![]() Join Date: Apr 2003
Bad Idle...not the AIV...any ideas?
Hey guys, i just recently removed my AIV and it doesnt die as much when starting and the revs feel better, but the idle is still low...i figured maybe it was just the idle now...but when I press on the brake it drops a few hundred, and when I lift off its at a nice 700-750rpms. Any ideas? Alternator and battery were tested at Autozone, fuel filter was replaced a bit ago, new spark plugs/wires...whats wrong!! =)
-Galen
"Wherever You Go, There You Are." ![]() |
#2 | |
![]() Join Date: Apr 2002
Eric
2002 Mazda Protege5 1989 S13 w/SR20DET (sold) |
![]() Join Date: Jul 2003
Clean your MAF, I had a similar problem....also be sure to check for Vacuum leaks....I would also reccomend checking your Cap/Rotor. Hopefully some of this might help.
#5 | |
-Galen
![]() Join Date: Dec 2002
Also dont know if you have already checked but, make sure you check your timing cause my idle was off alot and it was just the timing.
dang, I think that's what it is...i have some major timing chain rattle when I rev...time for a new timing system!
-Galen
![]() Join Date: Jan 2003
![]() ![]() Feedback Score: 8 reviews
yah, i 'd say check timing, what i did for this was cut a hole in a old cap at the number 1 plug position so i could make sure the rotor was there, then watched for the timing mark on the pulley. another thins to check is you idle air valve, on your intake tube there is a bigger hose that comes off near the valve cover hose, the hose goes back to a little control vlave, i ve heard that it can stick, but yah try cleaning maf, try celaning your water temp sensor, it seems the water temp sensor has lots of problems, and try cleaning your throttle body, i removed my egr and aiv and i had to clean my idle air valve to make it run right, also if u have a vacum leak you ll ahve higher rpms.
1990 hatch ka24de gt2871r |
#12 | |
-Galen
