Old 07-13-2010, 02:10 PM   #1
lukesr20det
lukesr20det's Avatar
lukesr20det is an unknown quantity at this point
Hks actuator installation redtop sr20det
ok so i just bought a hks actuator for my redtop sr20det with a stock t25. All of the instructions are in japanize!! figures haha.
CAN ANYBODY HELP ME WITH THE INSTALLATION?
some kind of step by step installation guide would be much appreciated.
thanks everybody
lukesr20det is offline   Reply With Quote
Old 07-13-2010, 02:15 PM   #2
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
just search man, when i was researching them on here i found a couple threads that covered the install.
sidewaysil80 is offline   Reply With Quote
Old 07-13-2010, 04:39 PM   #3
!Zar!
!Zar!'s Avatar
Remove old one.
Install new one.
It isn't that hard. Just compare it to the stock one or a picture online if you are really having trouble.
After that, just adjust boost by making the rod longer/shorter.
Old 07-13-2010, 05:16 PM   #4
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
remove vacuum line
there are two bolts that hold the stock one on, and there is a C clip on the pin the rod goes on.
do not lose the c clip. they are very small and hard to find.
once you pull out the 2 bolts and the c clip the actuator comes off.
adjust the length of your HKS actuator to roughly the same length as stock. tighten the nuts properly locking them in place.
put the fucking thing on and put the 2 bolts back in.
and put the vacuum line back on
if you really need help pm me.
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 07-13-2010, 05:20 PM   #5
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Originally Posted by sr20detman View Post
remove vacuum line
DONE !
Old 07-13-2010, 05:21 PM   #6
jackal264
jackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud of
why would you want to put it back to stock length? either way, as short as possible will be max boost or ~14psi so you your t25 maybe your looking at 3/4 of a centimeter of threads showing to have 12psi all day long.
jackal264 is offline   Reply With Quote
Old 07-14-2010, 01:45 AM   #7
lukesr20det
hahaha good shit, thanks guys
Old 07-14-2010, 02:01 AM   #8
Slidin' Sam
Slidin' Sam's Avatar
Slidin' Sam is an unknown quantity at this point
You COULD post the directions online and I COULD translate them for you...or you COULD just do what everybody else has told you to. (not sure why I am writing "COULD" like this, lol)
Slidin' Sam is offline   Reply With Quote
Old 07-15-2010, 10:04 AM   #9
Mesarina
Mesarina's Avatar
Mesarina is an unknown quantity at this point
read the japanese direccions for boost, it has some lenghts and boost. something about 12psi = 140mm, it's easy to understand it if you dont want to be adjusting your wastegate to get desired boost...
Mesarina is offline   Reply With Quote
Old 07-21-2010, 05:32 PM   #10
lukesr20det
I installed it last night. it was a little bit harder than it sounds but only took about half an hour. Car feels incredible huge difference.
and i set it with about 3/4's of a centimeter of the thread showing and im running about 12.5 psi all day.
thanks again for all the help
Old 03-24-2013, 12:28 AM   #11
jerryscherry
jerryscherry is an unknown quantity at this point
sorry to reviving a old thread, but is it safe to run 12.5 lbs on a stock sr20det ecu without a tune/fmu etc.?
jerryscherry is offline   Reply With Quote
Old 03-24-2013, 05:13 PM   #12
Supergoji
Supergoji's Avatar
Supergoji is an unknown quantity at this point
Send a message via AIM to Supergoji
yes its is safe
sr20's stock run 11psi from factory
www.NYZC.net
Supergoji is offline   Reply With Quote
Old 03-24-2013, 05:52 PM   #13
jerryscherry
Originally Posted by Supergoji View Post
yes its is safe
oh i thought it was 7psi? least for s13 sr20
