Old 10-24-2010, 01:10 PM   #1
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
battery light stays on
96 s14
car started acting funny not reving under load.
car dies at stop light have to push it over.
change alternator - battery light still on
new battery- battery light still on
what could the problem be?
repda916 is offline
Old 10-24-2010, 01:15 PM   #2
Sileighty_85
Sileighty_85's Avatar
check all fuses
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Sileighty_85 is offline
Old 10-24-2010, 01:42 PM   #3
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
- check your alt fuse
- bad/loose ground
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline
Old 10-24-2010, 02:04 PM   #4
Rabboni
Rabboni is an unknown quantity at this point
Yea, do what the above people mentioned. Also, check for voltage drop across the wire that goes from the alternator to the battery.
Baling Wire-The Duct Tape Of Champions
Rabboni is offline
Old 10-24-2010, 02:52 PM   #5
repda916
fuses are good. grounds are good. happened randomly. never abuse the car.
repda916 is offline
Old 10-24-2010, 04:56 PM   #6
Om1kron
Om1kron's Avatar
sounds like your charging wire is corroded or has a break in it.
Wayne Edwards
https://om1kron.blogspot.com
Om1kron is offline
Old 10-24-2010, 05:33 PM   #7
yabeet
yabeet's Avatar
yabeet is an unknown quantity at this point
As a rule of thumb:
Voltage drop from the positive battery post to your alternator [@power outlet] should not be more than .3v
Voltage drop from the alternator housing/casing to your negative battery should not be more than .2v
.5 together is max allowable drop between the two.
Edit:
If you do have more v.d than max allowable then these guys are correct, high resistance is bigger v.d is corrosion or a break in the line. Corrosion most likely.
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’
Jeremy Clarkson on Automatics
yabeet is offline
Old 10-26-2010, 10:04 PM   #8
kingston
kingston is an unknown quantity at this point
Maybe it's karma for ripping people off.
kingston is offline
Old 10-26-2010, 11:36 PM   #9
Rabboni
Did you actually do the voltage drop test, or are you just assuming its good? Do the test and then get back to us.
Rabboni is offline
