Old 10-19-2003, 11:45 AM   #1
whitey_mb
whitey_mb is an unknown quantity at this point
brake trouble - I'm desperate!
I've been having a recurring problem for months and nobody can figure out what is wrong. I have a non-abs s14 and my rear brakes are dragging like crazy. The Nissan dealership told me my calipers were bad, so I replaced them myself, which didn't help. I took the car to two seperate brake shops which both said the same thing as the dealership. They both replaced my rear calipers, and neither time made any differance.
I've tried disconnecting the handbrake cable, and both shops told me they could find no evidence of any sort of blockage in the lines. After I got it back from the second shop, my cousin wanted to look at everything so we took off the calipers again, and when we put everything back together, the brakes were fine! I drove around for about a week, and all of a sudden they locked up on the highway so badly that I couldn't even keep up with traffic. Later on, I started it up again and the brakes were fine. The problem seems intermittent. It's perfect one day and awful the next.
Sorry to go on so long about such a simple sounding problem, but I really am desperate. I can't afford to take it back to a shop, and I can't just keep buying pads once a week. Any ideas would be greatly appreciated!
whitey_mb is offline   Reply With Quote
Old 10-19-2003, 12:09 PM   #2
240Dave
240Dave's Avatar
240Dave is an unknown quantity at this point
Wow, only other thing I can think is your MC is bad. Not sure how this would be caused exactly but if your rear calipers are fine and your e-brake isn't causing troubles, the only other thing I can thing of would be the MC.
240Dave is offline   Reply With Quote
Old 10-19-2003, 05:06 PM   #3
whitey_mb
I kinda figured it might be something up front. Wouldn't the master cylinder affect all four wheels though? Could the proportioning valve be causing it? Is there any way to check them out?
Also, do they sell master cylinder rebuild kits or anything? I'm not that familiar with that stuff. Thanks
Old 10-19-2003, 05:46 PM   #4
240Dave
240Dave's Avatar
http://auto.howstuffworks.com/master-brake.htm
http://auto.howstuffworks.com/power-brake.htm
This may make it more clear...all I know about them I learned above.
Maybe go to a local autoparts store and ask them, they always give free advice if they can.
Old 10-19-2003, 05:59 PM   #5
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
If you can see it stick, then loosen a bleed screw. If your brake fluid gushes out and the caliper unbinds, you may have a collapsed hose. If you do not appreciate fluid squirting out and the caliper will not release, the caliper is sticking.
Replace or rebuild and you should be good to go. You should price watch though. I have seen rebuilt master cylinders that were very little more expensive than rebuild kits. Not typically true with calipers, it does nothurt to verify anyway on new, rebuilds and kits which are around.
zero.counter is offline   Reply With Quote
Old 10-19-2003, 09:32 PM   #6
mandoz85
mandoz85 will become famous soon enoughmandoz85 will become famous soon enoughmandoz85 will become famous soon enoughmandoz85 will become famous soon enough
I had the same problem as you, my back brakes would lock up. my problem was that the brake light switch that hits the pedal was screwed in to much and causing my brakes to be pushed in a little all the time. i could only drive about 10 min. and then my brakes would lock up.
mandoz85 is offline   Reply With Quote
Old 10-20-2003, 04:38 PM   #7
whitey_mb
Well I loosened a bleeder valve, and some brake fluid came out. I guess I have a collapsed line. What could have caused this and what can I do about it?
Old 10-20-2003, 10:35 PM   #8
the head
the head's Avatar
usualy line colapsing is in the hose (rubber section) of the brake line. Primarily caused by degradation of the rubber from age. if your car is lowered you might (although highly unlikely) have damaged your hardlines check them for dents and flat areas the length of the car. if the hose is colapsed you need to replace it with either a factory rubber hose or a braided steel hose depending on you budget and preference. Was there anything that was done to the car (modifications? sent to a shop?) that coincided with the beginning of the problem? that might give you a better idea of where to begin looking on the vehicle.
