Old 10-04-2010, 05:39 PM   #1
Siberian Husky
Siberian Husky's Avatar
Siberian Husky is on a distinguished road
Fiberglass fenders. Pros Cons
Im looking into this silvia front conversion kit and it comes with fiberglass fenders. I can't see anything wrong with running fiberglass panels. They weigh less, they dont rust. Granted they are of course flimsier, but fiberglass these days holds up well to even fast speeds.
I tried searching, but nothing came up that satisfied by inquiry as to hop on this good front end deal or wait out for some sheet metal fenders.
I dont think I can accept "cheap" as an appropriate con, because I really could give a f*ck about another persons subjective opinion on value.
I'd like to keep this discussion about functionality and practicality.
Thanks
Siberian Husky is offline   Reply With Quote
Old 10-04-2010, 06:25 PM   #2
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Pros: none
Cons: everything. Unless its a really good brand its going to look like ass, nothing beats OEM metal.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 10-04-2010, 06:28 PM   #3
Csomme
Csomme is an unknown quantity at this point
unless you're going to run a larger front wheel, stick with Metal.
Csomme is offline   Reply With Quote
Old 10-04-2010, 06:34 PM   #4
drivens13
drivens13 is an unknown quantity at this point
ffiberglass any facking sunks.The parts never fit well and you are constantly repair the parts because those cheap fiberglass parts have no strength compared to metal ofcoarse.
drivens13 is offline   Reply With Quote
Old 10-04-2010, 06:38 PM   #5
living4surf
Trader Rating: (52)
living4surf is an unknown quantity at this point
Feedback Score: 52 reviews
Biggest con is fitment they will never fit as good as oem metal but the good thing is you can repair them if you crash
living4surf is offline   Reply With Quote
Old 10-04-2010, 07:46 PM   #6
C-unit
C-unit's Avatar
C-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to all
the cons are just bad fitment and will turn weavy eventually.
they are easily repairable, cheap, shit load of style to choose from.
C-unit is offline   Reply With Quote
Old 10-04-2010, 08:00 PM   #7
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
Originally Posted by singlecamslam View Post
Pros: none
tsk tsk
There are pros. Such as non-corrosive, lower density, easy fix(as was mentioned), very rigid when made correctly, resistant to high temperatures, and cheap compared to other fibers.
duffman1278 is offline   Reply With Quote
Old 10-04-2010, 08:11 PM   #8
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
There is only one con I can think of, and that's the damn ugly ass vents. Otherwise, as long as you buy quality ones, they should fit damn near OEM like. Most people don't even realize I have 20mm fiberglass fenders. I started with really good quality fenders, ChargeSpeed, then filled the fenders vents.
You can't even tell:
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 10-04-2010, 09:06 PM   #9
cheesyriceo4
cheesyriceo4 is an unknown quantity at this point
(Broadfield, that's a beautiful S13.)
Don't the higher quality(aka more expensive) fiber panels fit better than the cheap knock offs?( For example: Vertex)
I guess a con would be if you hit a pedestrian, they'd be filled with pieces of fiberglass.
cheesyriceo4 is offline   Reply With Quote
Old 10-04-2010, 09:44 PM   #10
Siberian Husky
the kit im lookin at has the vents in the fenders. look pretty homo yeah, but i think people exaggerate how badly they fit.
Old 10-04-2010, 10:13 PM   #11
sleep
sleep's Avatar
sleep is an unknown quantity at this point
Send a message via AIM to sleep
You get exactly what you pay for
California sucks. Get over yourself cali.
sleep is offline   Reply With Quote
Old 10-04-2010, 10:20 PM   #12
Bushido
Bushido's Avatar
oem metal all the way.
fiberglass fenders only if your wheels call for it.
Old 10-05-2010, 05:49 AM   #13
OBEEWON
OBEEWON's Avatar
Tires eat fiberglass for brunch. Portly friends lean on your car thinking it's metal, then craaack.
Old 10-05-2010, 06:00 AM   #14
theboy
theboy is an unknown quantity at this point
depends on the brand. I have origin 20mm fronts and they fit like shit at the gap between the door (1/4" wide gap). But that type of stuff can be fixed with a little bit of work. They are also flimsey, but im fixxing that by adding a couple layers to the inside in certain areas for added rigidity. Get the cheap ones then learn how to fiber glass and do body work. Then realize its a 240 so youll always be working on it no matter what.
theboy is offline   Reply With Quote
Old 10-05-2010, 06:01 AM   #15
CaptainVlad
CaptainVlad's Avatar
CaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really nice
Did he just say Vertex is lower quality... lol
CaptainVlad is offline   Reply With Quote
Old 10-05-2010, 12:38 PM   #16
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
You can't pull fiberglass fenders to make wheels fit.
Pulled metal fenders > Fiberglass.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 10-05-2010, 04:55 PM   #17
Broadfield
Broadfield's Avatar
No, it's not an exaggeration... most of them fit absolutely horrible. Some of them are so bad you can't even get them to bolt up at all.
There is only 3 brands that I would even think of buying as far as quality:
Vertex, ChargeSpeed and Super Made
My Portfolio
Please Share
Check Out My Builds
Old 10-05-2010, 05:13 PM   #18
fckillerbee
fckillerbee's Avatar
fyi..i'm running all knockoff fiberglass, as I tend to break shit while drifting, so spending money on something that will break soon isn't worth it.
the full kit i'm running was an ait uras style 4 replica.
when people say they fit like ass, they really do. if you don't know basic cutting and measuring, then your fucked. I spent two weekends getting the whole body kit to fit perfectly. which required cutting and bending, a few zipties, and some more fitting.
one of the fenders hit the door when I open it, so I made it a few mm wider, you really can't tell.
the rear, well, you fit the fenders to the rear. pinch, bow, pull, same shit, you can work fenders to fit. I have 30 mm, and needed over a 50mm pull, and no problem. Hardest part was aligning the car to what i wanted, and then riveted the fenders on. real simple.
as far as the body kit...front bumpers tend to fit perfect, sides are always cut and re-cut to fit, rear needed a little trim....but i saved what...over 1k, and it looks decent....looks great for drifting! lol....30 ft pictures.lol
p.s. the rear had some damage, so fenders hides that a little. if you look close enough, you can see the sides not fitting extremely well.
Old 10-05-2010, 05:38 PM   #19
jspecusa
jspecusa's Avatar
jspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfection
Send a message via AIM to jspecusa
Never get fiberglass fenders if you have OCD.
Only get it if you are building missiles.
A car is just a tool to perform a task, what's your car being use
for it the key to any build.
It's all about Optimal and Efficiency.
Nissan Japan: "road to happiness has many curves"
Jdmlivin: "Jdm is dead, the yen is crazy"
jspecusa is offline   Reply With Quote
Old 10-05-2010, 05:43 PM   #20
fckillerbee
^^^^ agreed, make a goal, and shoot for it. if you are driving, fenders will hid damage, easy to replace too. If you aren't, don't buy knockoff shit, buy legit, so that it looks great for the daily. You don't break shit driving to and from work, unless your an ignorant 16 year old.
Old 10-23-2010, 10:37 PM   #21
tims05
tims05 is an unknown quantity at this point
I just recently got some front fenders from Origin for my s14 zenki. The driverside fits like complete crap and not even close to being able to bolt on enless you brake off the lip that bolts to the fender rail and reglass it back on.
Passenger side is okay, few spots may end up with little crackin if i bolt it down.
I bought the Origin fenders because I heard they were okay/good quality but where they bolt to the car is complete disgrace. Not sure how a company can ship something out like that.
If you look at the pics im attaching you'll understand.
Ive contacted the company I ordered them thru, hope to hear from them on monday.
tims05 is offline   Reply With Quote
Old 10-23-2010, 11:15 PM   #22
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
If you want perfect fitment say NO to fiberglass. I tried the fiberglass conversion fenders for my s13.5 and it didn't turn out that great. Spent many hours just trying to make it not seem like so much fail...
Driver side wasn't too bad but the passenger side is a whole different story... And that was after many many hours of cutting/fitting/zip-tie'ing etc. I will be going OEM metal cut and weld when I have the funds.
Old 10-23-2010, 11:29 PM   #23
whitepony22
whitepony22 is an unknown quantity at this point
I just finished mocking up my S13 Silvia front with Origin fenders, and they fit decent at best. But for the amount of time/work involved with them.... I don't really see the value at this point.
I am surprised at how rigid they are with everything bolted up, but that is also my biggest concerns as I see simple chassis flex from a drive way or a pot hole or something cracking the hell out of them.
whitepony22 is offline   Reply With Quote
Old 10-23-2010, 11:45 PM   #24
chiboy002
hey hey hey. i drive cautiously because i don't wanna kill my vertex front...... and no, my mommy didn't pay for it
street dancer.
GLEAM
Old 10-25-2010, 05:17 AM   #25
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
yea, my buddy got some origin front fenders and they didnt fit very good. The worst part was the door to fender gap. It was huge.
slideways2004 is offline   Reply With Quote
Old 10-25-2010, 10:10 AM   #26
tougefactory
tougefactory's Avatar
tougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to all
Origin Fenders. Origin fullkit.
Performance Parts // Track Prep // Fabrication
**Follow us on Instagram @TFWorks
For all the latest TF★ news visit our blog!!
tougefactory is offline   Reply With Quote
Old 10-25-2010, 10:15 AM   #27
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
Originally Posted by duffman1278 View Post
tsk tsk
The non-corrosive is just stupid. Paint your shit and it won't rust.
Also a fiberglass body part will be cracked, smashed and broken long before a metal part has rotted away.
Corbic is offline   Reply With Quote
Old 10-25-2010, 10:24 AM   #28
Corbic
Corbic's Avatar
Even the missile theory sucks.
Sure on a 70's Muscle car it's brilliant, as the heavy steel cowls, fenders and hoods weigh hundereds of pounds.
There is nothing heavy with OEM fenders on a 240, the are made of tin foil.
Only reason to buy fiberglass is you to fucking lazy/cheap to properly work on the highly available OEM fenders.
Cut and Weld my friends.
Old 10-25-2010, 10:24 AM   #29
tougefactory
Fiberglass is stronger than metal, weight for weight. It is also stronger than metal at the same weight. Deosn't rust, doesn't dent, easy to repair.
I've installed Vertex, chargespeed,c-west, origin and they are all about the same. None of them will fit 100% perfect out of the box but if you're patient you can get them to fit good.
Old 10-25-2010, 10:43 AM   #30
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
I have B-magic fenders.. not the top quality but not the lowest either...
fitment was good except corner light part and you dont see wavy surface...
