![]() Join Date: Aug 2009
Trader Rating: (43)
![]() Feedback Score: 43 reviews
s13 silvia triple projector low beams
what do i need to buy for this to all work out?
it has nothing... no bulb or adaptor for the bulb. is it hard to find? ![]() |
![]() Join Date: Dec 2006
What do you mean adapter?
looks like your just missing the Rubber weather boot The harness looks like it there just missing a wire (a red one) on the female plug
![]() Join Date: Jan 2008
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
not to jack you thread, but what beam is that? i installed mine and the middle one and fog are operrational, but the outer ones dont work i try to turn on hi beam and they still dont work so im assuming those are my hi's?
Sorry to thread jack, but i was wondering. I have the dual projectors, and i'm running 4300k hid's in them. I have the most horrible output ever, even after trying to adjust them. Is that just how the projectors are? what gives
yup all silvia headlights are shitty....Clear corners has a conversion kit that you can buy to make the light output correct.
#10 | ||
![]() Join Date: Dec 2007
Trader Rating: (68)
![]() Feedback Score: 68 reviews
all silvia light outputs suck dick.. Quote:
cheaper to go with tsx projectors.
Late Night Crew... #02 <3 Bought anything from me? Please leave me a review! ![]() http://zilvia.net/f/private-sellers/...meistah21.html |
Trader Rating: (43)
the female plug goes onto the low beams and the male plug connects to the light switch on your car.
middle light is high beam and the outter light is the low beam.. its all plug and play if everything is there.. but im missing the low beam so its not for me ![]() so if i buy HID's i dont have to worry about that adaptor? |
Trader Rating: (92)
so the middle lights are hi beam and the outer lights are the lows? wth, when i switch to normal head lights the middle lighs up, when i switch to hi the mid come off and nothing lights up so i thought my high were blown out ?
Outsides are Low's middles are High's
The Male & female plug together for the Low's and High's, Fog Lights use their own harness. I show in here how the plug should be wired up (there is a bonus wire up for the Q's Lights) http://zilvia.net/f/tech-talk/276805...l-wire-up.html
#15 | |
All S13 Silvia lights use the same config. (outside Low's, Middle's High) Low's ![]()
#16 |
Trader Rating: (43)
no my lights are right ha my high beams are middle.. hey if i replace Head Light Stalk switch would it fix my high beams cause only my passenger side light works when highs are on.. its been like that even when i had my pop up lights
#18 | |
I cant remember, My Silvia harness was Cut so that why I had to solder mine and made that write up, JIC someone else had this issue
#19 |
Trader Rating: (92)
i have a set of h4 bulbs ill plug it into the harness if my harness is legit, lo and hi should work fine if it does, then i guess its my silvia lights that are messed up
#23 | |
Its been awhile but i think its LB- H3C HB- H3 Fog- H3C
#25 |
That right, I forgot hes got K's Lights.
I got Q's so mine uses H3C
#30 |
Trader Rating: (92)
S13 Silvia Hid H1 Headlight Conversion With Pics - Boostcruising
dont know if the install is product specific but here you go |
