Old 05-27-2010, 07:39 AM   #1
CarlHoover
CarlHoover is an unknown quantity at this point
horrible cam problem.
the cars out of time and we were working on rotating the chain around two the two light links. well my friend didnt finish loosening up the other cam, so now one cam was loose and the the sprocket was spinning freely while we were bumping the ignition so only the exhaust side was rotating. how can i get the cams back in the right working order? the intakes first lobe is around 3 o clock. where should the exhaust's be?
CarlHoover is offline   Reply With Quote
Old 05-27-2010, 03:15 PM   #2
iROYAL
iROYAL's Avatar
iROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfectioniROYAL is close to perfection
First off, which motor are you working on?
iROYAL is offline   Reply With Quote
Old 05-27-2010, 08:14 PM   #3
CarlHoover
sorry, its an SR. but we put the motor back together, and tightened up the intake cam at 11 while the exhaust was at 1. once we got it timed right, we put it all back together, and now you can just hear the cams clicking when we try to start it. how can we figure out the exact location for the intake?
Old 05-28-2010, 05:38 AM   #4
bb4_96
bb4_96 is an unknown quantity at this point
You need to pull it apart and start again with motor at TDC. Don't try to mess around and find your way from half way through. There is a pin that holds the chain on the crank sprocket so pull the cam gears and the tensioner and start from there like you just put the head on.
bb4_96 is offline   Reply With Quote
Old 05-28-2010, 11:06 AM   #5
slider2828
slider2828's Avatar
There is an exact thread on this.... by option13 on this same page...
Mazworkx has a cam timing tool... look it up
Turn and Burn!
Old 06-01-2010, 09:40 AM   #6
CarlHoover
this isnt just getting the chain in time. the cams are out of whack and when trying to start the car you can just hear them click. do i start with both cams at 12 o clock and keep rotating till the two silver links line up and the pulley marks line up?
Old 06-01-2010, 12:30 PM   #7
slider2828
slider2828's Avatar
Just read the thread, but its a guessing game right now, seriously....
http://zilvia.net/f/tech-talk/324166-sr-problems-2.html
Turn and Burn!
Old 06-01-2010, 11:08 PM   #8
misfitsfreak81
misfitsfreak81's Avatar
misfitsfreak81 is an unknown quantity at this point
you should download the fsm and reset the cams in the exact way described there. the clicking you are hearing is probly the valves slamming into the piston tops due to improper time. start over now so you dont ruin your motor completely.
Mike
misfitsfreak81 is offline   Reply With Quote
