thanks.
TurboJ: Regarding the built longblock, I am throwing it away for 6k right now. Rather get cash for it.
~ Ali
Mute is offline
Old 01-07-2011, 11:53 AM   #28
Mute
Pending sale...
~ Ali
Mute is offline
Old 01-08-2011, 08:32 AM   #29
turbojohnj
hey man i posted my car on here that i told you about look it up through my name or search forum 98 kouki rb25 thanks
Old 01-08-2011, 09:06 AM   #30
slideslidegnarslide
Trader Rating: (29)
slideslidegnarslide is an unknown quantity at this point
Feedback Score: 29 reviews
saw you were in cali just kidding
slideslidegnarslide is offline
240sx, drift car, project sale, rb25det
