Old 10-24-2010, 02:37 PM   #1
idamaster
idamaster's Avatar
idamaster is an unknown quantity at this point
Brake lines in way of making downpipe
Ive come close to finishing up my build but my break lines touch my V-Band housing on the turbo. How can I find a way around this?
idamaster is offline   Reply With Quote
Old 10-24-2010, 02:59 PM   #2
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
Chase bays booster delete
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 10-24-2010, 03:14 PM   #3
xdumbxguyx
xdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to behold
rhd brake master move lines to other side
infinitwheels.com
pitgarage.net
xdumbxguyx is offline   Reply With Quote
Old 10-24-2010, 03:18 PM   #4
idamaster
idamaster's Avatar
Do they make long ass stainless steel lines that I can just replace the ones that are getting in the way?
Old 10-24-2010, 03:29 PM   #5
chiboy002
no but instead of doing all that bullshit, you can go to a hardware store/plumbing store and buy the right size hard lines, then bend your own
just a thought
street dancer.
GLEAM
Old 10-24-2010, 03:30 PM   #6
Slammed180
Good luck with that.
I tried using a LHD master on my 180. The strut tower is right against the master cylinder, which makes it impossible to connect the brakelines.
Blow me, bitches.
Old 10-24-2010, 04:19 PM   #7
idamaster
idamaster's Avatar
Well whats the fastest and easiest was to approach this. I don't want to have to have another "project" over just over a damn brake line.
Old 10-24-2010, 04:49 PM   #8
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Well whether you want it or not you have another project.
Your turbo placement sucks. It's way too close to the brake lines. Expect rapid brake fade. You need to make custom lines to clear the turbo and you need to make a heatshield to keep your fluid not boiling and your resovior not melted.
The brake line that you need is the rear line. Luckily it has a fitting on the passenger's side framerail by the bottom of the firewall where you can un-screw it. Take that section of hardline out and find someplace that can make a braided one for you. Make sure to let them know that you need a 90* fitting where it comes off the master. Unfortuanetly the bend is too close to the fitting for you to be able to bend the line that you have without kinking it...
Old 10-24-2010, 05:53 PM   #9
idamaster
idamaster's Avatar
I think I'm going to order a different manifold with the flange rotated. This ones flange is parallel to the motor. Would that work?
