![]() Up for sale is my 1989 Nissan 240sx coupe. I've owned it since October of 2006 and it's been through a lot of changes. When I originally bought it, it was a cream and charcoal two tone and it had the original front.
The reason I'm selling the car is because I can't afford to keep it and finish it. School is starting to get expensive and paying for school is a priority. The car drives great and has been well maintained. It's not in perfect condition but that's expected with a 20 year old car. It drives great, very quick, daily driven, never tracked. The motor was pulled from the car winter'09/spring '10 to upgrade parts, quick overhaul, paint engine bay, etc.We replaced just about every gasket possible without tearing the motor down. We replaced the AACV with a new OEM unit as well as all gaskets and seals for it. Also replaced the water pump, front and rear main seal, valve cover gasket, new coolant temp sensor(ecu one), factory 02 sensor, intake manifold gasket, collector gasket, exhaust gasket, turbo gaskets, clutch slave cylinder, and there might be a few more things I'm forgetting. Here is what has been done to the car: 1989 Nissan 240sx- coupe 5-speed 160K miles on chassis ~65k miles on motor ENGINE: Blacktop SR20DET Garrett GT2871R .64 turbo *ISIS V2 Tubular exhaust manifold *ISIS Turbo lines Circuit Sports Turbo Outlet New factory 02 sensor P2M GT oil drain kit Greddy downpipe Apex’i GT Spec exhaust Megan Racing test pipe Enjuku Racing pulley and belt kit Walboro 255lph fuel pump Circuit Sport Fuel Rail kit HKS 740cc injectors AEM fuel pressure regulator Circuit Sport “mini” catch can kit Enjuku Racing intake cone filter Speedlab custom intake Z32 MAF sensor Greddy Type-S blow off valve Greddy intercooler piping with Ebay intercooler core Circuit Sport brake master cylinder heat shield (not installed) Hose Techniques couplers and T-bolt clamps Koyo Radiator w/ Flex-a-lite 12” dual electric fans Samco hoses Circuit Sport overflow tank P2M Magnetic oil drain plug Greddy radiator cap Megan Racing Motor mounts Pro Fab 5mm plastic IM gasket SUSPENSION: KYB GR2 shocks Tein S-Tech Lowering Springs ELECTRONICS: Enthalpy tuned ECU (GT2871R/740cc/Z32/19psi/91octane) HKS EVC-S electronic boost controller Greddy turbo timer Alpine deck Prosport gauges (boost, wideband, oil pressure) JDM cluster DRIVETRAIN: ACT street disc clutch kit TODA lightened flywheel ARP Flywheel bolts Driveshaftshop 1 piece driveshaft B&M Short throw shifter VLSD Megan Racing Transmission mounts EXTERIOR: Silvia S13 front end conversion Triple Projector Headlights Graphite Gray paint Seibon Carbon fiber hood 20% tint(not even a year old) ![]() ![]() ![]() More: ![]() ![]() ![]() ![]() ![]() GOOD: Car is in good shape for being 21 years old. Paint is only about 3 years old. It could use a good waxing and buffing to look exceptional. It has a sunroof, power windows, locks and mirrors. I Just recently changed the brake pads (back in August). THE BAD: Someone backed into the front fender on the driver’s side. It’s not horrible but still noticeable. The windshield has a few rock chips in it. The cluster doesn’t light up. I’m not sure if it’s an electrical problem or a problem with the cluster. No A/C The car smokes under high boost, looks to be running rich. Interior could use some work. The carpet on the driver side is torn. The seats are worn too. Passenger side mirror fell off. I’m currently trying to replace it. Needs a new antenna or cover the hole I'm asking $7,200 OBO. I'm also accepting trades. I'm looking for a reliable 4 cylinder, AWD or RWD. Subaru's are a plus! If you guys have any questions the best way to reach me if via email. I check it all the time. But here are a few options as well: Cell: (575)-840-8200 Email: [email protected] Ask for Orlando Thanks guys. Last edited by Arby2Six; 11-20-2010 at 08:46 AM.. |
Tags |
greddy, gt2871r, hks, s13, sr20 |
