Old 01-02-2011, 03:50 AM   #1
bvr463
bvr463 is an unknown quantity at this point
I need Help
I need your guys suggestions on what could be wrong with my car, i have a 95 s14 with a rb25det inside... heres the issue, when the car goes into boost its suppters real bad, car is in boost but doesn't go anywhere, wideband shows the numbers its suppose to be at... Heres what im guessing it could be
coils,spark plugs(changed them but not to sure what the exact gap suppsoe to be) fuel pump, or maybe the way they wired car up before i bought it..
Please Help Me if you guys have any idea what it could be
thank you
ryan
bvr463 is offline   Reply With Quote
Old 01-02-2011, 07:10 PM   #2
bvr463
bump to the top
Old 01-02-2011, 07:25 PM   #3
nismoman
nismoman is an unknown quantity at this point
I would start by checking the coils. Inspect them visually and check the impedance
nismoman is offline   Reply With Quote
Old 01-02-2011, 07:30 PM   #4
240sxrb25
240sxrb25 is an unknown quantity at this point
If fuel pump quits it will go lean. I bet its the plugs. When my plugs were not gapped properly this happened and the wideband looked correct...
240sxrb25 is offline   Reply With Quote
Old 01-03-2011, 02:06 AM   #5
bvr463
i just changed plugs about month ago, but cant remember what i gapped them at, what is the right gapping for a stock rb25det?
for the coils when measuring for impedance, what am i looknig for from what range to what range? Should i electrical tape or liquid tape the coils?
thanks
ryan
Old 01-03-2011, 03:23 PM   #6
st280
st280's Avatar
st280 is an unknown quantity at this point
Send a message via AIM to st280
I'm guessing coils, SAME thing happened to me like a week ago on my Sr... I just got new ones and swapped it out. All was good.
st280 is offline   Reply With Quote
Old 01-04-2011, 12:21 AM   #7
bvr463
thank you, i will try clean mines first and tape umm up and see what they do, if not i will order new ones and try them out
Old 01-05-2011, 01:19 PM   #8
bvr463
Okay regapped plus to .80 and cleaned and taped up coils and still the same, goes into boost, but don't go anywhere :-(
Old 01-05-2011, 01:20 PM   #9
bvr463
Some one pleaseeeeee help meeee, my beast runs like a teard
Old 01-05-2011, 03:46 PM   #10
nismoman
have you checked your timing?
Old 01-05-2011, 04:02 PM   #11
Sileighty_85
Sileighty_85's Avatar
wow .80
try .026-.028 inch
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-05-2011, 05:44 PM   #12
bvr463
Okay I will, isn't .026 or .028 to small of a gap and spark
Old 01-05-2011, 07:18 PM   #13
nismoman
Maybe he was measuring in millimeters .80mm is .031"
Old 01-05-2011, 08:27 PM   #14
Sileighty_85
Nope, that about what I run on mine
Thats still too big, its probably blowing out spark
後輪駆動車1番
1986 SR86 - 200ish
Old 01-05-2011, 10:09 PM   #15
bvr463
yes i meant in milimeters, sorry for the mix up... i have ngk bkr7e plugs inside, gonig to try to different things, try gap them to .026-.028 and try back to where the original plugs were gapped at 1.1mm. I will let you know what happens.
thank you for guys help, im hoping this will solve it
let you know
Old 01-06-2011, 10:46 AM   #16
bvr463
Took car for a ride on 1.1mm gap, car runs good. Feels like there is a little power still missing, any other suggestions?
Thanks for ur help
Old 01-06-2011, 12:16 PM   #17
Face Man
Face Man is an unknown quantity at this point
Have you checked to see if you have a boost leak anywhere. I had a car that was doing the same thing and I tried everything in the end I found an intercooler pipe with a pin hole rubbed in it.
Face Man is offline   Reply With Quote
Old 01-06-2011, 01:05 PM   #18
bvr463
I'll go make a boost leak tester next week and let u know
