Old 06-06-2010, 11:38 AM   #1
Jay97240Sx
Jay97240Sx's Avatar
Jay97240Sx is an unknown quantity at this point
Send a message via Yahoo to Jay97240Sx
Installed new manifold now bonnet wont close !!!
Hi folks, i installed a peakboost manifold over the weekend, and now the turbo sits about an inch too high and the bonnet wont close, i have nismo motor and tranny mounts. Can anyone give any suggestions what i can do to fix this issue. Im running a master power 50 trim turbo on a ka24de engine.
Jay97240Sx is offline   Reply With Quote
Old 06-06-2010, 11:40 AM   #2
sliptones629
sliptones629's Avatar
sliptones629 is an unknown quantity at this point
get new motor mounts. Nismo's sit higher than stock. I put the on an everything hits. mani and hard lines, strut tower bar wont go back on and my downpipe is sitting against the floor
sliptones629 is offline   Reply With Quote
Old 06-06-2010, 11:50 AM   #3
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Look into driftfreaq's motor mounts.
I have a pair of them. Sit lower than Nismo motor mounts and doesn't let the oil pan hang below the crossmember.
Would definitely solve your clearance issue.
-Jspec-
Instagram/CrimsonRockett
Old 06-06-2010, 12:08 PM   #4
jspaeth
jspaeth's Avatar
How can it make the engine sit LOWER and also make the oil pan sit NOT AS LOW at the same time?
I am confused....
Daily driven
Old 06-06-2010, 12:14 PM   #5
CrimsonRockett
The Architect.
I am confused....
Nismo mounts raise the engine along with the oil pan. Past the crossmember.
driftfreaq's mounts sit lower than Nismo mounts and makes the oil pan sit pretty much "flush" with the crossmember.
Not difficult to understand.
-Jspec-
Old 06-06-2010, 02:30 PM   #6
sliptones629
I just ordered some from him right after my first post actually. Those or circuit sports. But I was hearing conflicting information. They lowered the center of gravity but sat just as high as Nismo's. I dont get it. Xsessive sells reworked brackets too that you could look into.
Old 06-06-2010, 02:34 PM   #7
Jay97240Sx
Jay97240Sx's Avatar
Thanx for the responses guys I'm gonna look into your recommendations, and do some calling around tomorrow.
Old 06-09-2010, 02:14 PM   #8
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
I think this problem is just the reality of building a car from a bunch of different mfg. Your task is to lower the turbo, so... change parts that encourage this result.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 06-09-2010, 03:28 PM   #9
Jay97240Sx
Jay97240Sx's Avatar
The problem was resolved today,i bought some circuit sport engine mounts then cut them down to drop the engine as low as possible. I have more than enough clearance now.
Old 06-09-2010, 05:32 PM   #10
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
those things are janky...i cant personally trust a mount, that has the rod going clear thru...
they always look like ur going to stress the rod and just warp the rubber...oppose to DF or nismo or OE mounts that put the weight on the actual rubber...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 06-09-2010, 08:23 PM   #11
Jay97240Sx
Jay97240Sx's Avatar
I understand what u are saying but in my case they were quickest solution. I had to take my nismo's off to use these which I wasnt happy about. Ill be researching a better solution in the next few weeks.
Old 06-09-2010, 08:58 PM   #12
Jay97240Sx
Jay97240Sx's Avatar
Just did alittle research on the driftfreaq mounts, they look almost exactly the same as the circuit sport mounts
Old 06-10-2010, 04:05 PM   #13
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
big difference is there not a straight thru rod design like the CS crap...
PSN
Old 06-10-2010, 06:39 PM   #14
sliptones629
Im glad I didnt get the CS ones. They said it lowered the motors center of gravity but sat just the same height as nismos. ???????????????????????????? ezactly
Old 06-10-2010, 08:09 PM   #15
Jay97240Sx
Jay97240Sx's Avatar
Yea they were only slightly lower than the nismo which puts them at just about stock height (they were advertised to be lower than stock), I had to cut alittle off to bring the motor down to the height I needed.
