Old 04-03-2010, 02:17 AM   #1
Jung2
Jung2 is an unknown quantity at this point
Nismo Subframe Bushing Install with PIC?
Base on my search I would need to remove two sleeves on the front side of the subframe. But after removing both. It seems like I would need to remove the third bushing? The nismo bushing seem like it just to tight. Please see pic attached. The first pic are the sleeves that I pulled out the second pic is the sleeve that is in question. Again thanks. I tried searching but no luck.
It's for 95 S14
Thanks
Jung2 is offline   Reply With Quote
Old 04-03-2010, 04:33 PM   #2
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
I have no experience with Nismo Bushings, but if you are swapping say PBM solid bushings, you need to cut the collar out.
There is a metal outer collar, rubber, then inner metal tube.
@#%k that burning non-sense guys do around here, saw-all around the bushing, dropping the center tube out, then saw-all the bushing collar, pound out with hammer. Takes like 30 minutes.
Just don't use a POS screw-driver.
Finished product -
Corbic is offline   Reply With Quote
Old 04-03-2010, 05:38 PM   #3
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
you still have a metal sleeve from the looks of it
you have to remove that too
use a hacksaw, to saw a slit
JRas is offline   Reply With Quote
