Old 02-01-2011, 01:27 PM   #1
jlmillionaire
jlmillionaire's Avatar
jlmillionaire is an unknown quantity at this point
SR 550s or 650cc for gt28r
Hey was good everyone,I just need a little advice on what size injectors to go with my current setup.I have a garret gt28r should i go with 550 or 650? And where should i get a rom tune? jwt nistune enthaply?
jlmillionaire is offline   Reply With Quote
Old 02-01-2011, 01:37 PM   #2
nismoman
nismoman is an unknown quantity at this point
Either injector is more than enough, but if you are thinking about a JWT tune I would contact them to find out what brand injector he recommends for his tunes. I don't think enthalpy is as picky about brand. Both do great work.
Nistune is great if you wanna tune yourself or have a good local tuner
nismoman is offline   Reply With Quote
Old 02-01-2011, 01:46 PM   #3
jlmillionaire
well the 650 would be good for more hp correct,and im gonna do rom tune for now till i get my hands on a aem or apex pfc
Old 02-01-2011, 01:52 PM   #4
Chaw wee
Chaw wee's Avatar
Chaw wee is an unknown quantity at this point
Yes 650 will be good for more hp, but 550's will do just fine also.. If you are planing on going for more in the future, just get the 650's now, and not have to worry later.
Chaw wee is offline   Reply With Quote
Old 02-01-2011, 02:02 PM   #5
jlmillionaire
Ok good look on the input is jecs a decent company?i saw a set of 650 for like 230... wich is considerably cheap compared to others.By the way they are remanufactured and come with a flow test sheet>
Old 02-01-2011, 02:09 PM   #6
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
base it off your future goals and current engine management.
if your running a rom tune with a SAFC stick with 550cc's
if you have a standalone or are going to soon. go 650cc's
Grenade180sx is offline   Reply With Quote
Old 02-01-2011, 02:11 PM   #7
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
Nistune/JWT and 740cc done. overkill never fails.
Review Thread
bardabe is offline   Reply With Quote
Old 02-01-2011, 02:16 PM   #8
jlmillionaire
well i do have a safc 1,being repaired by apex and the tech guy keith said the safc max tuning capabilty is 550...
Old 02-01-2011, 02:28 PM   #9
bardabe
bardabe's Avatar
after it comes back from apex sell it and buy Nistune. but if you really must use the SAFc. go no bigger than 550.
Review Thread
Old 02-01-2011, 03:29 PM   #10
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
LOOOOL!
<meatloaf>took the words right outa my mouth</meatloaf>
To the O/P (and to mimic Bardabe), go with the biggest injector you can. 550's will get you to 350ish whp before being maxed out, so why not go with 740's and be done with it.
Old 02-01-2011, 05:51 PM   #11
anton1o
anton1o's Avatar
anton1o is an unknown quantity at this point
Send a message via MSN to anton1o
Injectors arent turbo suitable based, you could be running a TD06 on 550cc injectors.
They will max flow on HP rating achiveable, on an SR20 your looking at maxing out 550cc injectors at around the 220-240rwkw mark.
So if your only planning to run 200rwkw in an SR20 with that turbo 550cc is MORE than enough, but if down the track your really thinking of running more boost more power, then it would be nice to run 650/740's so your only running them at 60% load over 100%
anton1o is offline   Reply With Quote
Old 02-01-2011, 06:42 PM   #12
jlmillionaire
so what kind of whp or bhp should i get with this setup,tomei 260,bc dual spring and ret,gt28r,740cc inj,greddy fmic, trust 3.5 inch exhaust greddy turbo elbow and dp,z32 mafs and nis tune.and what boost settings should i run with avcr
Old 02-01-2011, 06:46 PM   #13
jlmillionaire
i also have flex a lite dual fans if that matters and jgy 6 puck clutch,i need to get a exhaust manifold tho whats good tomei from bottom mount setup
Old 02-01-2011, 07:26 PM   #14
codyace
codyace's Avatar
Trader Rating: (58)
As I said earlier, the 550's are plenty for 350ish whp assuming we're looking at lower 90% cycle. Considering 50lbers will max in the 350 range considering the tune, I bet you could see 375/380 whp at 100 percent duty...to say they max as low as 300-325 whp is not true. While that may be an old 'safe' limit, I think we all know that Nismo/STI sidefeed 550cc injectors will live just fine in the upper 90% duty cycle.
But the end comment is true, I'd rather run a larger CC injector at a much lower duty any day of the week. However I can't deny how 'tough' some injectors have proven to be at close to 100%.
Why would you ever run BC springs on a Tomei cam? Run Tomei springs.
You should see 300-325 whp at big boost. Trust me when I say I'd strongly suggest going 2871r before you even get it set up...it will spool darn near as quickly as the 28r, but make 300 whp at amuch lower boost, while allowing much more power on the top end.
Stock manifold
Search for the '2871r thread' and read it all.
Old 02-01-2011, 08:02 PM   #15
jlmillionaire
Well the place jgy where im getting the stuff from, said i can use bc springs i originaly i wanted tomei springs but they recomended bc they said its the same as tomei and basically im paying for a name.my gt28r is brand spanking new so i will stick with that for a while.then sell it then upgrade.
Old 02-01-2011, 09:02 PM   #16
codyace
codyace's Avatar
Trader Rating: (58)
Google the horror stories about JGY
...amazing that people still us them :/
JGY suggesting BC springs/retainers is complete awful suggestion, especially when they are nothing more than a copycat company with no real RD section.
If you have tomei cams, run tomei springs. HKS cams? HKS springs. JWT Cams? JWT Springs.
I'd still sell the 28r and look at a 2871r setup if I were you. You're only going to be upset knowing you could have a turbo capable of another 50-75 whp, much more torque and average power, all on the same setup.
Old 02-02-2011, 05:36 AM   #17
jlmillionaire
Ok thanks ,i will change the order from bc springs to tomei will i be able to rev higher?ill prob sell my turbo after i put like 1000 miles on it,the dam turbo cost me 800 a couple years ago.
Old 02-02-2011, 05:38 AM   #18
jlmillionaire
Yes and trust me i know about the horror stories they took three months to do my wiring harness,ill never have them work on my my car or any of there services.But they do hook me up on prices and allow me to do payment plans.
Old 02-02-2011, 07:33 AM   #19
codyace
codyace's Avatar
Trader Rating: (58)
With a 28r, you're not going to need to take it much last 7000 rpm as its' just blowing hot air at that point. I'd say a save rev limit at 7850 though as when you upgrade turbo it will be good.
The major limiting factor of 'safe' additional revs (that is, 8000-9000) really are the lifters
Old 02-02-2011, 10:55 AM   #20
jlmillionaire
well the gt28r will be good for now,im really trying to set my s14 for drifting,i do want that gt2871r tho i wish the guy would have got me that turbo instead.Originaly i was going with gt28rs but jgy shipped the shop in my town the wrong turbo at that point i had no knowledge and i was in a rush to do my swap>
Old 02-03-2011, 05:12 AM   #21
Q.Smooth127
Q.Smooth127 is an unknown quantity at this point
yes to overkill
Q.Smooth127 is offline   Reply With Quote
Old 02-04-2011, 08:47 PM   #22
bing
bing will become famous soon enoughbing will become famous soon enoughbing will become famous soon enoughbing will become famous soon enoughbing will become famous soon enough
doesnt matter between the two... get the cheaper set and put the savings towards a better tuner
i went from 650's down to 550's and made 12whp more... tired injectors i guess.
same tuner, rest of the set up was the same.. 650's were 2-3 years old.
www.son240sx.org /// www.nyspeed.com
bing is offline   Reply With Quote
