Old 08-18-2008, 11:47 AM   #1
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
S14 SR20DET Timing Problems, Q's. Guru's pls.
I'v had this problem with Timing my sr20det for sometime now,
not being able to set base timing to anything near 15 degrees.
Iv installed the CAS several times, each time not being able to start the car.
This is following the FSM. I finally got the car running after installing it, it runs, and runs okay but the car runs extremely HOT! It times at 23 Degrees (most retarded), it doesnt drive well... because I cannot retard it anymore I advance it to 26 degrees and it runs fine.
It starts and drives, a bit laggy as some rpm but drives okay I dont ever bag on it because it runs so hot!
I want to now fix the basetiming, drop it down to maybe around 18+- degrees.
Specs of the car,
S14 Kouki SR20DET
S14 WC Zenki ECU
S15 MAF
Emange Blue (doesnt have timing harness installed)
What can I do to change the base timing to 15, would anything off the specs list effect my timing?
kuruptR is offline   Reply With Quote
Old 08-18-2008, 12:32 PM   #2
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
WC ecu w/ kouki motor and S15 MAF?! Why?
97 240sx se
0wn3r is offline   Reply With Quote
Old 08-18-2008, 01:13 PM   #3
kuruptR
kuruptR's Avatar
lol, doesnt answer my question..but here is the answer to yours; I used to have a zenki motor, purchased a kouki long block because the other one had some issues. The maf because it was the only one I could find that was said to work with the WC ECU, but didnt really matter because I have emange to convert the signal.
Anyhow, back on topic.
Old 08-19-2008, 09:54 AM   #4
SoSideways
SoSideways's Avatar
Is your timing chain loose? Because if it is, you might not be able to time your motor correctly.
Old 08-19-2008, 01:06 PM   #5
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
are you just pulling the CAS in and out without removing the VC? I recently did cams this weekend and ran into the same problem of the car not starting. After removing and installing the CAS 2 or 3 times with no luck I finally pulled the VC back off and made fucking sure it was lining up. the car starts up great and runs like a champ. Maybe the same problem.
What all started this problem, disassembly?
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 08-19-2008, 02:01 PM   #6
kuruptR
kuruptR's Avatar
Its been like this since iv installed the s14. I went from s13 - 14 sr a while back, but have never been able to time the s14 properly.
Im gonna pull the CAS and valve cover off tonight.
Old 08-19-2008, 06:10 PM   #7
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Specs of the car,
S14 Kouki SR20DET
S14 WC Zenki ECU
S15 MAF
What RPM are you setting base timing at? Thats most important, this cannot be guesstimed by that I mean with the gauge cluster, you need a digital tachometer.
Old 08-20-2008, 01:01 PM   #8
kuruptR
kuruptR's Avatar
yeah i have a digital tach on my timing gun
Old 03-21-2011, 09:03 PM   #9
kuruptR
kuruptR's Avatar
Just to update someone asked me, it was incorrect installation of CAS. When i was pushing it in, it was going off slightly. It has to be accurate as hell.
@woooster on instagram
Old 03-21-2011, 09:16 PM   #10
RZRSHARP_240SX
RZRSHARP_240SX's Avatar
RZRSHARP_240SX is an unknown quantity at this point
How To Set Crank Angle Sensor (CAS) Timing on the SR20DET Engine
this is what I have always refered to when doing my timing. make sure you at TDC with the cams facing out. and align the marks. if you need help I am local with you I can help
RZRSHARP_240SX is offline   Reply With Quote
Old 03-23-2011, 12:48 PM   #11
s14unimog
s14unimog's Avatar
Trader Rating: (22)
HA! I called it! 2 years ago!
