Old 02-18-2010, 03:09 PM   #1
cali-s14
cali-s14 is an unknown quantity at this point
ka24de rebuilt kit or sr
hey guys well my ka24 is acting up so im thinking of buying a rebuilt kit for it or doing a sr swap im kinda new to the s14 so i will like some of ur guys help an if any of u know what the best rebuilt kit is if thats the way to go thanks.
cali-s14 is offline   Reply With Quote
Old 02-18-2010, 03:35 PM   #2
slider2828
slider2828's Avatar
go to frsport or phase2motortrend or like whatever store that advertise... You can get pretty much all parts to rebuild the SR..... I am not sure for KA, but I am sure someone can chime in on that....
Turn and Burn!
Old 02-18-2010, 03:43 PM   #3
cali-s14
alrite thanks
Old 02-18-2010, 03:51 PM   #4
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Get a cheap re-build kit for the KA on ebay and do it yourself
you'd spend ~$500 - 600 and learn a bunch
before fucking up... errr.. I mean modifying an SR
Old 02-18-2010, 03:53 PM   #5
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
Rebuiding the Ka in OEM specs or building it for force induction is the real question here....
Swaping in a sr20 can be had for about 3-4 grand with bolt-ons...and both setups can reliable enough for daily driving provided good tuning.
S14Serge is offline   Reply With Quote
Old 02-18-2010, 03:53 PM   #6
enkei2k
Super Moderator
Trader Rating: (29)
enkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfection
Feedback Score: 29 reviews
Engine Rebuild - Head (KA24DE)
rebuild kit...is the way to go. keep it SR, smog legal, etc..etc...
Ask enkei2k
xquizitditz
enkei2k is offline   Reply With Quote
Old 02-18-2010, 07:43 PM   #7
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
yeah hes got a good point but only if you were to do it for oem spec, if you want to turbo it go to ams perfromance and get ther rebuild kits they different packages and are very good for turbo apps. But prepping it for forced induction cost $$:ghey:
ahh theres a way around that, but you wont worry with the ka with oem specs
jdm213 is offline   Reply With Quote
Old 02-18-2010, 07:57 PM   #8
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
where at in cali are u located?? heres a rough estimate of wut it would cost if u parted out the rebuild parts wich is wut i usauly do when i rebuild
-chrome rings- 80 buck at WE
-rod and main- bearings 100 bucks at WE
-Headgasket kit- 100 buck at autozone fel pro kit
-oil pump gear assembly, with front main seal-80 bucks from nissan
-tensioners,- 80 a piece from nissan
-head resurface and new valve seals put in-60
-get block re-honed
-couple cans of parts clean, some ultra grey silicone, and assembly lube,scotch brite,2000grit sand paper,
total comes out to about 550-650 in parts that are good and will last, not ebay shit.
just be sure u know wut u are doing, dbl check all ur clearences, and make sure everything is nice and clean before u put it together, and lube everything up
fcdrifter20 is offline   Reply With Quote
Old 02-18-2010, 08:16 PM   #9
jdm213
jdm213's Avatar
-get block re-honed
ebay doesent sell rebuild kits,do you see ebay brand pistons?? ebay is just a pathway to private sellers. the sellers are the ones that either sell good stuff or crappy stuff.what if someone sells something thats brand name shit for a good price??? Im sure youll take it so If I were you I would look every where to get a good deal
Old 02-19-2010, 11:19 PM   #10
cali-s14
so i should go with rebuilt the ka instead of doing the sr swap.
Old 02-20-2010, 12:13 AM   #11
M11's
M11's's Avatar
M11's is an unknown quantity at this point
hell yes a built ka you can get a gnar turbo set up and built engine for price of stock sr. check out jgs and jgy for ka engine and turbo parts.
WELCOME TO THE SHITTY WOK
M11's is offline   Reply With Quote
Old 02-20-2010, 03:53 AM   #12
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
No not really, I have an SR and a KA S14 kouki and building the ka is pretty expensive comes out to close to the same but the ka is more expensive also depends on what turbo you will use.
S13 curtis is offline   Reply With Quote
Old 02-20-2010, 06:48 PM   #13
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
to rebuild a KA Right, it will cost you about 500$ in machine work like i said this is to have it done right. I'm talking about
Do a Complete Valve Job (not just replacing seals)
Clean and Pressure Test the Head
Resurface head and Front Cover
Align Bore the cam holes
Inspect Cylinder walls for Uneven wear that they are still round
if your cylinder walls are OK you can get away with a Hone. if not you gotta Bore and Hone.
Inspect Crank for wear / even surface if so Micropolish the crank and new bearings
if unevely worn you gotta regrind the crank and get oversized Bearings
new oil pump, water pump, thermostat, etc etc. in some cases you want to get new rod bolts because sometimes they stretch but not all the time and you usually don't find that out untill you re assemble the Engine.
for a proper KA24 rebuild you are looking at about 800-900 in machine work and parts. but oh so worth it. it will outrun and outlast a "lightly" built KA24 like most of the people in this thread stated. if you are intrested in a real KA24 OEM or Performance Build contact me I'll point you on the right direction
Review Thread
bardabe is offline   Reply With Quote
Old 02-20-2010, 09:18 PM   #14
JorDash-s14
JorDash-s14's Avatar
JorDash-s14 is an unknown quantity at this point
ay if u wanna go sr hit me up i have a full redtop sr swap for sale. call me for more details (707)3634269 my names Jordan
JorDash-s14 is offline   Reply With Quote
Old 02-23-2010, 10:50 PM   #15
jonnybonds84
jonnybonds84's Avatar
jonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to all
That's a good kit there, I wish I would have seen it when I was rebuilding my KA. I had fun doing mine, you get really attached to the engine and you learn alot.
SPENCER DOUGHERTY RIP ME OFF. SEARCH HIS REVIEW THREAD.
jonnybonds84 is offline   Reply With Quote
Old 02-23-2010, 10:51 PM   #16
jonnybonds84
And......I just noticed you were banned.
