#1591 |
![]() Join Date: Oct 2004
You know seriously idaho if I were to do it all over again. I wouldn't do an sr... LS1 and call it a day... On track especially when its hot SR's can't run 18PSI... it would over heat for sure... I eman I have 19 row setrab oil cool and all the cooling venting and bla bla bla... still its not great..... I dunno for fun on teh street SR for sure... for track, its gotta be LS1 or somethign that doesn't create so much heat.... you can ask WhiteGLX about that....
#1592 |
![]() Join Date: Jan 2008
i dont track my car though. just street and highways driving. ls1 is sickthe thought went through my head a couple times
bt i liek the sound of a 4cylinder turbo spooling
My Twin Scroll Gt30r Sr22det Build |
#1593 |
You dont need 18psi on track when 14psi will do just fine. There are a lot of people who track SR cars with no real issues. I also think the Pignose front bumper creates a huge cooling problem.
#1594 | |
Pignosed was gone a long long LOOOONG time ago.... ![]() Yes under panel and over panel is there too to direct air... Hoping a swirl pot will help.....
#1597 |
Since you're having heat issues and don't want to lower the boost I would suggest ceramic coating as your next option to keep temps down.
A guy I know runs track days at Sebring in the middle of summer here in Florida and doesn't have too much of an issue after he ceramic coated pretty much everything on the hot-side of the motor. He said the temps in the engine bay dropped by more than 20* You could also try running E85 since it keeps the combustion charge way cooler. |
#1598 |
i wish we had e85 here
#1600 |
what do you guys think about the t2 gt3071r. i am seeing if they have a .64 version versus the .86. the problem i noticed with my gt2871r .64 was back pressure cause my pistons to get screwed up on the exhaust side but they were stock pistons. seems like a gt30 wheel with housings about the same size as gt2871, will flow more making a little more top end, with about the same boost response.
make about 400 to the wheels on 92 octane, with a 2.2 liter and ported head on the exhaust side. and once the center housing got spooling even if it took a littler longer it will have more rotational momentum and inertia.
#1601 | |
![]() Join Date: Jun 2008
#1602 | |
if they made a bottom mount manifold that was externally gated i would like to see it. can you give me a link to it. yeah and i agree about the .86 being better after doing some more reading. i wouldnt mind full boost around 4200 becasue i will rev out to 8
#1603 | |
![]() ![]() ![]() ![]() I still havent had it mounted yet but it should be pretty fun once i get it running. especially since its running on ethanol. |
#1605 |
![]() Join Date: Mar 2006
Yeah, I too would be interested to see what difference the 3071 compressor housing and 0.76 exhaust housing have on the power/spool characteristics versus the typical and 0.64 housings.
Daily driven |
#1606 | |
i cant find that housing turbine housing? how much did that whole combo cost you. if some one bought the center section, they could combine them all for about the same price as a normal gt3071 seems
#1607 |
http://zilvia.net/f/tech-talk/230385...mm-wg-t2x.html found the link. i wonder if they will let you switch out when you order so you dont have to order both sections. i might have to call them tomorrow and ask.
#1608 |
CHRA - Garrett GT3071R-WG with 90 trim 56.5mm turbine wheel : atpturbo.com think i might pic up this center section, then peice it together. but ifs yours was originally a .64 a/r then it is the 84 trim, wonder waht difference the 90 trim would make
#1609 |
difference is the 56.5mm turbine vs the 60mm turbine
so i found this center section Garrett Turbo Replacement CHRA - GT3071R [CHRA-GT3071R] - $827.00 : Himni Racing, Turbocharger, Turbo, Garrett, Turbo Kit, GReddy, Mazda RX-7, HKS, Apexi, TiAL, TurboXS, TurboSmart, Flange, Turbonetics, Exhaust, Intercooler, ACT, Intake combine it with Special Turbine Housing T25-EWG-44 : atpturbo.comCompressor housing for GT3071R with 71mm 56 trim wheel - 4" Inlet and 2" outlet : atpturbo.com and you pay exactly the same price asa gt3071 t2 but have a better turbo, then add in a tubular maifold, and the turbo outlet that is divdied as if it was for an internal gated turbo, seems like it would keep flow better coming out of the turbine. i bet this set up full boost by 4000 rpm, and make a around 450 on pump gas
#1610 | |
#1611 |
and here you can buy the turbo for 1160 dollars. just select the correct options, i wonder if the 4 inch inlet really has any benifit over the 3. MAF to 3inch pipe, to 3 in inlet seems like would have the best flow. not to mention it would probably be cheaper.
Garrett GT3071R Ball Bearing Turbo (450 HP) [700382-3 , 700382] - $1,160.00 : Himni Racing, Turbocharger, Turbo, Garrett, Turbo Kit, GReddy, Mazda RX-7, HKS, Apexi, TiAL, TurboXS, TurboSmart, Flange, Turbonetics, Exhaust, Intercooler, ACT, Intake
#1612 | |||
![]() Join Date: Dec 2004
Trader Rating: (58)
On the compressor side, yes the 56 trim A/R. However let it be known that A/R changes on the compressor side typically make for less to zero difference in HP, assuming th rest is the same. Will it change a few aspects? Yes technically, but it won't effect spool up and that sort. It's really interesting to read about how little an A/R change on a compressor effects power...very unlike the turbine sections which can make large differences.
This is why when I run the dyno days, it's always give people uncorrected and STD numbers. It's amazing to see people running wild CF's to make pwoer, it's just not fair. Quote:
Correct. I run 12 and sometimes 16 when I wanna pass a higher power car that parks in the corners. No issues here after 4 years. Quote:
On paper it sounds like a fantastic idea, but as before, the biggest drawback has always been the turbine housing as the restriction. With a proper backside it may prove to be a 'hot setup'. For me, it was just easier to adapt a external gate onto the manifold than spend all the cash again hehe.
#1613 | |
Cody, I am NOT CERTAIN, but I think you might be off a little here on your explanation. From what I recall, the trim of the compressor wheel refers to the ratio of the area of the inducer to exducer. On the 2871R, the exducer is 71 mm, so all that can change with different trims is the inducer size of the wheel. But you were referring to "56 trim A/R" I may be wrong, but I think A/R of the housing is completely different than the trim of the wheel. And if you look on Garrett's website at the compressor map of the two different compressor wheel sizes: ![]() ![]() The 56 trim does flow a little bit more than the 52 trim, but the difference is small.
Daily driven |
#1614 |
i am trying to find something that will get me about the equivalent of 400 to the wheels with out running on the jagged edge of efficiency for the turbo but still have nice response.
while keeping it bottem mount for money savings
#1618 | |
Trader Rating: (58)
"Mirage Turbochargers" lol!
#1619 |
![]() Join Date: Sep 2005
figured i would put this issue in here because they are some smart ones posting here
so i drove my car home for the first time yesterday. let it sit in my garage and went to start it this morning...and it flooded like super style. pulled the plugs and they are soaked. so i cleaned em off, pulled the injector clips and turned the key. started up and ran for a sec, plugs the injectors back in and BAM, she starts and runs great. now, where i keep my car in my shop, its never under 60 degrees and it was at my house in my garage where it got to..i dont know 40ish last night. did the cold start cause this problem? |
#1620 |
Trader Rating: (58)
THat should be posted in general section, not here.
ps: that small temperature difference wouldn't make much of an issue in regard to the car flooding. check timing/coupler vacuum leaks and unsure your tune/ecu is correct.
