Old 01-24-2004, 01:47 AM   #1
FallbrookS13
FallbrookS13 is an unknown quantity at this point
Send a message via AIM to FallbrookS13
adj. rear upper arm..adj question...
ok. i am curious... when you have the adj. rear upper arm. (for adj. camber) do you have to unbolt the side that has the heim joint (pillowball) and then turn it in 180 degree rotations to make adjustments?? and then bolt it back on and check camber angle....then repeat the process to make another adjustment? i obviously do not own these. i amjust curious as to how they work.
thanks
hi.
FallbrookS13 is offline   Reply With Quote
Old 01-24-2004, 01:58 AM   #2
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
No, it has 2 threaded sections. You turn one and lock with another.
Chernobyl is offline   Reply With Quote
