Old 07-02-2010, 08:42 PM   #31
R33E8
R33E8 is an unknown quantity at this point
You can probably find another automatic tranny on here for super cheap.. cheaper than doing a manual swap...
R33E8 is offline   Reply With Quote
Old 07-02-2010, 09:07 PM   #32
S14DB
AFC #1
S14DB's Avatar
Originally Posted by Bellanatrix View Post
1. Would it be cheaper to get a manual transmission installed instead of another automatic?
2. Any ideas as to why this might have happened after putting Lucas in transmission fluid?
Thanks for your input.
1)If you went to a Aam.. style transmission shop I'm sure it would be $1200+ for a new(rebuilt) automatic.
If you can find someone that has pulled their Auto to go manual you can probably get it for free-$100. Then it would just be the labor to remove and install.
Manuals cost less then automatics. Why you typically have to pay more for the option when you buy a new one. But used for our car the Manual is more desirable then Autos. You can get a swapped out auto for basically free but a Manual can run up to $250. Then you have to get the other parts for the swap(Flywheel, clutch, pedal, MC/SC, Driveshaft, bolts). This can run a lot depending where you get them from and new or used parts. But it will be probably half of a rebuilt auto.
Cheapest is to find someones Auto they pulled for a Manual swap. Then doing a manual sawp. Then getting a rebuilt auto.
2) Nissan Automatics need "Nissmatic" transmission fluid. Basically this is a ash-less Dextron. The key is ash-less. Most shelf stock dexron/mercon has some ash in it. This fouls the disks in the clutch packs and makes them slip on the plates. Running anything that is not ash-less shortens the life of the packs.
When he said the seals were leaking. Were you low on fluid?
I can see two things. Ether the packs were worn from all the miles and the contamination from the lucas killed it. But it was more a coup de grace then it being at fault. The transmission was on it's last legs.
Or your fluid was low or loaded with crap and running hot. The heat from summer finally killed it.
Ether way I think the transmission was beyond the point of the potential Lucas damage mattering.
Old 07-08-2010, 10:16 PM   #33
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
i have a friend who rebuilds transmissions. he gives me dealer prices which is alot cheaper than the average joes price. if you guys want to your KA tranny rebuilt, let me know whats wrong with it and ill get you a rough estimate. i had one with a bad 1st and 3rd synchro and he charged me $450. came back looking and feeling brand new.
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 07-09-2010, 12:20 AM   #34
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
does he do core exchanges?
upsdude is offline   Reply With Quote
Old 07-09-2010, 06:05 PM   #35
HAWAII
Trader Rating: (24)
HAWAII is an unknown quantity at this point
Feedback Score: 24 reviews
I paid 1400 to get the tranny of my pathfinder rebuilt, keep in mind that it was an auto and a 4x4, so getting the tranny out and in the car is a PITA, syncros are busted what ever springs are in there was eaten. Old owner never bothered changing the fluid for years. I am pretty sure a rebuilt 5 speed tranny would be 1000 less, even cheaper if you just bring them the tranny by itself.
HAWAII is offline   Reply With Quote
Old 07-10-2010, 04:22 PM   #36
besTint
Trader Rating: (81)
no core exchange. drop off, pick up.
