Old 08-30-2010, 08:45 PM   #1
allntrlundrgrnd
allntrlundrgrnd's Avatar
Damaged Downpipe-Repairable?
I blew up the flex section of this megan downpipe months ago.
My question is: Can the flex section be repaired? Or can it just be cut out with a section welded in? I ask because If I get it fixed, I will have some of the vertical section cut out and rewelded as well because it sat so damn low on my car. I have a greddy dp on it now and exhaust STILL hits everything.
I'm debating having a muffler shop do this, so exhaust guru's please chime in!
pics for reference:
Old 08-30-2010, 09:01 PM   #2
BoostSlideWayz
BoostSlideWayz's Avatar
BoostSlideWayz is an unknown quantity at this point
Send a message via AIM to BoostSlideWayz Send a message via Yahoo to BoostSlideWayz
3" X 6" Stainless Steel Exhaust Muffler Flex Pipe: eBay Motors (item 270624572045 end time Sep-19-10 15:00:00 PDT)
1994 toyota supra...... n-a D=
1992 nissan 240sx KA24E-T fully Built =D
BoostSlideWayz is offline   Reply With Quote
Old 08-30-2010, 09:46 PM   #3
!Zar!
!Zar!'s Avatar
If your car is slapping it on the ground, there pretty much isn't any point to having a flex section in the first place.
Not unless you have it going vertical like the Powered By Max one.
Old 08-31-2010, 12:48 PM   #4
allntrlundrgrnd
Not really, just scraping. I'm not really worried about having a flex section, just an exhaust that doesn't hang so far under the frame rails.
Old 09-01-2010, 02:23 AM   #5
kalypso123
(ノಠ益ಠ)ノ彡
Id imagine the flex piece makes it sag more, why not slice it out and put in straight pipe.
Old 09-01-2010, 10:01 PM   #6
gearhead55
gearhead55's Avatar
I'm wondering about a flex pipe in the downpipe section too. Right now i have 3 inch piping with no flex pipe at all. My question is will scraping put pressure on the turbo or exhaust manifold and cause problems?
gearhead55 is offline   Reply With Quote
Old 09-02-2010, 09:10 AM   #7
jchrisw85
jchrisw85's Avatar
jchrisw85 is an unknown quantity at this point
i have the same downpipe but with a trust power extreme cat back. it used to scrape all over the place until i changed my exhaust bushings to polyurethane. they were super hard to put on lol
lmao or get higher profile tires.
jchrisw85 is offline   Reply With Quote
Old 09-02-2010, 09:26 AM   #8
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
Also interested in this...as I blew the flex pipe too. I would rather have the flex pipe in than a straight pipe.
I was thinking of just purchasing another dp w/ a flex pipe on it.
Maiku240sxS14 is offline   Reply With Quote
Old 09-02-2010, 09:30 AM   #9
jchrisw85
jchrisw85's Avatar
i had constant exhaust leaks coming from the downpipe and exhaust manifold. just bc the downipipe was scraping. 3 inch piping is lower than the frame rails.
my setup was tomei exhaust mani, greddy turbo elbow, t28, greddy downpipe, trust power extreme catback
every 6 months or so i would start to get an exhaust leak. i must have fixed it at least 4 times before i sold the old s13.
Old 09-02-2010, 09:59 AM   #10
s14l0v3r
Trader Rating: (25)
s14l0v3r is an unknown quantity at this point
Feedback Score: 25 reviews
Exactly what I did with mine, had an ebay dowpipe and it cracked right where the flex pipe started. Just remember if you go with this to add a little more pipe to compensate for the flex. Measured and cut the exact length of pipe and now exhaust is a little short =/
s14l0v3r is offline   Reply With Quote
Old 09-02-2010, 10:02 AM   #11
Tearlessj
Tearlessj's Avatar
I have a "xs power" down pipe. It sits way up in the frame rail and sometimes even hit the floor board on rough bumps.
Nagasaki Motors
Friends help you move. Real friends help you move bodies.
Tearlessj is offline   Reply With Quote
Old 09-03-2010, 12:28 AM   #12
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Yah, looking at that shot, looks like your exhaust hangers are letting it sag lower than its supposed to. Actually, are you using the hanger that hooks up to the transmission? If you're not, thats probably why it sags.
CLICK HERE!!!
