Old 03-01-2011, 12:29 PM   #1
godzillarb
godzillarb's Avatar
godzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to all
Major rust under door. Ideas on fixing?
5 minutes later...
I noticed some serious rust under the passenger side quarter panel this morning, poked it with my finger, and everything fell apart. Ugh. Started cutting and it just gets worse. Rust keeps going past where I cut in the picture, but is getting less and less torward the front. The metal support with the holes in it is rusted through and basically fucked. The part that really worries me is the backside of the sheet metal is rusted as well. Seems like it'd be a lot harder to fix / get to?
I'll get more pictures later, but any ideas on tackling this? I'm decent with a mig welder, just not really sure where to start.
INTENSE POWER RIPPED ME OFF
godzillarb is offline   Reply With Quote
Old 03-01-2011, 06:35 PM   #2
Def
That's a lot of rot if those interior panels are also rusted up that badly. Any chance of getting some more pics?
I'm thinking you're surpassing just basic sheetmetal repair. Might want to visit a junkyard and cut up another car to get some donor metal. Just piece it back up with maybe some additional gussets.
DEFSPORT
Old 03-02-2011, 07:56 AM   #3
godzillarb
godzillarb's Avatar
Started cutting into it more, but need more cut off wheels. *sigh*
So far, the more I remove, the worse it gets.
Old 03-02-2011, 08:03 AM   #4
Darren
Darren's Avatar
Darren is an unknown quantity at this point
looks like you had a leak at one point ...
You are on the right track, all you can do is keep cutting, and as Def said, you could find clean panels from a donor car and patch them in, or you can just weld in metal to replace what you're cutting (it's just on the inside anyway) and then dose liberally with weld through zinc primer and por15 to keep it from rusting again.
Hope that helps, but it looks like you're in for some work there.
Good thing is, it's not the whole car, just localized.
Darren is offline   Reply With Quote
Old 03-02-2011, 08:11 AM   #5
godzillarb
godzillarb's Avatar
Apparently, the quarter panel had been replaced there due to a crash. I'm thinking it was improperly fixed (understatement of the year). Also, it looks like there's a water hose coming from the sunroof that exits right there. fml
From the location, I think I'll be able to hide everything with a sideskirt so that's the plan at the moment. Can I pick up por15 at home depot / an auto parts store?
Old 03-02-2011, 03:02 PM   #6
spice_weazle
spice_weazle is an unknown quantity at this point
A lot of UK cars are like this. Ours rust due to a large hole on the part of the inner sill in the rear arch just above the subframe Y bracket. I had to replace both sides on my 14a. Its a pretty big job.
spice_weazle is offline   Reply With Quote
Old 03-02-2011, 06:16 PM   #7
Def
I guess you could just get the sheetmetal down to a common point and weld in a piece of 1.75 x 0.095" DOM tubing then cover with a side skirt. That would be at least as robust as the factory rocker.
DEFSPORT
Old 03-02-2011, 06:19 PM   #8
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
I HATE RUST! But like everyone said just cut it out & weld fresh sheets of metal GL....
jdm2191 is offline   Reply With Quote
Old 03-02-2011, 08:07 PM   #9
godzillarb
godzillarb's Avatar
Getting a little worried with how much I'm having to cut out. Oh well, the saga continues.
Old 03-03-2011, 07:19 PM   #10
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
shit i fear my car is like that thanks to my fucking stupid sunroof trim ripping off and letting water accumulate in this spot. i would get a donor car for the easiest way to replace it.
Old 03-03-2011, 08:02 PM   #11
godzillarb
godzillarb's Avatar
Yeah, that's where I'm at right now. There is more rust than I originally thought. I'm currently looking for another shell.
It'll probably take too much time to fix properly.
Old 03-03-2011, 08:35 PM   #12
240sxrb25
240sxrb25 is an unknown quantity at this point
thats what i did. my s13 had a badly rusted driver frame rail to the point of the front apron splitting away and the shock pushing up on the hood. i bought a shell haha.
240sxrb25 is offline   Reply With Quote
Old 03-03-2011, 08:36 PM   #13
240sxrb25
your sig says widebody...yout not hacking your widebody are you lol
Old 03-03-2011, 08:40 PM   #14
godzillarb
godzillarb's Avatar
That's the worst part. I had the rears molded years ago and not really sure how to save them or if it'd even be worth it. Why the shop that did it wouldn't say anything about the epic rust is anyone's guess
Old 03-09-2011, 09:23 PM   #15
Eramo323
Trader Rating: (22)
Eramo323 is an unknown quantity at this point
Feedback Score: 22 reviews
Send a message via AIM to Eramo323
Get A Shell save yourself all the extra work !!!!!!!
Eramo323 is offline   Reply With Quote
