Old 03-30-2011, 03:06 PM   #1
dwadia
dwadia is making his/her stupidity well-knowndwadia is making his/her stupidity well-knowndwadia is making his/her stupidity well-known
VDO Cockpit black gauges - Boost, Oil Pressure w/ braided SS 4' hose & warning ligBht
Both gauges are 2 1/16" (52 mm) and illuminate white (you can probably change this with one of those colored bulb covers, i've never looked into this. They look great white, like OEM).
Boost/Vac gauge, part# 150063 - -30 to 25 psi. excellent condition and removed fully working. Includes angled mounting ring (pictured) and stock mounting bracket and bulb (not pictured). When off, the needle seems to rest at about 1 in/hg (vac)... as far as i'm concerned not an issue, i had a boost controller installed with a digital reading and there was no significant discrepancy between the 2 readings. $25 shipped or $20 picked up.
Oil Pressure gauge, part# 150107 - 100psi mechanical, seemed to be very accurate (no lag in response time). Works perfectly. Includes angled mounting ring, 4' Autometer braided steel oil hose, Longacre adjustable low-pressure warning light (adjusts from 15-15 psi) with NEW IN BOX sender (all pictured), and mounting bracket and bulb (not pictured). All together, about $150+ new. $75 shipped or 70 picked up.
Dual-Gauge Pod for Center Vent - primed and painted black to match the dash. Paint shows some wear and could use a re-spray, but it's not bad at all. One side is still unpainted brushed aluminum, so in case you prefer this look, you can flip it. FREE IF YOU BUY BOTH GAUGES, otherwise $12 shipped or $10 picked up.
dwadia is offline
Old 04-02-2011, 08:25 AM   #2
dwadia
bump... offer what you think it's worth.
dwadia is offline
Old 04-09-2011, 07:23 PM   #3
dwadia
second bump
dwadia is offline
Old 04-09-2011, 07:32 PM   #4
RJs9DsixS14
RJs9DsixS14's Avatar
RJs9DsixS14 is making his/her stupidity well-knownRJs9DsixS14 is making his/her stupidity well-knownRJs9DsixS14 is making his/her stupidity well-knownRJs9DsixS14 is making his/her stupidity well-known
Send me your info i want the Dual-Gauge Pod for Center Vent
RJs9DsixS14 is offline
Old 04-09-2011, 07:36 PM   #5
dwadia
i will PM you my info but please make sure this is the piece you are looking for...
dwadia is offline
Old 04-28-2011, 06:18 PM   #6
dwadia
final bump... there has to be someone on here who needs boost and oil pressure gauges, just make an offer if you're interested.
dwadia is offline
Old 04-29-2011, 07:55 AM   #7
racerx2k1
460
racerx2k1's Avatar
second bump
racerx2k1 is offline
