Old 10-14-2010, 06:59 AM   #1
chucky norris
chucky norris's Avatar
chucky norris is an unknown quantity at this point
Send a message via AIM to chucky norris
tranny to engine torque specs sr
i need the tranny to engine torque specs for an sr20det
does anyone know the specs?
and please don't tell me to Google it when i already did and failed
"If you're not first ..... you're last"
Ricky Bobby
chucky norris is offline   Reply With Quote
Old 10-14-2010, 08:10 AM   #2
Sileighty_85
Sileighty_85's Avatar
You are talking about the bell housing bolts?
Its a German Torque Spec = "Good en Tight"
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-14-2010, 08:19 AM   #3
jspaeth
jspaeth's Avatar
^Agreed. Seriously though, my instincts say somewhere from 80-100 ft-lbs.
EDIT:
Just checked my FSM for you, and I was wrong.
The ones around the top "half" of the tranny are 51-59 ft-lbs. and the ones around the bottom "half" are actually only 22-29 ft-lbs.
The input shaft and tranny mount likely carry most of the load, so the primary function of those bolts is probably just to hold the tranny housing tight against the motor
Daily driven
