Old 09-12-2010, 09:41 PM   #1
iLL_sx
iLL_sx's Avatar
iLL_sx is an unknown quantity at this point
LSD vs VLSD vs SNOW
Got my s14 in the beginning of the summer but since I live in Chicago snow seasons coming but my car is running open diff witch brings my question what would be better in snow LSD or vlsd or would they equally perform the same and it's my DD! Hateing comments or helpful comments will be greatly appreciated thanks
iLL_sx is offline   Reply With Quote
Old 09-12-2010, 09:49 PM   #2
articdragon192
articdragon192's Avatar
First thing's first, a VLSD is a type of LSD.
With that out of the way, any LSD, either helical (or gear driven), clutch type, or viscous (VLSD) will be beneficial in the snow, as it will prevent any kind of pegleg action. Clutch type might be a little too aggressive, and will take some getting used to in the snow I would imagine. VLSDs are usually pretty worn already, meaning they don't lock as well anymore. So it may end up peg legging on you anyways. best bet IMO would be a helical diff.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 09-12-2010, 10:21 PM   #3
Sam_Well.13
Sam_Well.13 is an unknown quantity at this point
VLSD and rebuild it by re-shimming it with 2 shims instead of 1. cost $10
http://zilvia.net/f/s-chassis/200226...-j30-vlsd.html
Sam_Well.13 is offline   Reply With Quote
Old 09-12-2010, 10:44 PM   #4
iLL_sx
iLL_sx's Avatar
Thanks both of you real helpful reason I posted in the first place was because I seen this http://zilvia.net/f/sale-items/342015-6-bolt-vlsd.html a little while ago what do you guys think?
Old 09-12-2010, 10:48 PM   #5
articdragon192
Gotta have a proper working VLSD for that to work. And with shimming, say good by to the pinion an ring gear over time. Haha. But still, it's an option
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 09-12-2010, 10:55 PM   #6
slomar91
slomar91 is an unknown quantity at this point
Considering the huge price difference between a vlsd and a clutch type lsd unit, i would recommend a vlsd since your just going to use it for daily driving, unless you like changing your diff fluid every other oil change.
slomar91 is offline   Reply With Quote
Old 09-12-2010, 10:56 PM   #7
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Helical. Helical. Helical.
SochBAT is offline   Reply With Quote
Old 09-12-2010, 11:06 PM   #8
iLL_sx
iLL_sx's Avatar
Sorry for the stupid question but what the hell is a helical diff or what does helica mean?
Old 09-12-2010, 11:14 PM   #9
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
helical = hellllaaacooooooll
hold on...Let me google that for you
Originally Posted by punxva View Post
i gotta fever, and the only prescription is moar hood vents
SlideWell is offline   Reply With Quote
Old 09-12-2010, 11:15 PM   #10
S14DB
AFC #1
S14DB's Avatar
You are shimming the internals increasing the preload on the VSLD not the bearing shims that keep the ring centered.
As far as the OP's situation. Locking diff is not going to be enjoyable in the snow. Helical is going to be the best bet.
Old 09-12-2010, 11:18 PM   #11
iLL_sx
iLL_sx's Avatar
Lol that was funny but almost all the threads I read are talking bout witch is better for drifting either helical or clutch I'm not a drift just a student lol
Old 09-12-2010, 11:20 PM   #12
articdragon192
Pardon my assumption. disregard my "Later gears" statement, lol
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 09-12-2010, 11:27 PM   #13
S14DB
AFC #1
S14DB's Avatar
Sheesh, first result...
Limited slip differential - Wikipedia, the free encyclopedia
Old 09-13-2010, 12:48 AM   #14
buentellomma
buentellomma's Avatar
buentellomma is an unknown quantity at this point
i have both a vlsd and a tomei 2way clutch type i swap in from time to time and i enjoy the vlsd more for dd. the tomei is hard to drive in the rain and breaks traction while turning. its great for drifting but no so much for dd. i agree with these guys, get a helical if you can get ahold of one, or just stick with the vlsd
buentellomma is offline   Reply With Quote
Old 09-13-2010, 12:53 AM   #15
g00se
g00se's Avatar
g00se is an unknown quantity at this point
Helicals ( like say a S15 LSD ) will also act like an open diff if you hit a patch of ice or have one wheel in the air, I say go with the shimmed VLSD..
g00se is offline   Reply With Quote
