Old 09-08-2010, 08:19 PM   #1
95zenkisr20
95zenkisr20 is an unknown quantity at this point
SR20 REDTOP t28r upgraded..... making no power help please
so after getting my sr back in for the third time i upgraded my turbo to an oem s15 spec r turbo.. im using a greddy profec b spec II and my read out says im making 6 psi but the power just isnt there its slowww.. plugs are gaped to .030... i have checked for boost leaks and vacuum leaks there are none.... i am running a draw through setup but because the turbo sits a little bit different than the stock t25 so i cannot run the hose from the bov back into the intake because it dose not reach... so i blocked off the intake hole would this make that big of a difference in power loss??
any help is much appreciate
95zenkisr20 is offline   Reply With Quote
Old 09-08-2010, 08:47 PM   #2
shadowcorp
shadowcorp's Avatar
shadowcorp is an unknown quantity at this point
How slow, is it across the whole RPM band or is it just specific areas? Also if your matching the stock boost I think it's actually supposed to be 7 PSI, not that 1 PSI would really make a huge difference or anything.
shadowcorp is offline   Reply With Quote
Old 09-08-2010, 08:54 PM   #3
95zenkisr20
it has the power down low before the spool but when it starts to spool up at half throttle at its like its N/A and then it starts to just bog down.. my bov dosent go off when this happens
Old 09-08-2010, 09:10 PM   #4
shadowcorp
shadowcorp's Avatar
Sounds more like your car is freaking out because of the boost like loss of spark or to much fuel. You said third time about the engine, did you change any thing besides the turbo when you put it in? And I wouldn't worry about the BOV tube since any one that goes to a open air blocks that same pipe off.
Old 09-08-2010, 09:14 PM   #5
shadowcorp
shadowcorp's Avatar
Also do you have any way to verify that it's making the boost it says since if it wasn't really spooling it would probably feel just as bad
Old 09-08-2010, 09:14 PM   #6
95zenkisr20
yeah a while back i bent a valve a smeared a piston so my machine shop screwed up 3 times but yeah the turbo is the only upgrade
Old 09-08-2010, 09:16 PM   #7
shadowcorp
shadowcorp's Avatar
You've checked your compression and all to make sure they didn't fudge any thing on their end?
Old 09-08-2010, 09:20 PM   #8
95zenkisr20
yep the first thing i did was check the compression because 1 time they didnt mill my head.. and the 2ed time they didnt deck my block so when i got it back this last time that was the first thing i did when i got it running and i got 160 on all 4
Old 09-08-2010, 09:34 PM   #9
95zenkisr20
also i can hear it spool up but the only way for me to read boost is through the greddy boost controller
Old 09-08-2010, 09:55 PM   #10
Sileighty_85
Sileighty_85's Avatar
so your running a Stock BOV?
Stock BOV's stay open untill the turbo build boost
So the Stock BOV needs to be replace with an Aftermarket one or make the hose reach the Intake pipe
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-08-2010, 10:01 PM   #11
95zenkisr20
no i have a greddy type s
Old 09-08-2010, 10:46 PM   #12
airhead
airhead's Avatar
Trader Rating: (32)
airhead is making a name for him/her selfairhead is making a name for him/her selfairhead is making a name for him/her self
Feedback Score: 32 reviews
when you upgraded. Did you replace all your turbo gaskets? including the 7layer mani gasket? check for any leaks around the turbo manifold area. also did you tighten your mani to the block as the FSM says?
im having that problem right now with my car in the process of replacing all my gasket and putting on the OEM turbo manifold.
airhead is offline   Reply With Quote
Old 09-08-2010, 10:49 PM   #13
95zenkisr20
yes all gaskets have been replaced with new ones
Old 09-08-2010, 11:02 PM   #14
airhead
airhead's Avatar
Trader Rating: (32)
Did you tighten the mani to the block like how the fsm says?
you might need a aftermarket BOV.
are your vacuum lines connected right? like cold pipe to the B.C and wastegate?
Old 09-09-2010, 01:33 AM   #15
95zenkisr20
i have an aftermarket bov (greddy type s).. i will check vacuum lines again
Old 09-09-2010, 06:04 AM   #16
shadowcorp
shadowcorp's Avatar
Do you have a mechanical boost Gage that you can verify what the turbo is doing?
Old 09-09-2010, 09:13 AM   #17
slider2828
slider2828's Avatar
Take pictures of all your vacuum lines and turbo setup....
Otherwise its just going to be guessing and wasting your time and others.....
Take pictures of your intake and block offs, vaccum lines, bov, and boost controller setup. That will help us a lot.
Turn and Burn!
Old 09-09-2010, 09:14 AM   #18
airhead
airhead's Avatar
Trader Rating: (32)
try to recir. the BOV?
or tighten the bolt on that BOV to make it stiff it could be opening/leaking when you boost..
Old 09-09-2010, 09:55 AM   #19
shadowcorp
shadowcorp's Avatar
or tighten the bolt on that BOV to make it stiff it could be opening/leaking when you boost..[/QUOTE]
Yea it is possible that it's still reading boost but leaking it out before the intake
Old 09-09-2010, 05:49 PM   #20
95zenkisr20
i tighten the bov all the way and re circulated it still no power
Old 09-10-2010, 03:36 PM   #21
95zenkisr20
help pleasee
Old 09-10-2010, 05:03 PM   #22
PoorMans180SX
PoorMans180SX's Avatar
Hey man, I'm in Michigan. If you really can't get it figured out, you could drive it down here and I could take a look at it. I'm about an hour and a half away though.
Is it making any weird noises? Do you hear the turbo spool? Did you make sure the wastegate works properly?
Basically there can be a bunch of things wrong. Try and be as specific as you can.
Old 09-11-2010, 03:28 PM   #23
95zenkisr20
well dosent matter right now car blew up last night after only putting 200miles on the rebuilt motor.. took whole car to machine shop and told them to fix it
Old 09-11-2010, 03:31 PM   #24
airhead
airhead's Avatar
Trader Rating: (32)
motor blew? what do you think was the cause?
Old 09-11-2010, 03:52 PM   #25
95zenkisr20
i have no idea i had my whole long block assembled at a machine shop with arp head studs and mls head gasket.... blew a head gasket and motor started knocking after i lost about 5 quarts of oil in 45 min driving...put 5 quarts back in... good thing i was only 10min away from the machine shop so i limped the car at like 1am to the shop..... and called them this morning giving them hell (keep in mind i have had my motor their 3 times prior to this, this summer)
Old 12-05-2010, 11:00 PM   #26
imcunner
imcunner is an unknown quantity at this point
sounds like you need to find a better machine shop
imcunner is offline   Reply With Quote
Old 12-06-2010, 06:00 PM   #27
s14freak93901
s14freak93901's Avatar
s14freak93901 can only hope to improve
first off, find a better shop.
s14freak93901 is offline   Reply With Quote
