Old 01-23-2004, 02:42 PM   #1
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
Turbo Kit pricing
I'm researching prices for a turbo kit for my SOHC. I found this on realnissan.com
how does this compare to other turbo kits out there? If you have links to other sites hook it up. Thanks
89-90 240sx KA24E $2,999.00 - includes; Our custom manifold, T4 Hi-Flow Turbocharger unit, Non- intercooled, External wastegate, Downpipe flange and 3 inch downpipe(assembled), Steel braided Oil send/return kit (w/ all necessary fittings), Cool side pipings, Couplers and clamps, Vacuum hoses and clamps, Cold air intake, Air Filter, Gasket(s), Nuts & Bolts, TurboXS blow off valve, Boost dependent Dual adjustable Fuel management unit (FMU), Fuel pump, Dual guage pillar pod, Air Fuel ratio meter, Boost/Vac guage.
Hi
Var is offline   Reply With Quote
Old 01-23-2004, 05:00 PM   #2
HiPSI
HiPSI is an unknown quantity at this point
Send a message via AIM to HiPSI Send a message via Yahoo to HiPSI
ripoff... for $3000 and no electronics or intercooler, screw that. you could piece all that crap together much cheaper.
SR motor set/clip $2500+, FMIC kit $700+, Downpipe $100+, 3" exhaust $500+, Misc install parts $100+, Shop labor for install $1000+ and you still only make 220rwhp for $5000
so what's so CHEAP about the SR swap again?
HiPSI is offline   Reply With Quote
Old 01-23-2004, 05:32 PM   #3
Var
Var's Avatar
werd that's what i wanted to hear. got any links?
Hi
