Old 02-13-2011, 10:59 PM   #1
GeneStarWindGSW
GeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant future
Everyone too poor on zilvia to buy stuff
Well I'm leaving for the Miltary in April...soo all this stuff has to go or it might get tossed in the garbage.
You Contact me via PM, AIM: xxT88SupraT88xx , or text: 305-984-5103.
If I haven't gotten back to you and your still interested in anything, leave a message and I'll get back to you ASAP.If my inbox is full, leave me a visitors message.
(also if u have nothing good to say, just don't post..thank you)
I'll consider trades for parts below
V8 1UZ Swap
Traction Arms, Strut Bars, Tension Rod/Subframe/Door Brace, Etc
Motor/Tranny Mounts
Glovebox, Center Console, S14 Radio Bezel & s14 cut radio harness
Touchscreen 7" DIN
4-2-1 Header
Exhaust
B&M Short Shifter
Tires (205-235/35-40/17---255/35-40/17---225-255/40/18)
17" Wheels OR 18x9.5 Gunmetal MB battles OR baller wheels 17/18x10-11-12
Nissan PARTS FOR SALE/TRADE
  • KA/SR Shifter - $15
  • 240sx Frame Exhaust Heat Shield - $10
  • S13 Dead Pedal - $15
  • S13 Dash HUD - $25
  • KA24DE Injectors - $5 EA
  • KA24DE Crank Pulley - $40
  • S13 Red Valve Cover - $30
  • KA24DE Injectors /w round pinkle caps inside Rail /w FPR - $40
  • S13 KA24E Cut Tucked Engine Harness (ECU/Interior plug cut) - $20
  • KA24DE Oil Pan - $50
  • S13 Stock Rucas & Toe Rods - $15 A Set
  • KA24DE Bad Starters (Good for cores) - $15
  • S13 KA24DE Engine Harness (Cut interior Plug) - $30
  • S14 Toe/Rucas/Traction/RLCA & 5lug Knuckle - $15 EACH SET/ $20 for Knuckle
  • S14 Open Diff - $20
  • S14 Front Mudflaps - $30
  • S14 Charcoal Canister - $5
  • S14 6bolt Axles - $50
  • S14 Zenki Fog Delete - $30
  • S14 Horn - $20
  • SR20 T25 Oil/Coolant Turbo Lines - $30
  • SR20 Manifold - $70
  • SR20 Fuel rail - $10
  • SR20 T25 Elbow /w Gasket - $35
  • Incomplete Set of 240sx Peak Performance Poly Rear Subframe Inserts One is Torn - $15
  • DOHC Throttle Cable - $30
  • S14 Stock Clarion Amp - $30
  • S13 Radio Brackets (L/R) - $30
  • 180sx bumper turn signal (RIGHT) - $50
  • Z32 E-Brake Cables for S13 - $100
  • AEM EMS for S13 89-94 KA (in the box) - $1000
  • M/T ka flywheel bolts - $45
  • S14 to S13 KA Adapter harness - $80 {needs to be soldered}
Toyota PARTS FOR SALE/TRADE
  1. 1JZ/2JZ ARP rod bolts - $65
  2. 7m Blockoff Plate - $10
  3. Magnetic Drain plug for R154 Transmission - $15
  4. 1JZ/2JZ TTC Fan Pulley Cover - $60
  5. 1JZ/2JZ Thermostat Housing Rotator plate- $55
  6. R154 Throwout Bearing - $20
  7. R154 Clutch Hub bearing - $45
  8. 1JZ/2JZ Stock Oil Filter housing /w dual -10AN fittings - $100
  • R154 used Slave cylinder & hardline - $20
  • R154 Clutch Fork - $55
  • 2JZ-GE EGR Delete /w Gasket - $15
  • MR2 Manual Steering Rack - $30
  • Toyota Emblems - $2 EA
  • Cressida Rear Driveshaft Piece - $10
  • JZX81 Cressida mounts/brackets - $250
  • Cressida RHD Swap - $600
Wheels FOR SALE
  • (Pair) 18x8.5 Zenetti Vega wheels (5x114.3)(Bad Tires) - $150
  • (4) 18x8.5 Zenetti mystic wheels (brand new cooper 215/35/18 tires) (5x100) - $400
  • (Pair) 17x9 +30 Gunmetal MB battles /w Bald/Crap tires (5x114.3) (205/40/17) - $350
GeneStarWindGSW is offline
Old 02-13-2011, 11:00 PM   #2
GeneStarWindGSW
PART TWO
CAR PARTS FOR SALE/TRADE
  • RX-7 Turbo II S4 Turbo Manifold - $20
  • Kazama 5spd Shift Knob (12x1.25) - $50
  • 5x100 --> 5x114 Conversion Spacer - $40
  • Tow Hook - $5
  • Megan Coilover Threaded Collar - $5
  • 36" -4AN SS Line - $25
  • 5 bolt turbo downpipe flange|wastegate delete - $10
  • 3" Spectre Coupler - $5
  • 3" IC Pipe 45 Deg - $10
  • 3" Dynomax IC/Intake/Exhaust Pipe - $10
  • 3" Chrome Metal Coupler 45 Deg - $5
  • 3" Black Hard Plastic Coupler 45 Deg - $5
  • 2.75" IC/Intake Pipe 45 Deg Cut - $10
  • 2.5" IC Pipe Straight - $15
  • 2.5" IC pipe 90 Deg - $15
  • 2.5" IC Pipe 45 Deg - $15
  • EVO X Braided Air Hoses 2.5" & 2" - $20
  • Steering Wheel - $20
  • 5 Panel Rear View Mirror - $35
  • (Pair) 15mm slip on spacers 5x114.3 only - $50
  • Magnaflow 24" long 3" louvered resonator - $70
  • Treadstone Intercooler - $150
  • G-Force Racing Gloves - $45
  • T4 Oil Drain Flange /w -10AN Fitting- $20
  • (4) Top feed FC RX-7 550cc injectors high impedence -$150
  • (8-12) 2jz-ge injectors (325cc) - $50 (have more just not shown)
  • (6) 1jz-gte injectors (370cc) - $70
MISC PARTS FOR SALE/TRADE
  • Digital Music Mixer - $40
  • Body Massager - $15
  • Subwoofer Box with (Pair) of 12" Subs - $50 or sell Kicker sub for $20
  • ONE of a Kind Car poster (32in x 48in) - $40
  • Sprint HTC Hero ((data cable, wall charger, car charger, screen protector, phone case, manual, covers, battery & Fully working/ Clean ESN. Can be used on sprint or flash to metro, etc) - $100
  • HTC Google G1 (White Face, Works) - $100
  • Security Camera - $35
  • HP IPAQ H4350 Pocket PC - $20 (can be used for tuning software that support mobile PC)
  • Pioneer Radio /w remote (DEPH-P4300) - $40
  • custom built PCs & computer repair (15yr experience) - PM me for details
Old 02-13-2011, 11:08 PM   #3
chinabean
chinabean's Avatar
chinabean is an unknown quantity at this point
pm for the zenki coolingp late shipped to 85353
Zenki Love - I spray paint my stock 15" hubs teal and rockillest/supreme/obey stickers on my car.
chinabean is offline
Old 02-14-2011, 11:26 AM   #4
h2v7
h2v7 is an unknown quantity at this point
pics of coilovers or did i miss them?
h2v7 is offline
Old 02-14-2011, 12:07 PM   #5
One_love_silvia
One_love_silvia's Avatar
Trader Rating: (38)
Feedback Score: 38 reviews
i think i saw a double sided dildo..
One_love_silvia is offline
Old 02-14-2011, 01:38 PM   #6
S14Nep
S14Nep's Avatar
S14Nep is an unknown quantity at this point
i think i saw a double dildo as well lol.
S14Nep is offline
Old 02-14-2011, 01:54 PM   #7
nissanfreak317
nissanfreak317's Avatar
Trader Rating: (18)
nissanfreak317 is an unknown quantity at this point
Feedback Score: 18 reviews
I might snag those ka injectors and rail off ya, I have one of those HTC Heros sitting around too, haha maybe I'll throw it up for sale... Sprint offered me $40 for it in their recycle program.
nissanfreak317 is offline
Old 02-14-2011, 03:21 PM   #8
Hollywood30
Hollywood30 is an unknown quantity at this point
Willing to ship rear bumper to 15108? If so let me know. Tks.
Email: [email protected]
Text: 412-999-9339
Hollywood30 is offline
Old 02-14-2011, 03:34 PM   #9
jsaviour84
jsaviour84's Avatar
jsaviour84 is an unknown quantity at this point
ka turbo manifold and whatever you have for that conversion
EVO X GSR and R32 GTR
jsaviour84 is offline
Old 02-14-2011, 03:42 PM   #10
DertyDan
DertyDan's Avatar
Trader Rating: (22)
DertyDan is an unknown quantity at this point
Feedback Score: 22 reviews
http://www.youtube.com/watch?v=Ww3GTNv9hHk
DertyDan is offline
Old 02-17-2011, 11:17 PM   #11
GeneStarWindGSW
Originally Posted by DertyDan View Post
lol
PM'ed u
Text: 412-999-9339
i'll let you know asap
PM'ed u
No Coils
Pmed u
Old 02-17-2011, 11:49 PM   #12
Drift_86
Drift_86's Avatar
Trader Rating: (60)
Feedback Score: 60 reviews
This sucks I can't c any of the pics?
Drift_86 is offline
Old 02-18-2011, 12:13 AM   #13
GeneStarWindGSW
try clearing cache/history and refresh
Old 03-06-2011, 11:20 PM   #14
GeneStarWindGSW
bump, still got all this
Old 03-07-2011, 12:42 AM   #15
locoluna825
locoluna825's Avatar
locoluna825 is an unknown quantity at this point
Take 5 dollars for the big dick vibrating dildo?
locoluna825 is offline
Old 03-07-2011, 01:07 AM   #16
turbox18
turbox18's Avatar
turbox18 is an unknown quantity at this point
Send a message via AIM to turbox18
ill give you 10 bucks shipped for poster ??
turbox18 is offline
Old 03-16-2011, 10:21 PM   #17
GeneStarWindGSW
bumped, more stuff added & sold
Old 03-16-2011, 10:52 PM   #18
statickx991
statickx991 is an unknown quantity at this point
lmao 5 dollars but thats without the d batteries you could prolly rent it out for like 2.50 a session make your money back
im a f18 bro
statickx991 is offline
Old 03-16-2011, 11:05 PM   #19
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
s13 military
hey man what branch of service? i just got back from afghan 9 days ago! im not broke!!
lewisfk is offline
Old 03-16-2011, 11:42 PM   #20
GeneStarWindGSW
still for sale
well buy some stuff, im goin navy.
Old 03-16-2011, 11:57 PM   #21
GeneStarWindGSW
Under $50 Sale
Well I'm leaving for the Miltary in April...soo all this stuff has to go or it might get tossed in the garbage or put into storage.
PM me or Txt me 305-984-5103
V8 1UZ Swap
Motor/Tranny Mounts
Touchscreen 7" DIN
4-2-1 Header
Exhaust
B&M Short Shifter
  • Tow Hook - $5
  • S14 Horn - $20
Old 03-16-2011, 11:57 PM   #22
GeneStarWindGSW
PART TWO
  1. 7m Blockoff Plate - $10
  2. Magnetic Drain plug for R154 Transmission - $15
  3. R154 Throwout Bearing - $20
  4. R154 Clutch Hub bearing - $45
Old 03-17-2011, 04:03 AM   #23
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
navy...>.<
ftl = /
nismoracingsx is offline
Old 03-17-2011, 07:49 AM   #24
blackej7
blackej7's Avatar
blackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really nice
PM sent.....
blackej7 is offline
Old 03-22-2011, 12:25 AM   #25
GeneStarWindGSW
bump, still got a lot of stuff
Old 03-22-2011, 12:46 AM   #26
GeneStarWindGSW
bump stuff u want, come!
Old 03-22-2011, 09:40 AM   #27
racerx2k1
460
racerx2k1's Avatar
racerx2k1 is offline
