almost stalling
hey whats up i have an s13 with a sr swap stock turbo, s15 injectors, r33 fuel pump, greddy intake manifold, apexi exhaust, blow off, hks intake and fmic, blitz sbc-id runnin 12 lbs of boost.I dont get on it much but when i do after i let of the throttle and put the clutch in the rpms drop fast, slows down around 1k then it drops down to like 300 and almost stalls and a few times it has so if anyone has had this problem or knows what it is or has any suggestions please let me know thanks
![]() Join Date: May 2002
judging by your parts list, im leaning more towards the Blow off valve...
but it wont hurt to change your fuel filter... and clean your air filter.... check your maf too... what kind of BOV do you have??
#5 | |
what years your ride and what do you have done to it |
Start with this; when you let off the gas at say 3000, 4000 or wherever, try not to hit the clutch right away. Let the rpm comes down under 2000 or even 1500 before you hit the clutch. Try this first. If you still have the problem, then there could be so many things and you can do the "search" to find the answers that you need.
Stp9154 has a good point... i did that and pressed the clutch when it hit like 1000rpm... didnt stall... try that out first...
if your BOV is the apexi twin chamber (www.apexi.com), adjust it... i have that running on my SR i have no idle problems and no stalling problems, and i dont run as rich... if this is what you have then you cant recirculate it... its an atmospheric BOV... and if its already adjusted, then its another problem...
