Old 12-22-2003, 10:19 PM   #1
superhoss37
superhoss37 is an unknown quantity at this point
boost gauge not reading what it "should"
well i got my boost gauge finally hooked up tonight and my wastegate spring is set for .4 bar which im pretty sure is 5.6 psi roughly. when i go WOT on it, the boost gauge only reads like 3 psi at most( from what i can tell by glancing at it while driving). What do you guys think is wrong? a boost leak maybe? i dont hear any hisssing from my pipes or anything like that. Thanks!
when my car idles it reads 20 vacuum...is this a normal #?
superhoss37 is offline   Reply With Quote
Old 12-23-2003, 11:39 AM   #2
Evil S14
Evil S14 is an unknown quantity at this point
Send a message via AIM to Evil S14
the vacuum seems normal, usually 18-22 for a normal car. As for the boost issueits possile you have a pinhole leak, but this would also cause bad idle and running rich as a mofo, its also possible that the gauge is messed up or you kinked the air line going into the gauge
*image exceeds forum limit*
-Moderation
Evil S14 is offline   Reply With Quote
Old 12-23-2003, 07:25 PM   #3
superhoss37
well as far as i know, i just have a little leak on the #4 runner on the exhaust manifold. would this cause this kind of problem? oh, and yea, i have very bad idle problems sometimes
once the car is warmed up fairly good, it idles around 700rpm or so but sometimes it likes to fluctuate down to like 550rpm. out my tailpipe, ihave some liquid that drips out but im not too sure if it's gasoline.
Old 12-23-2003, 08:15 PM   #4
klattr1
klattr1's Avatar
klattr1 is on a distinguished road
a boost leak would cause a lower number than you expect
klattr1 is offline   Reply With Quote
Old 12-23-2003, 09:19 PM   #5
Evil S14
i say its a boost leak, take your dipstick out and see if your oil is really thin and smell like gas. if it does ur running rich as a mofo.
the small exhhaust leak shouldnt affect anything related to your boosting problems
chek all pipes for leaks, make sure all hoses are tight and pressure test the whole system
-Moderation
Old 12-23-2003, 10:36 PM   #6
uiuc240
uiuc240's Avatar
Where is the source for your boost gauge signal? If the wastgate spring is set to 5.6 psi, and the signal line for the gauge is all the way on the OTHER side of the intercooler by the throttle body (like most are), you could very easily see 2 psi of pressure drop (if you have a big IC and lots of piping).
True, this is not a good thing, but it's not out of the realm of possibility.
Build an Intake Pressure Tester if you want to find boost leaks.
Exhaust leaks will affect spool-up (it'll be slower), but won't affect the boost pressure.
20 in-Hg of vacuum is good.
Autometer gauge? They are notorious for reading about 1 psi low from the factory (all I've seen sit at the low end of the "0" box). You can adjust it with a little creativity and a small screwdriver...take the bulb out and probe around in the back until you figure it out...be careful though.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
Old 12-23-2003, 10:40 PM   #7
uiuc240
uiuc240's Avatar
Here is the website I was thinking of:
http://www.vfaq.com/mods/ICtester.html
Eric
2002 Mazda Protege5
