Old 10-14-2003, 02:34 AM   #1
texsilvia
texsilvia is an unknown quantity at this point
RB RB26DETT swap in....anyone else done this?
I have a chance to get an R32 front clip with low mileage and was thinking of doing the mother of all swaps in to an S13.
Things I know:
1) McKinney Motorsports makes a kit to allow the RB26dett to be installed into the 89-98 240's and keep the TT system if desired.
2) The propellor shaft that drives the front wheels will pass somewhere to the right of the transmission hump under (or possibly partly through) the passenger area.
3) The driveshaft will need to be shortened and will require a new larger yoke.
4) The tranny tunnel and paseenger floorpan will most likely need to be fab'd to accomodate the transfer case.
5) The front half-shafts will probably need to be shortened, and the skyline spindles and hubs, possibly the entire skyline front suspension used in place of the silvia parts.
What I don't know:
What is the position (front to back) of the front differential of the AWD skyline relative to the wheel centerline of a silvia? A few inches +/- from center is acceptable. A source of potential problems is the geometry of the front subframe on a silvia and whether or not it will interfere with the halfshafts. Is anyone familiar with the subframe layout of a silvia vs. that of an AWD skyline?
What else should I look for? The crossmember from an R32 will bolt in to the silvia w/o modification IF the motor is an RB25DET....is there a significant difference between the RB26DETT crossmember and the RB25DET crossmember? If not, this simplifies things greatly.
The rest of the swap seems straight forward, cooling, intercooler, ECU, exhaust, etc all seem relatively easy compared to the AWD challenge.
This project is in the rough planning stages, if the AWD system proves to be far far too complicated, and by that I mean fabricating frame components, we may go with the "proven to be easy" RB25DET.
-Texsilvia
texsilvia is offline   Reply With Quote
Old 10-14-2003, 09:48 AM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Talk to McKinney. They're good people, and have much more knowledge on RB motors than anyone I know.
-Jeff
Whatup?
Old 10-14-2003, 12:21 PM   #3
ruf
ruf's Avatar
ruf is an unknown quantity at this point
Half of the people on this board actually own a 240SX.
Half of those people actually work on their own car.
Half of those people wish they had a turbocharged engine.
Half of those people actually have one.
Half of those people actually have one that's running correctly.
Half of those people have a "JDM" engine swap.
Half of those people do not have an SR.
Half of those people have an RB.
Half of those people have an RB25.
The rest will be able to tell you everything you need to know.
ruf is offline   Reply With Quote
Old 10-14-2003, 04:31 PM   #4
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
13,862 total users on zilvia.
6931 own a 240sx
3465.5 actually work on their cars
1732.75 wish they had a turbocharged engine
866.375 have one
433.1875 have one running correctly
216.59375 have a JDM swap running correctly
108.2 do not have an SR
54.1 have an RB
27.05 have an RB25
So there should be around 27 people on the board that can help you.
edit, that doesn't take into acount RB20.
andrave is offline   Reply With Quote
Old 10-14-2003, 05:19 PM   #5
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
haha, lol
There are a few people who have done it. Most RB26DET, although I have seen 2 TTs. Loook on 240sxforums, there is a post on em.
Just search around, there is someone in Florida with an RB26, one in (or was) Wisconsin, prolly a couple in Cali. I think one in Ohio.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 10-14-2003, 06:07 PM   #6
tougebear
tougebear is an unknown quantity at this point
If you ever try to do this, one advice: oil filter relocation kit.
tougebear is offline   Reply With Quote
Old 10-14-2003, 06:21 PM   #7
ruf
ruf's Avatar
We should pare that down to active users. I think the number would be more accurate...
I was just joking with my friend about how accurate my BS joke probably is...
Old 10-15-2003, 02:35 AM   #8
texsilvia
Ok, I talked with McKinney and co. and they said, yes...it's doable, but I'd have to pretty much customize the front subframe for the silvia since the RB26DETT does not mount to the crossmember. I would also need to build a jig based on the skyline suspension and transfer the upper wishbone from the skyline to the silvia. No struts on the GTR. Not to mention various small issues like, lack of room in the passenger footwell due to the propellor shaft.
Thanks for pointing me in the right direction. Looks like the car is going to get an RB25DET instead. I'll have to put off my AWD ambitions for now.
If I get a wild hair I may bust out the ol' 4340 Chromoly tubing and and arc welder, and maybe start fabricating, in which case I'll post a step-by-step either here or on a dedicated webpage. I've built a few race-cars before, can't be that much different.
-Texsilvia
Old 10-15-2003, 02:40 AM   #9
texsilvia
By McKinney and comapny saying It's "doable"...
I mean they WON'T mess with it w/o wads and wads of cash. ($10k+)
It could be done with the proper dedication, skills, financing, and space available to build a suspension jig. And even then, it would be iffy at best.
Please don't call them saying that you heard they would or even could do it.
-Texsilvia
