Old 09-20-2010, 02:37 PM   #2131
direktdrive
direktdrive's Avatar
direktdrive is an unknown quantity at this point
Originally Posted by Slammed95S14 View Post
Here's my daily. Spacers this week in the back.
bitch about it.
Damn! That's straight up gansta legit. Mega props to your DD! That's insanely low. I wish my DMAX coilovers could handle that height.
Michael Cabuco - Visual Development Artist
Michaelcabuco.com
direktdrive is offline   Reply With Quote
Old 09-20-2010, 04:09 PM   #2132
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
I'm on Powered By Max's.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 09-20-2010, 07:29 PM   #2133
hailandkill
hailandkill's Avatar
hailandkill is on the path to ruinhailandkill is on the path to ruin
weedm you want pics of my actual coilovers? or how my car sits with the coils?
hailandkill is offline   Reply With Quote
Old 09-20-2010, 08:05 PM   #2134
chiboy002
Originally Posted by ZX88 View Post
aluminum sub frames really dont like pavement contact.
ugh, i absolutely hate the look of over-photoshopped or poorly photoshopped or hazy pictures. It makes me rage
other than that, fucking nice
street dancer.
GLEAM
Old 09-20-2010, 08:08 PM   #2135
chiboy002
Originally Posted by ILoveMyRHS13 View Post
Stance owners are going to say Stance goes the lowest.
PBM owners are going to say PBM goes the lowest.
Fortune Auto owners are going to say PBM goes the lowest.
It's also all about what wheel/tire combo you run. But all 3 of them will go plenty low enough. I have PBMs and I've never had to remove collars.
out of the box, stances don't go low for fucking shit. i have 17's all around (with bubble tires :\ ) and i pulled 1 collar and AM STILL BARELY TUCKING TIRE
can't tighten spring perch either unless i want preload
i think its tiem to flip the bracket and pull another collar
street dancer.
GLEAM
Old 09-20-2010, 08:37 PM   #2136
Slikk Logic
Slikk Logic's Avatar
Slikk Logic is an unknown quantity at this point
s14 so low my tires rub frame on gravel
no success without excess
Slikk Logic is offline   Reply With Quote
Old 09-20-2010, 08:39 PM   #2137
nathanong87
nathanong87's Avatar
u must be doing something wrong.... i have 17s up front with max camber like -4 or something and if i put one collar underneath of the bracket (not flipped) i can get within like half an inch from the rim. and maintaining a slight preload (no droop)
natelife.tumblr.com
Old 09-20-2010, 09:02 PM   #2138
chiboy002
one collar underneath the bracket? please elaborate
also, wheel's aren't flush. Theyre like 1.5 inches sunk cause my works havent come back from getting fixed (never had a chance to put em on)
also, preload - i called stance and asked them what to set it as and they said nothing, just tighten by hand and then 1/4 turn. What does preload affect since i hear ppl adding it and shit
street dancer.
GLEAM
Old 09-20-2010, 09:39 PM   #2139
wh0aitznic0
You spin the top collar (spring perch) and spin it tighter and tighter therefore giving you more height adjustment for your bottom bracket to go higher.
Pros: Makes your car look sick
Cons: Makes your car ride like a go-kart
<3
Old 09-20-2010, 11:55 PM   #2140
Weedm
Weedm's Avatar
Weedm is an unknown quantity at this point
car sitting on coils please.
Weedm is offline   Reply With Quote
Old 09-21-2010, 03:14 AM   #2141
Tearlessj
Tearlessj's Avatar
Originally Posted by wh0aitznic0 View Post
Shut up. Fortune's don't go low unless you flip the bracket then that notched top bracket hole becomes useless. Gay.
Stance plus $40 shorter spring they sell/regular PBM go lowest. What other coilover have you seen can make the front fender touch the lip of a 17x9 +15 with a 215/40?
This is as low as Fortunes can go, flipped bracket and all.
They can't go as low as the others, but can definitely go low. 18's in the front.
Edit: I'm talking about the front, rear can drop forever.
Nagasaki Motors
Friends help you move. Real friends help you move bodies.
Tearlessj is offline   Reply With Quote
Old 09-21-2010, 04:26 PM   #2142
fckillerbee
fckillerbee's Avatar
in my sig is as low as my stance's will go in the rear...it's literally perfect for a s14. I just hope you don't have an exhaust....cause I had to take mine off just to drive the car.
no removing collars/ pre-load blah blah blah...just lowered the heigth...everything else is still set up for drift.
and just lowered the front last week....still have about half an inch before having to remove anything else....i'll take pictures and post them up later.
Old 09-21-2010, 04:30 PM   #2143
slidevertable
slidevertable is an unknown quantity at this point
stock height
slidevertable is offline   Reply With Quote
Old 09-21-2010, 04:49 PM   #2144
chiboy002
i indeed have an exhaust, its a straight though so no worries on that. but idk man, before i took my collar off, i wasn't any where near low enough. I think i need to buy those fucking "shortening springs" stance offers. Such bullshit, they should include it.
car already rides like go-kart, i enjoy the free massage.
i know how to adjust pre-load, i just wanted to know the effects it had other than go-kart ride quality (full dampening to stiffest)
street dancer.
GLEAM
Old 09-21-2010, 11:40 PM   #2145
joel.e.krueger
joel.e.krueger is an unknown quantity at this point
Originally Posted by ihatemygirl View Post
AN MY CAR IS ON GODSPEED COILOVERS AN ON 215/35 18X9.5 -5 OFFSET WITH THE HELP OF A 40MM SPACER AND NO!!! IT DOSE NOT RUB/SCRAP
JUST TO LET YALL KNOW
sorry to bring up old post. but damn. this car is just drawing me in. i can't help but love it...
joel.e.krueger is offline   Reply With Quote
Old 09-22-2010, 12:01 AM   #2146
the40sondec
the40sondec's Avatar
the40sondec is an unknown quantity at this point
my teg, ass phone pic
the40sondec is offline   Reply With Quote
Old 09-23-2010, 06:37 PM   #2147
ddf2006
ddf2006's Avatar
ddf2006 is an unknown quantity at this point
Not super low or aything, still runing helper springs all around and all collars.
GAB sport coilovers
ddf2006 is offline   Reply With Quote
Old 09-23-2010, 08:18 PM   #2148
2forty less
2forty less is an unknown quantity at this point
front lip was knocked off at a local drift event on sat and took the bumper extensions with it.
then today with the rain in my friends slippery neighborhood. the speedbumps were put in last week.
2forty less is offline   Reply With Quote
Old 09-23-2010, 08:41 PM   #2149
240bandwagon
240bandwagon is an unknown quantity at this point
Originally Posted by Weedm View Post
hailandkill, want to show me some pics of your megans will all collars removed? i'm getting tired of these megans. dislike the ride quality, they dont go all that low, but i got them for $400..
gaymaxxes
what wheels are those? i've seen them on a lot of S13s and i've heard they're cheap. they seem to fit well too.
240bandwagon is offline   Reply With Quote
Old 09-23-2010, 08:50 PM   #2150
2_slow_40
2_slow_40's Avatar
2_slow_40 is an unknown quantity at this point
^ It says right there under the picture...
They're 'gaymaxxes' BRO!!!
Duh...
2_slow_40 is offline   Reply With Quote
Old 09-23-2010, 09:28 PM   #2151
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
meh, i think it looks okay.
HS13KLS is offline   Reply With Quote
Old 09-23-2010, 10:10 PM   #2152
cemtoes
cemtoes's Avatar
cemtoes is an unknown quantity at this point
low. road dots murder my shit and i scrape frame.
I can't wait to have 18s so I can tuck some more tire and not have to worry about running my bumper over when it falls off due to roaddot carnage. The roads are so different here compared to ohio, everything is flat and fairly smooth but theres drainage lines for flooding on some streets so I have to plan my routes to avoid that nonsense. ohio = pothole central.
get chill.
cemtoes is offline   Reply With Quote
Old 09-23-2010, 10:22 PM   #2153
Weedm
Weedm's Avatar
Lol they're XXR 002's. if you must get them, BUY MINE duh. But seriously if you must get them, get the 16x8 +0 please. They used to be called sportmax, not xxr, therefore the name gaymax was given.
Old 09-24-2010, 04:49 AM   #2154
ayuaddict
ayuaddict's Avatar
Daily driven, also made it 400 miles to Long Beach and back.
Old 09-24-2010, 03:03 PM   #2155
fckillerbee
sway bar is an inch off the ground......but I can still make it up driveways!
also on the daily... and i'm in LA.
Old 09-24-2010, 05:00 PM   #2156
ayuaddict
ayuaddict's Avatar
LA has some shitty roads, I recently found out the hard way.
Old 09-24-2010, 05:02 PM   #2157
XxCAPTAINxX
XxCAPTAINxX's Avatar
XxCAPTAINxX is an unknown quantity at this point
i love this car so much.
XxCAPTAINxX is offline   Reply With Quote
Old 09-24-2010, 05:56 PM   #2158
cemtoes
cemtoes's Avatar
Indeed, I lost my bumper and destroyed a sideskirt. brb HUGE unmarked speed humps in the middle of the streets.
and damn you always droppin by threads and makin us all look inferior :P
get chill.
Old 09-24-2010, 06:12 PM   #2159
fckillerbee
yeah, you kinda have to have a planned route for work, food, and gas....any unknown road is forbidden until i drive it in the dodge. lol
ayu....curious...how DID you get your car that low? custom suspension?
Old 09-24-2010, 08:11 PM   #2160
g-via
g-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of light
lol
period car
shoulda put some rays on that sun
"I'm a rage-aholic, I just can't live with rage-ahol!!!"
g-via is offline   Reply With Quote
