Old 06-13-2010, 05:40 PM   #31
Triperformance
Triperformance is an unknown quantity at this point
Honestly just change your coolant mix to be more water based, coolant had a low freezing temp and a high boiling temp. For a daily driver you guys started off wrong. put actual coolant mix in it and let us know whats up.
Triperformance is offline   Reply With Quote
Old 06-13-2010, 06:20 PM   #32
S14_Kouki
S14_Kouki's Avatar
S14_Kouki can only hope to improve
Well it turned out to be a bad HG. thank u for the help everyone
S14_Kouki is offline   Reply With Quote
Old 06-13-2010, 06:29 PM   #33
Triperformance
Damn dude, sorry about your luck on that one. Hope all goes well.
Old 06-13-2010, 07:26 PM   #34
Om1kron
Om1kron's Avatar
Originally Posted by S14_Kouki View Post
What exactly can break?? From my understanding coolant is to prevent corrosion and prevent water from freezing in the engine.
You see that nasty water pump a few posts up missing it's fins, it could eventually cause it to seize and then the pump goes boom. I just recently fixed something like that one a toyota t100, it was so awesome. I really never thought something like that could happen in the cooling system. I guess it has to do with what anti freeze's purpose is..
I'm not a genius so scientifically I dunno what the fuck happened. All I know is I saw some shit explode and it was epic and there wasn't a piston or rod behind the part that blew up.
Wayne Edwards
https://om1kron.blogspot.com
Old 06-13-2010, 07:52 PM   #35
Triperformance
lol, T100 is pretty old dude. Toyota and water pumps is nothing new, consider every 60k miles to change one, which is why most people replace them during the swap cause the jdm engines can have up to that mileage.
Old 06-13-2010, 08:13 PM   #36
Slideways_Kiwi
Slideways_Kiwi is an unknown quantity at this point
Corrosion and water pumps don't mix.
Use inhibitor/antifreeze
Slideways_Kiwi is offline   Reply With Quote
Old 06-13-2010, 10:59 PM   #37
S14_Kouki
S14_Kouki's Avatar
Sounds fun lol. I guess antifreeze is a good thing. Lesson learned today....USE antifreeze.
Im not to worryed about the HG its not my car (cant see it from my house) lol. But on a real note. I have a extra HG sitting at my house im giving him and he's picking up some arp's also. It just sucks cause the guy that he bought the engine from said it has new rings and bearings. So that prob a lie. Atleast we found the prob.
Old 06-14-2010, 12:02 AM   #38
Om1kron
Om1kron's Avatar
Sounds like your typical rebuild (lets rebuilt the bottom end, not deck the head) and slap it together with a head gasket.
Wayne Edwards
Old 06-14-2010, 06:28 PM   #39
s14kdizz
s14kdizz is an unknown quantity at this point
the problem with it over flowing in the res would be air in the system but i found out by letting the car run longer that there was a little more then just air in the system
s14kdizz is offline   Reply With Quote
Old 06-23-2010, 11:43 AM   #40
BLKTOPSR20DET
BLKTOPSR20DET's Avatar
BLKTOPSR20DET is an unknown quantity at this point
the coolant lubes the seals and shit like that in the cooling system and it boils up at higher temps but its always better to mix coolant with water 50/50 mix and if you have a blown HG sometimes the motor oil doesn't get milky and sometimes when you do a compression test it dont show low compression it might just be a small hairline crack in your HG a friend of mine had the same problem or you just might still have air in your cooling system
BLKTOPSR20DET is offline   Reply With Quote
Old 06-23-2010, 12:44 PM   #41
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
Its all water. We r taking the head off so we will see if its a bad hg or cracked.
Water wetter+Distilled Water > Antifreeze
^ SoCal weather ofcourse...lol
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
