Old 09-05-2010, 07:33 PM   #1
JoHn E
JoHn E's Avatar
JoHn E is an unknown quantity at this point
car wont start, but starts when i disconnect and reconnect the battery
in the last month ive already ran into this problem about every few days where my car wont start.. but the weird thing is, once i disconnect my battery for few seconds and reconnect it, it starts fine. then maybe a day or two later it happens again and i have to disconnect the battery and reconnect it to get it started again
does this sound like a problem with my starter? my batterys only about 2 years old. is something draining my battery?
(the only thing i can think of is my car alarm, or my HIDs?)
heyyy
JoHn E is offline   Reply With Quote
Old 09-05-2010, 10:21 PM   #2
Dazzla
Dazzla is an unknown quantity at this point
I had the exact same problem and I thought it was my alarm too. It was simple as my battery terminal had a loose connection, even when I tightened it I could still wiggle it, but once I fixed that I haven't seen that issue since.
Dazzla is offline   Reply With Quote
Old 09-05-2010, 11:49 PM   #3
jspek
jspek is an unknown quantity at this point
Send a message via AIM to jspek
yea i had a loose connection to my ground wire and the car would run, turn it off, then it wouldnt do anything when i came back.
jspek is offline   Reply With Quote
Old 09-06-2010, 05:31 PM   #4
klits562
klits562 is an unknown quantity at this point
Taking off your terminals doesnt charge your battery so nothings draining it. Check the wires for the + - of your battery make sure they aren't corroded and then replace your terminals they're only 5 bucks.
klits562 is offline   Reply With Quote
