Old 02-07-2002, 09:51 PM   #1
Tricky1980
Tricky1980 is an unknown quantity at this point
Send a message via AIM to Tricky1980
ok, for basic (aggressive)daily driving and HOPEFULLY autocross eventually, if it ever comes near iowa, what would be the best setup some like apexi ws dampeners for like 899 or some koni yellows with eibach sportlines on a 95.  here in iowa we get snow(duh) so i was kinda hoping for something i could change the height on rather easily? do dampeners let you do that or am i just confused?
Tricky1980 is offline   Reply With Quote
Old 02-07-2002, 11:19 PM   #2
White240sx
White240sx is an unknown quantity at this point
Shocks/dampers are friction devices that turn the harmonic motion of a working spring into heat, which is dissipated into the chassis and atmosphere.
"coilovers" implies that the spring perch is adjustable via threaded shock body. This is intended so that you may adjust the weight balance at all four wheels so that you don't have extreme unbalance when you are throwing back and forth in turns and during extreme braking and accelerating.
Not to add too much confusion, but the stock suspension is also a coilover set up in that the spring rides around the strut.
All of this said the WS don't have dampening (ride) adjustment, ability to use aftermarket upper mounts, and there have been a few documented cases where they have failed.
I don't hear good things about the Koni’s (inserts) so I would advise to stay away from them.
You may want to look into other set-ups farther. The WS aren't really for hard-core track racers or autocrossers (lack of critical adjustment), and the Koni inserts are more of a pain then they are worth. Some KG/MM springs and HTS or GAB struts would make a pretty good racing set-up that would probably be tolerable driving over crappy roads (but will come in at a little over $1K, more with camber plates).
White240sx is offline   Reply With Quote
Old 02-08-2002, 04:02 PM   #3
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
Whitie's <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=';)'> got you mostly taken care of up there...
I'd add that for most autox chores, a good adjustable shock will do wonders. &nbsp;Actually, I've heard a lot of good about the Koni's performance, but personally, wouldn't get them b/c you must remove the rears to adjust (not that most peope would ever do that...). &nbsp;Ditto w/ the HTS. &nbsp;GABs (which are hard to find are the easiest adjusted, but get pricey). &nbsp;
A coilover set up (threaded shockbody and matched spring set) is overkill unless you are a serious autoxer or lapper. &nbsp;These have several drawbacks - too stiff, too low, what if you blow one?, etc. &nbsp;But, if you want all out performance and will sacrifice daily driving, they are the way to go. &nbsp;BTW: most coilovers can't be raised to stock heights anyway as they are more for corner weighting than road conditions, so that's not really an issue.
HippoSleek is offline   Reply With Quote
