Old 11-28-2010, 06:51 PM   #1
Mk2Roo
Mk2Roo's Avatar
Mk2Roo is an unknown quantity at this point
s14 problems
i have a 95 s14 ka and i cant get a spark from her. i changed the cap and rotor and still no spark. the weird thing is when i turn the key to on the check engine light is gone, arnt all the lights supposed to show? i need some help here?
Mk2Roo is offline   Reply With Quote
Old 11-28-2010, 07:08 PM   #2
Noeyy323
Noeyy323 is an unknown quantity at this point
probably the battery?
i had the same problem, when i got my s14. thought it was the starter but it ended up being the battery
Noeyy323 is offline   Reply With Quote
Old 11-28-2010, 07:13 PM   #3
nismolvr
nismolvr's Avatar
nismolvr is an unknown quantity at this point
check the ECM fuse along with all Fuses , Battery connections also.
nismolvr is offline   Reply With Quote
Old 11-28-2010, 07:41 PM   #4
Mk2Roo
Mk2Roo's Avatar
it cranks fine and i checked all the fuses and there good, it just doesnt spark, b4 it wouldnt start i drovit it fine with the cel on and one day it wouldnt start now the cel is off when i try to start it. i tried to jump her and that didnt work. i changed the fuel filter and that didnt work. i think i need a new distriburtor
Old 11-28-2010, 07:47 PM   #5
BKangS14
BKangS14 is an unknown quantity at this point
does it make a sound when you turn the key?
BKangS14 is offline   Reply With Quote
Old 11-28-2010, 07:55 PM   #6
nismolvr
nismolvr's Avatar
Sounds like your not getting any power to computer ,check harness connection.
Old 12-04-2010, 12:32 AM   #7
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
it cranks fine and i checked all the fuses and there good, it just doesnt spark,.... i think i need a new distriburtor
So did you get it fixed?? If you did, what was the problem?? If you didn't, use the SEARCH function here on Zilvia & download a Factory Service Manual for your model year.
Use the FSM to verify that you are getting power to your Engine Control Unit. It's possible that the relay powering the ECU could have died. Or your Crank Angle Sensor is broken. Or you could have a bad ground wire above the Oxygen sensor. Nissan runs several ground wires to this connection point on your engine block, (Don't ask me how I learned this). Or you could be right...the distributor gave out...I doubt it...but it's possible.
Follow the troubleshooting guide in the FSM and you should be able to figure out what your problem is. If you can get your ECU working, then using the ECU to read your Diagnostic Trouble Codes...it should help you to figure out what your problem is.
Anyhow, hope this helps...
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 01-04-2011, 02:19 PM   #8
Noeyy323
just wondering if you have found what the problem was, cause my s14 started doing this, the engine light wont turn on including the others and it doesn't crank when i turn the key.
