Old 10-11-2010, 05:00 PM   #1
GoToast
GoToast is an unknown quantity at this point
Send a message via AIM to GoToast
s13 1993 240SX Coupe w/1JZ
Jakob(Jake) Martin
410-490-2969(Verizon)
Romancoke, MD 21666
1993 240SX Base Model Coupe.
KG4 "Yellowish Silver", 248k Miles on the chassis. About 80-90k Miles on 1JZ-GTE Twin Turbo Swap with r-154 transmission. Factory JZA70 ECU.
PM's will be answered as swiftly as possible but call/txt will receive much faster response.
No one is allowed to drive the vehicle unless you have payment with you. Ive seen enough friends have their cars ruined during "test" drives.
*I am considering trades. Preferably trade+cash from you, but I will look over any offer. A street bike plus cash would be best.
Please also read my last post.
If you view, please leave good remarks.
Blitz BOV
Uras Super Tie Rods
EMPI Rack Boots
DIFF Aluminum Steering Bushing
De-greasing of cross-member
5-speed conversion
Removed Sound Deadening from the rear half of the car
Removed Rear interior & seats(still have gray rear seats in garage)
Disabled the motors in the automatic seatbelts
Replaced Two calipers and fully bled all lines.
Replaced e-brake cable
JZA70 Fuel pump(equal to walbro255) & New gas tank gasket
Front Sump oil pan conversion
MD Legal 35% tint
SR20 Tach Swap
SunPro Coolant Gauge
Mishimoto Aluminum Radiator
New Nissan OEM Radiator feet grommets
Dual Electric Fans(~2500cfm)
NGK Iridium Spark Plugs (BKR6ED)
Toyota Factory VCG, Grommets, FIPG, Thermostat & Gasket
DriftMotion Power-steering & Water pump UnderDrive Aluminum Pulleys
2JZ Mechanical Water pump
Castrol Full Synthetic 5W-30 & 2JZ Wix Filter
Removed 1JZ Fuel Dampner
Deleted IACV
Relocated Battery(AGM 8AMU1R) & 2op Cable
Single piece 3-in steel driveshaft
Nismo Motor Mounts
ZeroLift Mount Brackets
JZA70 FMIC
APEXi GTspec Exhaust
Vibrant Performance High-flow 3-in Stainless Cat (~300cpi) Passed Maryland Emissions as of October.
Braided Stainless Clutch line
Replaced Tail Housing gasket on transmission
Circuit Sport Stiffened Poly Exhaust Hanger Bushings
Shift Linkage Extended
MarlinCrawler Urethane Shift bushings
AMSOil Synthetic Transmission oil
Manual Windows & Locks
Passed MD Emissions
Heat & A/C were removed(A/C compressor is still on the motor)
Body damage to Driver Rear Quarter(light still works normally)
Rust on the passenger rocker panel
No Front Sway Bar(removed due to oil pan clearance)
Replaced as many vacuum lines as possible
Speedometer doesn't currently work(Will before sold)
Currently on Dunlop DZ101's 205/55r15(>80% tread)
Open Differential
No leather shift trim
I put about 7.5k miles(largely highway/cruising) and 3 oil changes since the swap.
The car has been very reliable and very fast.
It has been to the drag strip twice and the best I could get was a 13.5@107 after 5 passes. On the highway the car is fun as well. Easy to merge on and can catch anyone. Ive easily scared a couple 600cc series bikes. Gas mileage is great for the power behind it. All on Factory boost. Clutch still grabs and feels very good. Sound is amazing. Quiet and low and grabs attention. Ive had many compliments on the car for its ability. And the way it sounds "just like a supra".
Rear tires were replaced after the swap. Im waiting on a pay check to replace the front tires.
There is the large majortiy of the rear of the car stripped. And I still have a set of grey cloth rear seats in my garage. As well as a few other misc interior and parts I can throw in.
As I stated above. The Power steering line does leak some, im working on replacing it. I usually top the reservoir off every two weeks give or take depending on how much I drive.
Damage to Driver Rear Quarter was done by a man driving a moving truck(I was parked and away from the car). Great candidate for rear over fenders and wont require much to get a light properly fitted.
I've simply run out of currency.
The car is my pride and joy. I have an absolute minimum price, but it is negotiable depending.
Car with throw-in's $5000
But I also have extra parts, I planned to put them on the car but don't have everything I need. This will be the package deal.
-Included with Package Deal:
JDM Nissan 180SX Steering Wheel
Red/Clear Coupe Tails
300ZX 30mm Front&Rear Calipers
Ichiba 5-lug rear hubs w/Nissan bearings
300ZX E-brake Cables and Assemblies
Spare rust-free Coupe Trunk Lid(Forest Green)
SPL Pillowball Tension Rods(newest version)
EnergySuspension Complete Polyurethane Bushing Kit(NIB)
A set of no-name four point harnesses(black)
Moog S14 Tierod Ends
DriftMotion FPR Kit with Aeromotive regulator and gauge
Set of white w/red stripe 18x8in Tenzo R's(5x114.3) w/Falken Ziex ZE912 225/40ZR18
Package deal $6900
The Tenzo R's and tires are possibly for sale to a friend, so it is possible they will not be included in the final sale.
If you have any issues with this thread, please dont fill up space.
I am only intrested in serious buyers and good comments.
More pictures can be added.
Faster the better because I hate the freezing weather.
GoToast is offline   Reply With Quote
Old 10-11-2010, 05:42 PM   #2
s13superstar
s13superstar's Avatar
s13superstar is an unknown quantity at this point
ultimate sleeper!!! free bump!
1994 240sx SE- SOLD
1983 Cressida - Factory 5spd.
s13superstar is offline   Reply With Quote
Old 10-11-2010, 05:53 PM   #3
seanforney
seanforney is an unknown quantity at this point
Hmmm, I might be interested in this monster!
seanforney is offline   Reply With Quote
Old 10-12-2010, 06:44 AM   #4
Deliverance
Deliverance is an unknown quantity at this point
this car rolls out!! bump!
Deliverance is offline   Reply With Quote
Old 10-12-2010, 08:29 AM   #5
enot767
enot767 is an unknown quantity at this point
vouch for jake,
awesome car for sure!
enot767 is offline   Reply With Quote
Old 10-12-2010, 10:41 PM   #6
teckjoel
teckjoel is an unknown quantity at this point
Send a message via AIM to teckjoel
i was there helping the swap take place, i have video of the first start up on my FB.
car is scary fast for what it is and fun as hell to ride in, it was faster than my stage 2 audi a6. (roughly 300whp)
another vouch for jake, good guy. i'd personally like to see you keep this car but what ever works.
good luck with sale man.
450hp audi a6, bmw 323iT wagon, bmw 325i, honda accord. all 4 doors
teckjoel is offline   Reply With Quote
Old 10-13-2010, 05:52 AM   #7
GoToast
Car is still for sale. Trades will be considered but I would prefer to sell. Once again if your interested/serious or have any questions, leave a reply or contact me personally. I'm trying to get a few more pictures and hopefully some video up to help promote the car. Don't be shy. Thank you.
Old 10-15-2010, 02:43 AM   #8
DMiller
DMiller has a spectacular aura aboutDMiller has a spectacular aura aboutDMiller has a spectacular aura aboutDMiller has a spectacular aura aboutDMiller has a spectacular aura aboutDMiller has a spectacular aura about
Vouch for the owner and the car both being legit! good luck on selling it!
DMiller is offline   Reply With Quote
Old 10-15-2010, 10:10 AM   #9
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
LOL why do all the s13's with 1J's always look like sleepers?? GLWS...
jdm2191 is offline   Reply With Quote
Old 10-15-2010, 12:28 PM   #10
GoToast
cause the swap isnt an easy or cheap process. lol
Old 10-16-2010, 04:29 PM   #11
hopefull
hopefull's Avatar
hopefull is an unknown quantity at this point
car is one hell of a sleeper good guy to BUMP!!!
hopefull is offline   Reply With Quote
Old 10-19-2010, 01:31 AM   #12
DMiller
thats the damn truth! (coming from someone who tried to piece a swap like this together and then sold everything because I ran out of money!)
someone buy this and throw a diff + coilovers on it and run with it please!
Old 10-21-2010, 03:52 PM   #13
GoToast
Thread has been updated.
If you don't want the wheels and tires, that's fine, I have a few interested.
Times can be arranged to see the car in person, but I would rather avoid driving long distances. Sorta the, you come this way, situation.
And if you have any questions or concerns, please ask in thread.
(btw, this was my last bump, lets see where it goes)
Old 11-07-2010, 12:57 PM   #14
GoToast
Price drop.
Car 4800.
With 'everything' 5600.
Still open to trades. None offered yet. Would prefer a bike plus cash, or an unmodified/lightly modified car.
Old 11-07-2010, 05:16 PM   #15
seanforney
Not an unmodified car but worth a try,
1998 Camaro LS1 6 Speed 72K Miles 19" Wheels 426WHP Very Nice!!!! - LS1TECH
Old 11-07-2010, 08:12 PM   #16
GoToast
Originally Posted by seanforney View Post
Sean, pm me any info you don't have posted on that link. Also if you have factory wheels and tires.
Old 11-08-2010, 10:08 AM   #17
itsguyguy
itsguyguy's Avatar
itsguyguy is an unknown quantity at this point
I believe the color is Champagne, not yellowish silver, lol.
itsguyguy is offline   Reply With Quote
Old 11-08-2010, 12:15 PM   #18
GoToast
"If you have any issues with this thread, please dont fill up space."
Definitely classified in the paint codes as "Yellowish Silver Metallic" and "Sandstone Beige Metallic" KG4.
Old 11-18-2010, 11:05 AM   #19
GoToast
$5500 or best offer for everything?
Old 11-22-2010, 12:34 PM   #20
jaymelz324
jaymelz324 is an unknown quantity at this point
i have 4800 in hand. pm me
jaymelz324 is offline   Reply With Quote
Old 11-22-2010, 01:42 PM   #21
Nick Nasty
Nick Nasty is an unknown quantity at this point
if you still have this when i get back from iraq (should be back about the 2nd week of december) , i might have to pick this up from you
Nick Nasty is offline   Reply With Quote
Old 11-23-2010, 08:50 AM   #22
Veltall
Veltall's Avatar
Veltall is an unknown quantity at this point
i love this...bump for you sir.
Veltall is offline   Reply With Quote
Old 12-01-2010, 05:37 AM   #23
GoToast
Put all the interior I have back in the car and have a shift boots on. Still missing leather trim.
Get this now before I take it down. Still open to hear any offers.
Old 12-14-2010, 01:56 PM   #24
zaquanh
zaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura about
hey trade for a sr s14?
zaquanh is offline   Reply With Quote
Old 12-14-2010, 07:43 PM   #25
whitefedorafilms
whitefedorafilms's Avatar
whitefedorafilms is an unknown quantity at this point
wow. yeah that is a sleeper. glws. this thing is a monster.
whitefedorafilms is offline   Reply With Quote
Old 12-15-2010, 06:11 AM   #26
GoToast
Send me info on it and I'll look it over.
Old 01-02-2011, 06:30 PM   #27
WanganNastyMachine
WanganNastyMachine is an unknown quantity at this point
Vouching for a good friend and a awesome swapped car.
WanganNastyMachine is offline   Reply With Quote
Old 01-05-2011, 07:11 PM   #28
GoToast
MODERATORS PLEASE CLOSE!!!
Car has been traded.
1jz, 240, 240sx, nissan, toyota
