Old 12-23-2010, 04:25 PM   #1
TurboGoKart
TurboGoKart is an unknown quantity at this point
I need a gas tank. (also, Help w/fuel problem)
But I can't find one online anywhere?? Do they not sell these anymore? It's for an S13. Anyone know where to find one?
I was having issues with the pump not supplying enough fuel. Came to find out the fuel sock was FILTHY because the tank had a piss ton of surface rust in it. So I dropped it off the car, and wet sanded the whole inside of it, rinsed it out a ton etc etc etc. Put it all back together and thought it was good to go, but after about 20-25mins of driving the problem was back. Not getting near enough fuel and you can tell cause power is waaay down. Also, you can hear the fuel pump working harder and for some reason it idles a lot higher while moving?? I'm so confused at this point.
TurboGoKart is offline   Reply With Quote
Old 12-23-2010, 04:39 PM   #2
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
Maybe th pump is on its last breaths. Did you replace that filthy sock?
kojiki88 is offline   Reply With Quote
Old 12-23-2010, 05:11 PM   #3
chiboy002
I thought the fuel tank was plastic?
Anyways, ask nathanong - he bought one a while back if i remember correctly.
Try a junkyard?
street dancer.
GLEAM
Old 12-23-2010, 05:19 PM   #4
TurboGoKart
Fuel pump was brand new about 100miles ago. I cleaned the piss out of the sock so it was good to go.
S14 tanks are plastic. S13 tanks are metal.
Old 12-23-2010, 07:54 PM   #5
kojiki88
kojiki88's Avatar
Alright. If you want to buy it new heres the link, I bought mine from there. As far as I know Junk Yards punch a hole at the bottom of the tank to drain the gas.
Genuine Nissan Parts - Factory Nissan Parts - OEM Nissan Parts - Cheap Nissan Parts
Old 12-23-2010, 08:50 PM   #6
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
i bought my new tank from
172 Fuel Tank :: Fuel & Engine Control :: Genuine Nissan Parts :: 240SX Parts (S13) 1989-1994 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 12-23-2010, 09:28 PM   #7
TurboGoKart
I think I'm going to replace the fuel filter/pressure regulator first. I noticed something else weird. When you key the car on, and the pump primes, the pressure jumps up to where it should be, holds a couple seconds, then drops right back to zero. I'm guessing somethings wrong with that lol.
Old 01-01-2011, 10:38 PM   #8
RoyalFortune
RoyalFortune's Avatar
RoyalFortune is an unknown quantity at this point
I ordered a metal tank from FRsport.com
RoyalFortune is offline   Reply With Quote
