Old 03-06-2011, 06:37 PM   #1
jlmillionaire
jlmillionaire's Avatar
jlmillionaire is an unknown quantity at this point
SR Faint smell of fuel inside car??
Hi all, i just got my s14 sr20 on the road, I've been driving it around and i smell a faint smell of fuel inside the car.I wonder if i didnt correctly install the fuel pump??or do i have a leaky injector?? please someone help me out before i get serous migranes lol
jlmillionaire is offline   Reply With Quote
Old 03-06-2011, 06:41 PM   #2
stephens14sr
stephens14sr is an unknown quantity at this point
is it tuned? could just be running rich.
Full 2014 build progress www.handicapmafia.wordpress.com
stephens14sr is offline   Reply With Quote
Old 03-06-2011, 07:02 PM   #3
josephin510
josephin510's Avatar
josephin510 is an unknown quantity at this point
Check for leakage in engine bay none check under the car for leakage still can't find it its the tank.
Trade my Rb25 for some wheels.
Buy my Sc300.
josephin510 is offline   Reply With Quote
Old 03-06-2011, 07:08 PM   #4
jlmillionaire
no tune stock ecu its probably running rich,i have a aeromotive fpr set to 43.5
Old 03-06-2011, 07:09 PM   #5
stephens14sr
i may be wrong, but i think when the bov isnt recirculated it causes the ecu to confuse fuel and makes it run rich.
Old 03-06-2011, 07:10 PM   #6
jlmillionaire
s14
yes ill do that i dont think the injectors are leaking because i dont really see fuel in engine bay or near the intake mani
Old 03-06-2011, 07:22 PM   #7
Schassis707
Schassis707's Avatar
Trader Rating: (18)
Schassis707 is an unknown quantity at this point
Feedback Score: 18 reviews
It could also be the o ring in the tank or the upper gasket in the trunk too
Originally Posted by eddieflo View Post
use paint colors from other vehicles on your 240 too bolts right on
Schassis707 is offline   Reply With Quote
Old 03-06-2011, 07:22 PM   #8
blktopsr20
blktopsr20's Avatar
Trader Rating: (83)
blktopsr20 is an unknown quantity at this point
Feedback Score: 83 reviews
If you replaced the ff parts for aftermarket ones i suggest to get new gaskets for them:
Fuel pump- housing plate o-ring gasket
Fuel injectors o-ring gaskets
Fuel filter- check for loose clamps or cracked hoses
Lastly check fuel tank and fuel hoses for leaks and cracks
Hope this helps
blktopsr20 is offline   Reply With Quote
Old 03-06-2011, 08:03 PM   #9
jlmillionaire
Hope this helps
aigh thanks ill check those things,when i upgrade my injectors i will put in new o-rings
Old 03-06-2011, 08:05 PM   #10
jlmillionaire
that might be true i dont have it recirculated a tune should fix that i hope.
Old 03-06-2011, 08:10 PM   #11
abunai the drifter
abunai the drifter's Avatar
abunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-known
Send a message via Yahoo to abunai the drifter
more than likely it your o-ring for your fule pump i had the same problem it need to be replaced every time your remove your fuel pump
screw you guys im going drifting
abunai the drifter is offline   Reply With Quote
Old 03-06-2011, 08:23 PM   #12
jlmillionaire
hey guys is this what i need? 89-94 Nissan 240SX Fuel Pump Tank Gasket Oring O-Ring - eBay (item 190430153859 end time Mar-09-11 14:58:33 PST)
