Old 11-28-2010, 08:06 PM   #1
benarovi
benarovi is an unknown quantity at this point
SR So now my blow off valve isnt blowing off???
alright so i have my blow off valve teed off with the wastgate vaccum line and iv been using that ever sense i did the swap and no problems at all. i use the nipple next to the fpr vaccum nipple. then i put in my boost controller(teed off with same line with bov to wastegate) and thats when the bov started to not work. started to compressor surge but boost great and vaccum fine. so i took the boost controller out and now the bov still doesnt work. it doesnt blow off at all. I tightened the screw in and out and nothing changed. wtf can it be? it cant be the vaccum source cuz iv been using it no problems in the past. anybody who ahd the same problem as me can help me out or somehting before i decide to take it apart and lube it up.. lmk
benarovi is offline   Reply With Quote
Old 11-28-2010, 08:14 PM   #2
Tiny_T
Tiny_T's Avatar
Tiny_T is an unknown quantity at this point
what kinda bov? probably ebay junk
Tiny_T is offline   Reply With Quote
Old 11-28-2010, 08:17 PM   #3
benarovi
sorry forgot to mention hks ssqv no egay its nice and gold and legit lol
Old 11-29-2010, 01:28 AM   #4
Hawiann22
Hawiann22 is an unknown quantity at this point
Ughh so your running a single vacuum line from the waste gate to bov?
Hawiann22 is offline   Reply With Quote
Old 11-29-2010, 11:33 AM   #5
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
this shiuld of been posted in the tech talk thread..
but to throw in some input . your bov could be seized. i've never heard or seen this happen to an ssqv though.
take your bov off , spray the inside with some wd40, try to push the valve in as far as you can a few times and put the bov back on... just an idea
1992 240sx (RB20. 362whp@16psi)
eklips3 is offline   Reply With Quote
Old 11-30-2010, 11:22 AM   #6
benarovi
ok ill do that today. last nite i sprayed wd40 inside and pushed the thing back a couple times it didnt go back far but i did it about 3 4 times. still compressor surged...
Old 11-30-2010, 11:23 AM   #7
benarovi
yea i was doing it before and it worked no problems
Old 11-30-2010, 11:35 AM   #8
4-20sx
Trader Rating: (50)
4-20sx is an unknown quantity at this point
Feedback Score: 50 reviews
Send a message via AIM to 4-20sx
yea ur BOV coudl be seized. get a JGS =) thats what i got now
"get that nacho out of my face"
4-20sx is offline   Reply With Quote
Old 11-30-2010, 11:53 AM   #9
S14DB
AFC #1
S14DB's Avatar
The WG line is a Boost source in front of the throttle plate. It will never operate a BOV.
Old 11-30-2010, 12:28 PM   #10
tr0n9h
tr0n9h's Avatar
Trader Rating: (26)
tr0n9h is not welcome here anymoretr0n9h is not welcome here anymoretr0n9h is not welcome here anymoretr0n9h is not welcome here anymoretr0n9h is not welcome here anymoretr0n9h is not welcome here anymoretr0n9h is not welcome here anymoretr0n9h is not welcome here anymoretr0n9h is not welcome here anymoretr0n9h is not welcome here anymoretr0n9h is not welcome here anymore
Feedback Score: 26 reviews
Send a message via AIM to tr0n9h
tial is the way to go!
tr0n9h is offline   Reply With Quote
Old 12-01-2010, 12:19 AM   #11
Hawiann22
This is how it should be setup
Top left nipple on throttle body to Bov (boost gauge connected)
Right top is capped off if not using canister
Bottom nipple hooked to fpr
Nipple on Hotpipe hooked to Wastegate(MBC is hooked to this line)
I hope this helps at all...
to me it seems like your throwing the vacuum back into the bov causing it not to operate
Old 12-01-2010, 08:49 AM   #12
S14DB
AFC #1
S14DB's Avatar
Huh? BOVs need vacuum to operate.
They work on pressure differential. One side of the diagram/valve is on the charge pipe. The other side is the vacuum port which runs to the manifold side of the TB. When the TB is open the pressure on the port has pressure on it equal to the charge pressure. This with the light spring keeps the valve closed. When you let off the throttle the TB closes and vacuum is created in the intake manifold. Now there is Vacuum on the port side of the BOV. In push style BOVs this creates a pressure differential that allows the boost in the charge pipes to push open the valve an vent. In Pull styles it uses the vac to pull the valve open to allow boost pressure to vent.
Old 12-01-2010, 10:08 AM   #13
sil80d
sil80d is an unknown quantity at this point
Take it off plug the hole. Surge is sexy!
sil80d is offline   Reply With Quote
Old 12-01-2010, 02:49 PM   #14
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
pictures of how u have it hooked up
slow40sx is offline   Reply With Quote
Old 12-01-2010, 02:59 PM   #15
ROOSEY
ROOSEY is an unknown quantity at this point
i love surge
ROOSEY is offline   Reply With Quote
Old 12-02-2010, 08:04 AM   #16
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
this is WRONG.
Both top Nipples on T/B are Vaccum, they are behind the trottle plate, (inside the intake manifold)
The bottom nipple is boost, it is before the Trottle plate. Technically this nipple is the same as having one on the hot pipe.
To OP hook it up like this
Top nipple on T/B, there are 2 one goes to FPR, and FPR only Do NOT tee this line.
other one goes to BOV, you can Tee this line for Boost/vac gauge.
Bottom nipple can eithor be capped OR run to a W/G IF you dont have a nipple on hot pipe.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 12-08-2010, 09:44 PM   #17
benarovi
ok ill try that 2moro and let yall no whats up thanks for the help
Old 12-17-2010, 09:03 AM   #18
slim
slim's Avatar
slim is an unknown quantity at this point
had a 3rd gen hks ssqv do that same thing only it still opened a little, not enough to prevent surge but sound like the same prob. try a different bov.
slim is offline   Reply With Quote
